kirost
winbox can't work correctly if "users" folder moved from disk C:
Mon Oct 04, 2021 11:49 am
after migrating users folders from C: to U: drive, winbox can't find its files.
Instead of
U:\Users\USER\AppData\Roaming\Mikrotik\Winbox
, he looks for them in
C:\Users\USER\AppData\Roaming\Mikrotik\Winbox
(he also tries to write data there, if there is enough access)
C:\>echo %APPDATA%
C:\>echo %USERPROFILE%
U:\Users\USER
Windows 7, Winbox 3.31
rextended
Re: winbox can't work correctly if "users" folder moved from disk C:
Mon Oct 04, 2021 2:38 pm
Put back the users on C:
holvoetn
Mon Oct 04, 2021 3:15 pm
There are sometimes reasons why the user folder is NOT on C:.
Winbox should respect the WINDOWS environment variables. There are meant to be used for that purpose.
anav
Mon Oct 04, 2021 3:48 pm
No wait, doesnt windows conform to winbox standards?? ;-PP
pe1chl
Mon Oct 04, 2021 5:27 pm
There is a file sessionpath in the winbox directory which has a pathname in it. You can edit that.
rextended
Mon Oct 04, 2021 7:20 pm
@kirost
instead to ask on forum or search one file, you have Simply used the function for do that?
on WinBox / Tools / Move Session Folder...
CZFan
Location: South Africa, Krugersdorp (Home town of Brad Binder)
Mon Oct 04, 2021 8:06 pm
Silly question, but you did update any existing icon properties to reflect new folder?
rextended
Mon Oct 04, 2021 9:06 pm
Icon???
Link!!! ???
r00t
Long time Member
Long time Member
Tue Oct 05, 2021 2:13 am
It would be good to have "portable" mode switch that would keep all files in current winbox directory - so it can be put and used from USB flash drive, without modifying any system files.
Something like: If subdirectory PORTABLE_PROFILE exists, store all files in there instead.
joegoldman
Forum Veteran
Forum Veteran
Tue Oct 05, 2021 6:51 am
I have wanted for a long time to be able to move winbox working dir - I'd like to figure out a way to sync my managed lists database between devices without scripts or copying (using something like Dropbox or Nextcloud. THe session folder is just the .viw files so unfortunately is of little help.
pe1chl
Tue Oct 05, 2021 10:35 am
It would be even better to have a "router stored" mode where winbox session files are stored on the router instead of the windows computer!
Of course in addition to what there is now. It would be an extra selection <router> in the select list for the session file in winbox.
CZFan
Tue Oct 05, 2021 3:16 pm
Icon???
Link!!! ???
rextended
Tue Oct 05, 2021 3:28 pm
link, not icon???
CZFan
Tue Oct 05, 2021 4:05 pm
link, not icon???
That will depend on you age I suppose :-)
kirost
Sat Dec 04, 2021 12:25 pm
@rextended
@kirost
"Move Session Folder..." function moves only the session folder, not the settings folder (which, by the way, contains the file with the path to the sessions folder named "sessionpath"
Default session path
C:\Users\USER\AppData\Roaming\Mikrotik\Winbox\sessions\
and it is inside the settings folder
After using "Move Session Folder..." folders look like this:
the session folder is (for example):
D:\rextended_dont_understand_topic\
the settings folder remains the same
Now, i use dirty trick (костыль) for fix this:
C:\Windows\system32>mklink /D c:\Users\USER U:\Users\USER
символическая ссылка создана для c:\Users\USER <<===>> U:\Users\USER
Sob
Sat Dec 04, 2021 3:24 pm
HKCU\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\Shell Folders\AppData in registry is where WinBox takes the path from. How much correct or wrong it is, I can't say.
kirost
Sat Dec 04, 2021 10:09 pm
Thanks, Sob!
It's really solve this problem.
Users browsing this forum: GoogleOther [Bot], kormenator and 186 guests
