to55603
WAP-R
Thu Oct 14, 2021 6:56 pm
I upgraded my LTE module. The status display shows that the Lte interface is running. How do I get it now that WiFi or Ethernet work or are connected to the Internet
anav
Re: WAP-R
Thu Oct 14, 2021 7:35 pm
Yu have to associate this with your DHCP client and WAN interface settings.
I dont use LTE so not sure.
The rest of the device works from default settings.................
Minor tweaking on wifi settings (SSID, security password etc..)
NEXT TIME CONTINUE WITH SAME ORIGINAL THREAD, I just noticed you already had one going.
For future reference. :-)
pOst your config
to55603
Re: WAP-R
Thu Oct 14, 2021 8:44 pm
How can you connect the DHCP client to the WLAN interface?
Thanks for the tip..
I will implement :D
to55603
Re: WAP-R
Thu Oct 14, 2021 8:57 pm
I now have orders
/ export hide-sensitive file = test
tried out. Where can I find the exported file?
anav
Re: WAP-R
Thu Oct 14, 2021 10:06 pm
I now have orders
Hi there there should be no spaces between file equal sign or test, thus: file=test
It will be found under FILES ;-)
to55603
Re: WAP-R
Fri Oct 15, 2021 8:52 am
Thank you for your prompt reply. The file is in the attachment :D
anav
Re: WAP-R
Fri Oct 15, 2021 4:15 pm
(1) Why do you have two IP addresses for WLAN1 (suggesting removing the one in red)
add address=192.168.88.1/24 comment=defconf interface=wlan1 network=\
192.168.88.0
add address=10.10.10.1/24 interface=wlan1 network=10.10.10.0
(2) Why do have have LAN setup that is also your WAN setup.
IS LTE your WAN connection or your LAN subnet. something is wrong here but since I dont understand LTE . :-( :-(
Can you draw a network diagram to show where internet is coming from and what your network looks like behind the mikrotik device?
Also state clearly what your expectations are for users or devices on your network.
[ so far I am guessing, is that you have an LTE capable router, that gets internet from a provider with a fixed private IP of 192.168.88.X, with gateway of 192.168.88.1]
But then you have no subnets for your own use no LAN?)
to55603
Re: WAP-R
Sat Oct 16, 2021 9:25 am
[1] Thank you, I deleted one address.
[2] I would like to access the Internet with the WAP-R using a SIM card. The router should then supply every connected device with the Internet via a LAN cable.
[3] How can I create a network diagram with Winbox? Unfortunately, I am not very familiar with Winbox.
holvoetn
Re: WAP-R
Sat Oct 16, 2021 10:08 am
Easiest is papier and pencil and a picture :lol:
to55603
Re: WAP-R
Mon Oct 18, 2021 12:48 pm
Hi there,
the functionality should look like this:
tdw
Re: WAP-R
Mon Oct 18, 2021 2:24 pm
The configuration appears to be the default for a standard wAP with ether1 as the WAN and wlan1 as the LAN. I don't know if a reset to factory defaults would use a different configuration with the LTE modem being present, otherwise a few changes are needed:
add name=bridge
add bridge=bridge interface=ether1
add bridge=bridge interface=wlan1
add address-pool=dhcp disabled=no interface=wlan1bridge name=defconf
/interface detect-internet
set detect-interface-list=WANnone internet-interface-list=allnone lan-interface-list=LANnone wan-interface-list=allnone
add comment=defconf interface=wlan1bridge list=LAN
add comment=defconf interface=ether1lte1 list=WAN
add list=LAN
add address=192.168.88.1/24 comment=defconf interface=wlan1bridge network=192.168.88.0
add distance=1 gateway=192.168.88.1
When adding the bridge and bridge interfaces your Winbox session may get disconnected unless using a MAC rather than IP connection.
Also IIRC if you also need a DHCP client adding to acquire an address (as using passthough on a device here) which would be
/ip dhcp-client
add default-route-distance=1 disabled=no interface=lte1
holvoetn
Re: WAP-R
Mon Oct 18, 2021 2:30 pm
(EDIT: already someone replied before me ... same lines of thinking)
The config you posted before, is that the default config of the device ?
