fuzzyl0gic
VLAN test scenario
Sun Oct 03, 2021 7:36 pm
Hello all,
I'm new to Mikrotik products and have recently acquired an RB4011 router.
I am very impressed by the amount of configuration possibilities.
Part of why I chose to go with Mikrotik is to improve my understanding about networking, solving more complex tasks as I progress.
I have decided to start with something common, which is utilizing VLANs to segment a network.
# Synposis
To get the hang of configuring the router - and before putting it into use in my home network (and risking larger downtimes ;)) - I've decided to implement a small, isolated (no internet / WAN) scenario using VLANs.
My goal (target setup), approach, current configuration and open points are detailed below.
Why I am writing here:
1. To get feedback on my first attempt from experienced folks here (to see if I am on the right track, or possibly already took a wrong turn somewhere)
2. Help on the issues I have encountered and am currently stuck on (I've summarized some ideas at the bottom of this post)
Any help or pointers are very much appreciated :)
## Target setup
Topology:
* Three VLANs:
* VLAN 1: Management VLAN where access to the router and managed switch is allowed
* VLAN 10: Devices of class A
* VLAN 20: Devices of class B
* Router (RB4011, 10 ports):
* ether1: Trunk port for VLANs 1, 10, 20
* ether2, ether3: Access ports for VLAN 1
* ether3 to ether6: Access ports for VLAN 10
* ether7 to ether9: Access ports for VLAN 20
* ether10: Currently not used
* Managed switch (not from Mikrotik):
* ether2 to ether4: Access ports for VLAN 10
* ether5 to ether7: Access ports for VLAN 20
* ether8: Access port for VLAN 1
Networks:
* VLAN 1: 10.10.1.0/24
* VLAN 10: 10.10.10.0/24
* VLAN 20: 10.10.20.0/24
With this setup I would like to:
* Allow only devices in VLAN 1 to access the managed switch and router for management purposes
* Allow devices in VLAN 10 to communicate with one another, but not with devices in other VLANs
* Allow devices in VLAN 20 to communicate with one another, but not with devices in other VLANs
## Current state
What works: Devices connected to the switch are assigned an IP address from the correct range, depending on which port they are plugged into.
Current open issues:
1. The router still has an IP in the default range (192.168.88.1/24)
2. Devices connected to ether2 and ether3 on the router are still given an IP from the default address range, not the VLAN 1 address range
3. There seems to still be routing between devices on individual VLANs, which I would expect to not be possible (e.g. I can ping a device with IP 10.10.20.253, connected to ether5 on the switch from another device connected to ether2 on the switch which was given an IP of 10.10.10.2; only when the swith is connected to the router though))
## Router configuration
The following are the configuration steps taken for the router.
### Interfaces
Add the following new interfaces:
* Bridge interface `bridge`
* Three VLAN interfaces `vlan1`, `vlan10`, `vlan20`, where `bridge` is the parent interface
Configure bridge ports:
* Add `ether1` ... `ether10` to `bridge`
* Keep pvid at `1` for `ether1` to `ether3`
* Set pvid to `10` for `ether4` to `ether6`
* Set pvid to `20` for `ether7` to `ether9`
Configure VLANs for `bridge` interface:
* VLAN with ID `1`: Tagged for `ether1` and `bridge`, untagged for `ether2`
* VLAN with ID `10`: Tagged for `ether1` and `bridge`, untagged for `ether4` to `ether6`
* VLAN with ID `20`: Tagged for `ether1` and `bridge`, untagged for `ether7` to `ether9`
### Addresses and DHCP
Assign the addresses to the following interfaces
* 192.168.88.1/24 for `bridge` (from defconf)
* 10.10.1.1/24 for `vlan1`
* 10.10.10.1/24 for `vlan10`
* 10.10.20.1/24 for `vlan20`
Create the following networks:
* 10.10.1.0/24 for devices in VLAN 1
* 10.10.10.0/24 for devices in VLAN 10
* 10.10.20.0/24 for devices in VLAN 120
* 192.168.88.0/24 is the defconf network
Create the following DHCP address pools:
* Pool for `vlan1`: `dhcp-pool-vlan1` with range 10.10.1.2-10.10.1.254
* Pool for `vlan10`: `dhcp-pool-vlan10` with range 10.10.10.2-10.10.10.254
* Pool for `vlan20`: `dhcp-pool-vlan20` with range 10.10.20.2-10.10.20.254
Create the following DHCP servers:
