jmginer
Help migrating filter rules from v6 to v7
Sun Oct 10, 2021 2:01 pm
I'm trying to migrate my BGP filters from v6 to v7.
The problem is that I can't find how to migrate the "match-chain" rule.
These are my current rules, I receive transit from a provider and offer transit to a customer:
/routing filter
# section 1 - Accept what my transit provider advertise me
add action=accept chain=MyTransitProvider-IN prefix=0.0.0.0/0
add action=accept chain=MyTransitProvider-IN prefix=::/0
# section 2 - Accept what my transit customer advertise me
add action=accept chain=MyTransitCustomer-IN match-chain=MyTransitCustomerAS set-bgp-local-pref=300 set-distance=10 comment="Accept MyTransitCustomer prefixes"
add action=discard chain=MyTransitCustomer-IN comment="No more from MyTransitCustomer"
add action=accept chain=MyTransitCustomer-OUT prefix=0.0.0.0/0 comment="Disabled to provide full routing" disabled=yes
add action=discard chain=MyTransitCustomer-OUT comment="Disabled to provide full routing" disabled=yes
# section 3 - I advertise my own prefixes and my transit customer prefixes to my transit provider
add action=accept chain=MyTransitProvider-OUT match-chain=MyOwnAS
add action=accept chain=MyTransitProvider-OUT match-chain=MyTransitCustomerAS
add action=discard chain=MyTransitProvider-OUT comment="Dont advertise more to MyTransitProvider"
# section 4 - Chains with my prefixes and my transit customer prefixes (like address list)
add action=accept prefix=1.0.0.0/8 prefix-length=0-32 chain=MyOwnAS
add action=accept prefix=2.0.0.0/8 prefix-length=0-32 chain=MyTransitCustomerAS
If someone is kind enough to help me with the migration I would appreciate it very much.
This is what I've tried, but I'm not sure if it's right? And as I say, I need help with sections 2 and 3 to use the match-chain rule.
/routing/filter/rule
# section 1
add chain=MyTransitProvider-IN rule="if (dst==0.0.0.0/0 && protocol static) { accept }"
add chain=MyTransitProvider-IN rule="if (dst==::/0 && protocol static) { accept }"
# section 2
help!
# section 3
help!
# section 4
add chain=MyOwnAS rule="if (dst-len>0 && dst-len<32 && dst in 1.0.0.0/8) { accept }"
add chain=MyTransitCustomerAS rule="if (dst-len>0 && dst-len<32 && dst in 2.0.0.0/8) { accept }"
Thank you very much in advance!
aleksis
Re: Help migrating filter rules from v6 to v7
Mon Oct 11, 2021 10:43 am
You can match chain like this:
add chain=MyTransitCustomer-IN rule="if (chain MyTransitCustomerAS) { set bgp-local-pref 300; set distance 10; accept; }"
jmginer
Mon Oct 11, 2021 6:08 pm
Discard rules doesn't work?
/routing filter rule add chain=DECIX-IN rule="discard"
failure: "[Word {discard}]" - unknown action name
In my opinion, the documentation out there is very poor regarding the radical change with filters in v7.
mrz
Mon Oct 11, 2021 6:24 pm
ROS v7 doesn't have "discard" action.
noahzhang
Thu Nov 25, 2021 7:37 am
so,I have the same problem.How to rewrite the above the filter in v7.Thx.
Nevon
Thu Nov 25, 2021 9:46 pm
How does Mikrotik think then?
We must help BGP-community to make sure that the wrong information does not come in or out. For example. I want to make sure I do not get my own prefixes from eBGP peers.
mrz
Thu Nov 25, 2021 10:21 pm
With "reject" action.
Nevon
Thu Nov 25, 2021 10:27 pm
what would such a thing look like? Would like to start testing ROS7 BGP
mrz
Thu Nov 25, 2021 11:43 pm
I am not really sure what you are asking, what "reject" would look like if you type it?
Here you can find detailed description on how to use routing filters:
https://help.mikrotik.com/docs/pages/vi ... d=74678285
Some basic stuff to start with as well:
https://help.mikrotik.com/docs/display/ ... g+Examples
Nevon
Fri Nov 26, 2021 8:41 am
If I want to reject subnet "X.X.X.X/24" for one example.
mrz
Fri Nov 26, 2021 10:06 am
if (dst == x.x.x.x/24) {reject}
Splash
Mon Dec 06, 2021 9:21 pm
Would anyone know what the syntax is to mark a route as unreachable based on a matcher.
I have used a basic bgp-communities as an example
example:
add action=accept bgp-communities=no-export chain=BGP-IN set-type=unreachable
becomes
if (bgp-communities equal no-export) {set xxxxxxx; accept}
gw only works with an IP
gw-interface only works with a interface
https://help.mikrotik.com/docs/pages/vi ... yOperators
I don't see an operator for type unreachable in V7...
*note in the docs "bgp-communites" is incorrectly spelt.
Splash
Mon Dec 06, 2021 9:23 pm
Also note that I tested the route filter conversion from V6 to V7 but it doesn't work even though it is marked as completed. The filters are removed from the V7 config after an upgrade.
https://help.mikrotik.com/docs/display/ ... ol+Status
Jotne
Mon Dec 06, 2021 10:06 pm
Start a new thread.
Users browsing this forum: No registered users and 28 guests