The LTE + SIM card, is that your lte interface on your Mikrotik ?
I will also assume that you want to have AND Ethernet-clients AND wlan-clients as being part of LAN (= internal = 192.168.88.0/24 range).
Correct ?
Put eth1 on the LAN list, not WAN. Put lte-itf as WAN. Do this first and make sure to use Safe Mode when making this change since it can block your access if done wrong.
Your DHCP server is currently only serving wlan1 and I don't see a bridge where eth1 can be part of. If you add a bridge and put eth1 and wlan1 as part of that, change dhpc-server to bridge (which you will have to do anyhow since wlan1 will become a slave if you add it to the bridge)
I don't see a default route towards lte (and that definitely should be there): add route to 0.0.0.0/0, interface lte, distance 10 (I prefer to have the default path a bit out of the way, experts may disagree with that one)
I think that's the major part to have it working. Others will surely chime in.
to55603
Re: WAP-R
Mon Oct 18, 2021 4:57 pm
To be honest, I'm still a little overwhelmed with the steps ..
At first I tried to implement the points mentioned below. Pictures in the attachment
Unfortunately, I don't know exactly how to implement these points: :?
I don't see a default route towards lte (and that definitely should be there): add route to 0.0.0.0/0, interface lte, distance 10[/flash][/flash] (I prefer to have the default path a bit out of the way, experts may disagree with that one)
anav
Re: WAP-R
Post your lastest config !!
holvoetn
Re: WAP-R
Mon Oct 18, 2021 5:05 pm
As Anav said (without the exclamation marks :) )
On your lasts screenshots, the one for DHCP server: remove the line in red with defconf. It is invalid now because wlan1 is part of the bridge.
You can not run a DHCP server on a slave interface.
And then provide your export again please.
to55603
Re: WAP-R
Mon Oct 18, 2021 7:02 pm
Thanks for the help
Attached the file
Unfortunately, I currently have the problem that the device sometimes does not want to connect to the PC :(
anav
Re: WAP-R
Mon Oct 18, 2021 7:15 pm
I didnt mean literally the file should be called anynameyouwish, I meant that you could use any name you desired for the file LOL
anav
Re: WAP-R
Mon Oct 18, 2021 7:20 pm
(1) Lets tidy this up.../interface list member
add comment=defconf interface=wlan1 list=LAN
add list=LAN
add interface=ether1 list=LAN
add interface=lte1 list=WAN..
TO
add interface=eplus list=WAN {just to be sure we are capturing all possibilities as not familiar with LTE}
(2) From
192.168.88.0
TO
192.168.88.0
(3) Did you enter this IP route and if so why?? Typically we dont route to the gateway of the LAN but to the gateway of the WAN??
Typically under either DHCP client or I suspect in your Case LTE client settings there is a selection for ADD DEFAULT ROUTE YES NO.
to55603
Re: WAP-R
Mon Oct 18, 2021 7:46 pm
[1] Unfortunately I had problems with this point .. Picture in the attachment
The rest has worked so far. This time I even changed the name of the file: D
Do I have to add anything under the DHCP client?
anav
Re: WAP-R
Mon Oct 18, 2021 7:49 pm
I am not sure you need to frig with DHCP client, if you already have LTE client settings as a separate entity.
if you do need dhcp client then the interface would be the LTE one NOT the wifi one.
holvoetn
Re: WAP-R
Mon Oct 18, 2021 8:24 pm
No, it's not needed.
IP address should be provided through LTE interface.
Default route as well.
Interface for eplus is not needed either. Has nothing to do with Mikrotik interfaces.
Extract from my lte interface with a crucial part missing in red:
/interface lte apn
set [ find default=yes ] add-default-route=yes apn=xyz authentication=none \
default-route-distance=5 ip-type=ipv4 name=default use-network-apn=yes \
use-peer-dns=yes
You can find it here: Winbox - Interfaces - LTE - button LTE APN
holvoetn
Re: WAP-R
Mon Oct 18, 2021 8:26 pm
Why not ? It's a name like any other.
