stollerxd
PTP BETWEEN LHG5 AND DYNADISH 5
Mon Oct 04, 2021 4:26 pm
Hi all,
I try to make PTP link between LHG5 and DYNADISH 5 but it doesn't working. Any advice to give me.
PS: I use Dynadish like bridge( ap bridge not working due to ROS license level) and lhg5 like station bridge.
pe1chl
Re: PTP BETWEEN LHG5 AND DYNADISH 5
Mon Oct 04, 2021 5:29 pm
It should work. Did you ever make a link before?
Check that the wireless settings on each end are compatible.
Rugx
Tue Oct 05, 2021 11:22 am
Does you station-bridge see the the bridge through wireless scan?
stollerxd
Tue Oct 05, 2021 7:44 pm
Hi thanks for reply.
Yes i've already make a link on past. Between two same antenna (LHG-LGH, QRT-QRT or QRT-QRT).
But never do it with different antenna
stollerxd
Tue Oct 05, 2021 7:46 pm
Sadly no.
pe1chl
Tue Oct 05, 2021 8:02 pm
Make sure you use the settings that were successful for you, but are compatible with both devices.
soulflyhigh
Wed Oct 06, 2021 7:47 pm
That should work just fine, could you post WLAN config's export from both devices?
The link is either misconfigured or there are some hardware-related issues.
Regards,
M.
stollerxd
Thu Oct 07, 2021 2:56 pm
Regards,
M.
MASTER CONFIG
interface wireless
set [ find default-name=wlan1 ] antenna-gain=0 band=5ghz-a/n country=no_country_set \
disabled=no frequency=5440 frequency-mode=superchannel mode=bridge radio-name=\
DYNADISH-MASTER scan-list=5400-5600 ssid=FAUCO0021 station-roaming=enabled \
wireless-protocol=802.11
SLAVE CONFIG
interface wireless
disabled=no frequency=5440 frequency-mode=superchannel mode=statiojn-bridge radio-name=\
LHG5-SLAVE scan-list=5400-5600 ssid=FAUCO0021 station-roaming=enabled \
Users browsing this forum: No registered users and 70 guests
