sequoia
RB260GSP (CSS106-1G-4P-1S) PoE-In Amperage Limit
Fri Oct 08, 2021 4:34 pm
Hello to everyone,
Based on https://help.mikrotik.com/docs/display/UM/RB260-series and on the comment
The maximum power output of each ethernet port in this mode is 1 A, total for all ports 2 A.
is it right to think that if I use PoE input to power the device, then I cannot have more than 1A to use for my PoE output ports?
If I power the device with a power adapter, I can understand the quote above, but I am not sure if the amperage limitation applies to the port in general (so input or output does not make any difference) or only when the port is used to supply a PD.
To sum up:
  • power adapter: max 2A
  • poe in : max 1A (without excluding the device itself)
Is that correct? :?
Thank you in advance.
ConnyMercier
Forum Veteran
Forum Veteran
Re: RB260GSP (CSS106-1G-4P-1S) PoE-In Amperage Limit
Fri Oct 08, 2021 10:10 pm
PoE-Output :
The Mikrotik RB260GSP as 4 Interface with PoE-Out (Ether2, Ether3, Ether4 and Ether5)
Every single of these Ethernet-Interface is able to deliver up to 1A
So for Exemple :
12V x 1A = up to 12 Watts per Port
24V x 1A = up to 24 Watts per Port
30V x 1A = up to 30 Watts per Port
Important Notice 1:
If you have more then two PoE-Interfaces active,
you will need to make sure, that you don't exceed 2A.
The 2A referrers to the combined PoE-Outputs (Ether2 thru Ether5)
Important Notice 2:
You can Power the Mikrotik RB260GSP via PoE and/or DC-Jack.
It make no difference for the Switch or the PoE-Outputs.
A. Just make sure the Voltage is the right one for all your devices.
B. Make sure your Power-Supply as enough amps (A) for everything.
For Exemple :
If you use a 24V / 2.5A Power-Supply
You will be able to power everything.
sequoia
Sat Oct 09, 2021 12:30 am
PoE-Output :
So for Exemple :
Important Notice 1:
Important Notice 2:
For Exemple :
Thank you for your reply ConnyMercier.
This comment above is the one I want to elaborate on.
So if I use a PoE injector with a power supply 24V / 2.5A to PoE-In interface, should that PoE-In interface deliver 2A in total for the other four Ethernet ports?
With power supplied from jack, I agree with all that you have mentioned. But I was wondering if the 1A limitation is also applied to PoE-In with that resulting in less Watt in total for my PDs. :oops:
ConnyMercier
Forum Veteran
Forum Veteran
Sat Oct 09, 2021 12:36 am
Jap , no difference between PoE and/or DC-Jack =)
ConnyMercier
Forum Veteran
Forum Veteran
Sat Oct 09, 2021 12:45 am
Just in Case you are new to PoE,
Network-Cable Quality and Length are important Factors with PoE
So , don't use a 100m Cable if you only need 2m
And if you do have long runs of cables (50m+), think of using the highest Voltage possible (like 28V instead of 24V).
sequoia
Sat Oct 09, 2021 10:16 pm
Hello ConnyMercier,
Thank you for your replies.
Well, we never get old when it has to do with technology. Despite that, I am familiar with the practices you mention and it is useful advice. :D
Users browsing this forum: No registered users and 40 guests