Or would you prefer "becauseanavsaidso" ? :lol:
to55603
Re: WAP-R
Mon Oct 18, 2021 8:40 pm
Thank you holvoetn ..
The box was already selected :)
Unfortunately I still have no internet :(
holvoetn
Re: WAP-R
Mon Oct 18, 2021 8:49 pm
Did you reboot your device after all these changes ?
If that box was already ticked AND we still don't see a default address coupled to lte interface something is wrong.
Before you do:
Winbox - Files
Backup
"anynameyouwish" :lol: - don't encrypt (you can take care of that later if you want)
After creation, move that file to the flash part. That's the only way to have it survive a reboot (or move to disk, not all Mikrotik devices have that possibility)
Then reboot.
Other comment:
I do see you're still on an older version of ROS but that should not be a factor here.
For me authentication is set to NONE. I see you have PAP ? Can you also try to change that ?
anav
Re: WAP-R
Mon Oct 18, 2021 8:52 pm
I prefer........... holvoshoulddriveavolvo
holvoetn
Re: WAP-R
Mon Oct 18, 2021 8:53 pm
Used to drive Audi. Now a Jag (never again. Other story ...).
Let's stay on topic here !!
holvoetn
Re: WAP-R
Mon Oct 18, 2021 8:56 pm
@to55603
can you also provide screenshots of LTE interface - status and LTE interface - cellular ?
holvoetn
Re: WAP-R
Mon Oct 18, 2021 9:01 pm
Drop the authentication comment.
It seems it has to be PAP for eplus. Just checked on their site.
anav
Re: WAP-R
Mon Oct 18, 2021 9:10 pm
and do include my suggestion
add interface=eplus list=WAN wont hurt if wrong will help immensely if right!!!
to55603
Re: WAP-R
Mon Oct 18, 2021 9:16 pm
Did I forget any screenshots? Otherwise, just tell me on which page I should take screenshots or how I can get there :?
anav
Re: WAP-R
Mon Oct 18, 2021 9:57 pm
Step 1.
Clean up config remove the part in red and add blue
add list=LAN
192.168.88.0
192.168.88
FOR NOW Disable this rule, to ensure nothing is getting blocked.
/interface wireless access-list
add mac-address=CC:2F:71:A2:22:95
Finally try setting this to NONE for all.........,
set detect-interface-list=WAN internet-interface-list=all lan-interface-list=\
LAN wan-interface-list=all
ALSO where are these coming from?? Delete them......
Remove the static IP dns setting and not sure why you have some obscure dns server there so replace 159.... with 1.1.1.1 or 9.9.9.9
set allow-remote-requests=yes servers=159.148.60.2
/ip dns static
to55603
Re: WAP-R
Mon Oct 18, 2021 10:46 pm
[1] At the first point I could not select the interface eplus. See Appendix
[2] With this part I unfortunately don't know where and how to do it;
Remove the static IP dns setting and not sure why you have some obscure dns server there so replace 159 .... with 1.1.1.1 or 9.9.9.9
/ ip dns
set allow-remote-requests = yes servers = 159.148.60.2
/ ip dns static
add address = 192.168.88.1 comment = defconf name = router.lan
anav
Re: WAP-R
Mon Oct 18, 2021 10:56 pm
Okay understand about eplus!
You need to go to IP DNS settings. Check Green rectangle...........
At the top you should see servers, and this is where I assume the 159 came in there, seems to be the fact that you stated use peer DNS, which is fine so that is why that is there,
do not remove it. You can add 1.1.1.1 for example as well.
To reach that static IP dns setting select the tag stating Static in Orange rectangle and then delete the entry.
holvoetn
Re: WAP-R
Mon Oct 18, 2021 11:04 pm
Maybe basics first...
Does that SIM card work in another device ?
Because it should give an IP address on successful connection and I do not see it coming.
to55603
Re: WAP-R
Tue Oct 19, 2021 9:03 am
@anav
I implemented your tips. Many thanks for your help. I deleted the entry within the IP dns settings
@holvoetn
The SIM card was already running in another router. There were no problems with this :(
holvoetn
Re: WAP-R
Tue Oct 19, 2021 9:49 am
I still find it mighty strange there is no IP address for the lte interface, no default route, nada ...
