I have an older hAP ac lite US model. It is missing 'united states' from the country drop down list. There are only 2 choices available - 'canada2' and 'united states3'. 5GHz only has 5180 thru 5240 available, no upper band or DFS at all. 2.4 GHz seems fine. Upgrading to the latest firmware, 6.48.4 doesn't not add alternatve US or Canada options. I have seen multiple 'united states' options is hAP ac2's - 'united states', 'united states2', 'united states3'.
Is there a method to correct this situation? Has anyone else experienced this? It's it a limitation of the router itself? The 'factory firmware' in system > routerboard is 3.41 (2018-2019ish?).
Code: Select all
> system routerboard print
routerboard: yes
board-name: hAP ac lite
model: RB952Ui-5ac2nD
serial-number:
firmware-type: qca9531L
factory-firmware: 3.41
current-firmware: 6.48.4
upgrade-firmware: 6.48.4
