David1234
unable to send mail using gmail (auth failed)?
Sun Oct 10, 2021 10:53 am
does someone know if Google\Gmail change something ?
I just notice I can't send E-mail in the last 2 months
I get
Error sending e-mail <test>: AUTH failed
and in the gmail it said "Critical security error "
what do I need to change and where ?
** the password is correct
/tool e-mail
set address=smtp.gmail.com from=Myroutertest12@gmail.com password=******** port=587 start-tls=yes user=Myroutertest12
Thanks ,
holvoetn
Re: unable to send mail using gmail (auth failed)?
Sun Oct 10, 2021 11:51 am
Have you enabled sending of email through less secure applications on your gmail account ?
https://myaccount.google.com/lesssecureapps
Be careful, this does NOT work if your Gmail account has 2-factor enabled.
I use a separate gmail account for this sending of mails 1) to keep it out of my primary account, 2) my primary account has 2-factor enabled.
Larsa
Sun Oct 10, 2021 12:49 pm
You can still use the 2-Step-Verification if you create a specific gmail app password. https://support.google.com/accounts/answer/185833?hl=en
holvoetn
Sun Oct 10, 2021 1:11 pm
Right ! Missed that one ... still keeping the accounts separate, though :)
David1234
Mon Oct 11, 2021 9:48 am
this is just a router gmail account for sending data
I didn't know I can make a
i will try it
Thanks ,
Users browsing this forum: 486dx, Ahrefs [Bot] and 42 guests