From terminal, what does this give ?
/interface lte print
and
/interface lte info lte1 once
There is also no DHCP client. But it shouldn't be, that should come automatically.
However ... can you try this ?
/ip dhcp-client
add default-route-distance=5 disabled=no interface=lte1
And then /ip address print
to55603
Re: WAP-R
Tue Oct 19, 2021 10:50 am
These were the results:
holvoetn
Re: WAP-R
Tue Oct 19, 2021 11:50 am
Aha !
An IP address on LTE1 interface !!
What does /ip route show now ?
to55603
Re: WAP-R
Tue Oct 19, 2021 12:01 pm
This is now displayed
holvoetn
Re: WAP-R
Tue Oct 19, 2021 12:03 pm
Now we're talking !
You have a PC connected to LAN ? Does it get an IP address from WAP-R ?
Can it access internet ?
to55603
Re: WAP-R
Tue Oct 19, 2021 12:12 pm
I have now connected the device to the PC via LAN. IP Config in the appendix. Unfortunately the PC indicates that the network cannot be identified
holvoetn
Re: WAP-R
Tue Oct 19, 2021 12:13 pm
Other remark:
from that lte info lte1 once dump I see you're still on firmware V015.
Could be there is already a newer firmware available.
Check if new firmware is available for your device
/interface lte firmware-upgrade lte1
If so:
/interface lte firmware-upgrade lte1 upgrade=yes
And after success: reboot or /interface lte at-chat lte1 input="AT+reset"
holvoetn
Re: WAP-R
Can you export your latest config again please ?
We're getting close.
to55603
Re: WAP-R
Tue Oct 19, 2021 12:24 pm
The software should now be up to date ...
holvoetn
Re: WAP-R
Tue Oct 19, 2021 12:49 pm
Strange, DHCP client on lte-interface is gone again ??
You did a reboot after the firmware upgrade ?
That DHPC setting has clearly not been saved ... hmmm ...
First reaction would be to do again:
/ip dhcp-client
See if IP address comes in on lte1 itf with /ip address
And something else: any reason why you're still on 6.46 for RouterOS ? That's a rather old version. If it works, ok, no reason to change but ... it might be needed HOWEVER the latest stable version seems to exhibit some boot-problems on some devices so I am hesitant to steer you into that direction. Let's try without upgrade first.
What version of Winbox are you using ?
Because I find it strange that the DHCP setting part does show in your Winbox screenshot but it's NOT visible in the export and you still need to set the DHCP-client manually.
Something else I am missing is the definition of your Ethernet interface... but how can it be connected to the bridge then ??
Is the eth1 interface visible in Winbox ? How is it setup ?
Are device able to connect through wifi ? Do they get an IP address from the router ?
Another thing:
ip dns set allow-remote-requests=yes -> Set to no !
to55603
Re: WAP-R
Tue Oct 19, 2021 1:26 pm
Yes, I restarted the system again. I also tried again, but he seems to have a problem with the command add default-route-distance = 5 disabled = no interface = lte1 .. :(
Regarding the router version: I have not yet updated the router because I had problems with it at the beginning. That is why the original version is still on the device
I am currently using version 3.31 of Winbox
The problem with using the WAP-R later is that it is not connected directly to a PC. It is supposed to connect a circuit board to the Internet, with which a solar system can track the sun. Accordingly, it is best to only connect an Ethernet cable to the circuit board and to automatically assign the Internet via LAN
anav
Re: WAP-R
Tue Oct 19, 2021 2:09 pm
What confuses me is that the lTE seems to have a 10. xx address, the LAN is on 192.168.x.x
BUt the PC gets 169.254 ???
Regardless of the WAN situation the PC should simply get a proper LANIP from the router???
anav
Re: WAP-R
Tue Oct 19, 2021 2:13 pm
Ensure DNS setting is entered on this line.