* DHCP for interface `bridge` with addresses from `default-dhcp`
* DHCP for interface `vlan1` with addresses from `dhcp-pool-vlan1`
* DHCP for interface `vlan10` with addresses from `dhcp-pool-vlan10`
* DHCP for interface `vlan20` with addresses from `dhcp-pool-vlan20`
### Exported config
add admin-mac=2C:C8:1B:03:BB:AD auto-mac=no comment=defconf name=bridge
/interface wireless
set [ find default-name=wlan1 ] band=5ghz-a/n/ac channel-width=20/40/80mhz-XXXX distance=indoors frequency=auto installation=indoor mode=ap-bridge secondary-channel=auto ssid=MikroTik-03BBB7 wireless-protocol=802.11
set [ find default-name=wlan2 ] band=2ghz-b/g/n channel-width=20/40mhz-XX distance=indoors frequency=auto installation=indoor mode=ap-bridge ssid=MikroTik-E8D272 wireless-protocol=802.11
/interface vlan
add interface=bridge name=vlan1 vlan-id=1
add interface=bridge name=vlan10 vlan-id=10
add interface=bridge name=vlan20 vlan-id=20
set 0 default-vlan-id=0
set 1 default-vlan-id=0
set 2 default-vlan-id=0
set 3 default-vlan-id=0
set 4 default-vlan-id=0
set 5 default-vlan-id=0
set 6 default-vlan-id=0
set 7 default-vlan-id=0
set 8 default-vlan-id=0
set 9 default-vlan-id=0
set 10 default-vlan-id=0
set 11 default-vlan-id=0
add comment=defconf name=WAN
add comment=defconf name=LAN
add name=dhcp-pool-vlan10 ranges=10.10.10.2-10.10.10.254
add name=dhcp-pool-vlan20 ranges=10.10.20.2-10.10.20.254
add name=dhcp-pool-vlan1 ranges=10.10.1.2-10.10.1.254
add address-pool=default-dhcp disabled=no interface=bridge name=defconf
add address-pool=dhcp-pool-vlan10 disabled=no interface=vlan10 name=dhcp-vlan10
add address-pool=dhcp-pool-vlan20 disabled=no interface=vlan20 name=dhcp-vlan20
add address-pool=dhcp-pool-vlan1 disabled=no interface=vlan1 name=dhcp-vlan1
add bridge=bridge comment=defconf interface=ether4 pvid=10
add bridge=bridge comment=defconf interface=ether5 pvid=10
add bridge=bridge comment=defconf interface=ether6 pvid=10
add bridge=bridge comment=defconf interface=ether7 pvid=20
add bridge=bridge comment=defconf interface=ether8 pvid=20
add bridge=bridge comment=defconf interface=ether9 pvid=20
add bridge=bridge comment=defconf interface=ether10
add bridge=bridge comment=defconf interface=sfp-sfpplus1
add bridge=bridge comment=defconf interface=wlan2
add bridge=bridge interface=ether1
/interface bridge vlan
add bridge=bridge tagged=ether1,bridge untagged=ether2,ether3 vlan-ids=1
add bridge=bridge tagged=ether1,bridge untagged=ether4,ether5,ether6 vlan-ids=10
add bridge=bridge tagged=ether1,bridge untagged=ether7,ether8,ether9 vlan-ids=20
add address=192.168.88.1/24 comment=defconf interface=bridge network=192.168.88.0
add address=10.10.10.1/24 interface=vlan10 network=10.10.10.0
add address=10.10.20.1/24 interface=vlan20 network=10.10.20.0
add address=10.10.1.1/24 interface=vlan1 network=10.10.1.0
/ip dhcp-client
# DHCP client can not run on slave interface!
add comment=defconf dhcp-options=hostname,clientid disabled=no interface=ether1
add address=10.10.1.0/24 gateway=10.10.1.1
add address=10.10.10.0/24 gateway=10.10.10.1
add address=10.10.20.0/24 gateway=10.10.20.1
set allow-remote-requests=yes
/ip dns static
add action=accept chain=input comment="defconf: accept to local loopback (for CAPsMAN)" dst-address=127.0.0.1
add action=drop chain=forward comment="defconf: drop all from WAN not DSTNATed" connection-nat-state=!dstnat connection-state=new in-interface-list=WAN
/system leds
add interface=wlan2 leds=wlan2_signal1-led,wlan2_signal2-led,wlan2_signal3-led,wlan2_signal4-led,wlan2_signal5-led type=wireless-signal-strength
add interface=wlan2 leds=wlan2_tx-led type=interface-transmit
add interface=wlan2 leds=wlan2_rx-led type=interface-receive
/tool mac-server
/tool mac-server mac-winbox
## Ideas for solving the issues
Ideas for solving the issues mentioned above:
1. Setting the address 10.10.1.1/24 for the `bridge` interface and giving a different address from the 10.10.1.0 network to the `vlan1` interface (I tried this and ended up locking myself out)
2. Using the same DHCP server for `bridge` as for `vlan1`
3. Currently unclear how to proceed, but perhaps looking into the routing / firewall configuration of the router is a way forward here
Users browsing this forum: No registered users and 40 guests