Should look like
add address=192.168.88.0/24 dns-server=192.168.88.1 gateway=192.168.88.1
Also this is an interface, so
try to add either lte apn to the wan interface as a member and eplus
/interface lte apn
set [ find default=yes ] apn=internet.eplus.de authentication=pap name=eplus \
user=eplus
Can either be added below as a WAN member ( I know you tried eplus before but give it another stab and if not then try lte apn!!
holvoetn
Re: WAP-R
Tue Oct 19, 2021 2:14 pm
@to55603
Your last statement I sort of disagree. I also have a solar panel tracking system at home and it's nicely connected to my Wifi-network.
Just had to make sure to give it a fixed IP to be sure, that's all (open dynamic lease and make it static, as easy as that).
But could be your tracking system does not like Wifi that much (in 2021 ??) :)
Just realised (stupid me...): export does not show dynamic values.
Don't make screenshots, just copy-paste the output between [ code ] and [ / code] (without the spaces), much easier.
/interface ethernet print
/interface bridge port print
/ip address print
/ip route print
/ip dhcp-server lease print
The last screenshot you provided (ipconfig from PC) shows Drahtlos = WIRELESS (I understand a bit of German) ? But you said you were going to use a cable ?
It should not make a difference since wlan1 should also be connected to the bridge (which we will verify from the print-statements but from your Interface screenshot I see both eth1 and wlan1 with S for slave, so I think it's ok).
Therefor the DHCP-server for that bridge should hand out an IP address.
holvoetn
Re: WAP-R
Tue Oct 19, 2021 2:16 pm
Makes perfect sense if the PC does not get a DHCP lease.
Then Windows will default to 169.254 range.
That's the problem which needs to be addressed now.
And the IP address for lte will most likely be a CGNAT address from the carrier.
holvoetn
Re: WAP-R
Tue Oct 19, 2021 2:22 pm
/interface lte apn
user=eplus
Doesn't work that way :)
The interface is called lte1 and it is included in the WAN list (it's visible in his latest export).
to55603
Re: WAP-R
Tue Oct 19, 2021 6:20 pm
That's the result: :roll:
[admin@MikroTik] > /interface ethernet print
Flags: X - disabled, R - running, S - slave
# NAME MTU MAC-ADDRESS ARP SWITCH
0 RS ether1 1500 B8:69:F4:6A:3B:96 enabled switch1
[admin@MikroTik] > /interface bridge port print
Flags: X - disabled, I - inactive, D - dynamic, H - hw-offload
# INTERFACE BRIDGE HW PVID PRIORITY PATH-COST INTERNAL-PATH-COST HORIZON
0 H ether1 bridge yes 1 0x80 10 10 none
1 wlan1 bridge 1 0x80 10 10 none
[admin@MikroTik] > /ip address print
# ADDRESS NETWORK INTERFACE
0 ;;; defconf
192.168.88.1/24 192.168.88.0 bridge
1 D 10.128.157.147/32 10.128.157.147 lte1
[admin@MikroTik] > /ip route print
Flags: X - disabled, A - active, D - dynamic, C - connect, S - static, r - rip, b - bgp, o - ospf, m - mme, B - blackhole, U - unreachable, P - prohibit
# DST-ADDRESS PREF-SRC GATEWAY DISTANCE
0 ADS 0.0.0.0/0 lte1 2
1 ADC 10.128.157.147/32 10.128.157.147 lte1 0
2 ADC 192.168.88.0/24 192.168.88.1 bridge 0
[admin@MikroTik] > /ip dhcp-server lease print
Flags: X - disabled, R - radius, D - dynamic, B - blocked
# ADDRESS MAC-ADDRESS HOST-NAME SERVER RATE-LIMIT STATUS LAST-SEEN
to55603
Re: WAP-R
Tue Oct 19, 2021 6:23 pm
Unfortunately, this is the only solution for the circuit board ...
I am connected to the router via wifi, otherwise I cannot control it via Winbox. Or am I wrong?
holvoetn
Re: WAP-R
Tue Oct 19, 2021 6:36 pm
No problem. I assume you will have looked into your options.
Also here, no problem but I still don't get why your PC is not getting an IP lease. Are you connecting via Winbox and MAC-address ?
The circuit board is already connected via Ethernet ? It does not seem to get a lease either if it is.
to55603
Re: WAP-R
Tue Oct 19, 2021 6:40 pm
No, not yet. The circuit board is permanently installed and I didn't want to remove the circuit board separately. Can I configure the whole system without the circuit board?
holvoetn
Re: WAP-R
Tue Oct 19, 2021 6:44 pm
Sure you can do it without the circuit board connected. It was just a question to be sure the ethernet client does not get a lease either.
Just for testing, can you confirm connecting your PC to the ethernet port ? It should NOT get a DHCP lease (nothing in the 192.168 range).
If it does, something might be wrong with the wifi-settings on your PC.
holvoetn
Re: WAP-R
Tue Oct 19, 2021 6:51 pm
Oh and please:
Set to no !
to55603
Re: WAP-R
Tue Oct 19, 2021 7:05 pm
That's all :)
Hopefully I have now sent the correct part for the ethernet connection
[admin@MikroTik] > /ip dns
[admin@MikroTik] /ip dns> set allow-remote-requests=no
[admin@MikroTik] /ip dns> print
servers: 159.148.60.2,1.1.1.1
dynamic-servers: 62.109.121.17,62.109.121.18
allow-remote-requests: no
max-udp-packet-size: 4096
query-server-timeout: 2s
query-total-timeout: 10s
max-concurrent-queries: 100
max-concurrent-tcp-sessions: 20
cache-size: 2048KiB
cache-max-ttl: 1w
cache-used: 21KiB
holvoetn
Re: WAP-R
Tue Oct 19, 2021 7:50 pm
/interface bridge print
please ?
I am comparing your latest export with my config and your bridge looks REALLY simple.
Too simple.
Your config:
/interface bridge add name=bridge
Mine (I removed MAC address):
add admin-mac=XX:XX:XX:XX:XX:XX ageing-time=5m arp=enabled arp-timeout=auto \
auto-mac=no comment=defconf dhcp-snooping=no disabled=no fast-forward=yes \
forward-delay=15s igmp-snooping=no max-message-age=20s mtu=auto name=\
bridge priority=0x8000 protocol-mode=rstp transmit-hold-count=6 \
vlan-filtering=no
Seems to be odd AND DHCP-client AND default bridge settings are missing on that device.
You may want to consider upgrading RouterOS later on.
to55603
Re: WAP-R
Tue Oct 19, 2021 8:10 pm
I have now updated the router to 6.49. Hope it's the correct stable version. Definitely looks better now
[admin@MikroTik] > /interface bridge add name=bridge
failure: already have interface with such name
[admin@MikroTik] /interface bridge> print
0 R name="bridge" mtu=auto actual-mtu=1500 l2mtu=1598 arp=enabled arp-timeout=auto mac-address=XX:XX:XX:XX:XX:XX protocol-mode=rstp fast-forward=yes igmp-snooping=no auto-mac=yes ageing-time=5m priority=0x8000 max-message-age=20s forward-delay=15s
transmit-hold-count=6 vlan-filtering=no dhcp-snooping=no
holvoetn
Re: WAP-R
Tue Oct 19, 2021 8:51 pm
I hope you changed that MAC address yourself and it was not set like that ?
Still no IP address on PC ?
to55603
Re: WAP-R
Tue Oct 19, 2021 8:55 pm
Haha no
I changed the IP address myself
to55603
Re: WAP-R
Tue Oct 19, 2021 8:58 pm
Unidentified network :(
holvoetn
Re: WAP-R
Tue Oct 19, 2021 9:15 pm
There has to be something rather stupid preventing DHCP from handing out IP leases ...
It's the only thing missing.
to55603
Re: WAP-R
Tue Oct 19, 2021 9:20 pm
Hmmm. Do you have any idea?
anav
Re: WAP-R
Tue Oct 19, 2021 10:02 pm
Yes the R in the title means both Holvo and I are Retar...... for not figuring this out. :-(
to55603
Re: WAP-R
Tue Oct 19, 2021 10:05 pm
Okok, how should I proceed now? Is there any solution to the problem at all :(
holvoetn
Re: WAP-R
Tue Oct 19, 2021 10:10 pm
Final export with all latest settings please.
/export verbose hide-sensitive file=youknowthedrill
to55603
Re: WAP-R
Tue Oct 19, 2021 10:13 pm
Ok, here it is:
holvoetn
Re: WAP-R
Tue Oct 19, 2021 10:32 pm
Wild idea (it has caused me some troubles already in the past as well, it just popped in):
what is the current time on your device ? How off is it from the real time ?
Because I do not see any setting on your device which would sync time with whatever.
And if the time difference is too much, I have seen clients reject DHCP leases and the other way around, DHCP server rejecting DHCP-requests.
On every device I have (Mikrotik, NAS, printer, PC, whatever) it's usually one of the first things I configure to get the time right.
Just to try:
/system ntp client
set enabled=yes
/system ntp client servers
add address=94.224.67.24
(IP address is for be.pool.ntp.org. You're in the same timezone as me if you're in Germany so don't worry)
Can you also provide the last 20-30 lines of log:
/log print (just enter til it's finished, then copy the last 20 or so lines)
holvoetn
Re: WAP-R
Tue Oct 19, 2021 10:36 pm
BTW LOOOVE the way you simply copy-paste the names for the exports :lol:
to55603
Re: WAP-R
Tue Oct 19, 2021 10:37 pm
Unfortunately, I had problems with the second command...
[admin@MikroTik] /system ntp client> /system ntp client servers
bad command name servers (line 1 column 20)
[admin@MikroTik] /system ntp client> add address=94.224.67.24
bad command name add (line 1 column 1)
[admin@MikroTik] /system ntp client> print
enabled: yes
primary-ntp: 0.0.0.0
secondary-ntp: 0.0.0.0
server-dns-names:
mode: broadcast
[admin@MikroTik] > /log print
19:04:00 system,error,critical router was rebooted without proper shutdown
19:04:02 bridge,info "bridge" mac address changed to B8:69:F4:6A:3B:97
19:04:07 wireless,info CC:2F:71:A2:22:95@wlan1: connected, signal strength -55
19:04:09 bridge,info hardware offloading activated on bridge "bridge" ports: ether1
19:04:12 interface,info ether1 link up (speed 10M, full duplex)
19:04:14 interface,info ether1 link down
19:04:15 interface,info ether1 link up (speed 100M, full duplex)
19:04:24 lte,info lte1: registered home
19:04:25 interface,info lte1 link up
19:04:25 interface,info lte1 detect UNKNOWN
19:04:31 interface,info lte1 detect WAN
19:04:31 system,info,account user admin logged in from 54:E1:AD:74:CD:D9 via winbox
19:07:13 system,info package channel changed by admin
19:07:15 system,info package channel changed by admin
19:07:37 system,info,account user admin logged in via local
19:09:02 wireless,info CC:2F:71:A2:22:95@wlan1: disconnected, received deauth: unspecified (1), signal strength -53
21:12:09 wireless,info CC:2F:71:A2:22:95@wlan1: connected, signal strength -48
21:12:13 system,info,account user admin logged out from 54:E1:AD:74:CD:D9 via winbox
21:12:13 system,info,account user admin logged out via local
21:12:32 system,info,account user admin logged in from 54:E1:AD:74:CD:D9 via winbox
21:12:33 system,info,account user admin logged in via local
21:13:05 wireless,info CC:2F:71:A2:22:95@wlan1: disconnected, received deauth: unspecified (1), signal strength -48
21:13:06 system,info,account user admin logged out from 54:E1:AD:74:CD:D9 via winbox
21:13:06 system,info,account user admin logged out via local
21:33:35 wireless,info CC:2F:71:A2:22:95@wlan1: connected, signal strength -54
21:34:01 system,info,account user admin logged in from 54:E1:AD:74:CD:D9 via winbox
21:34:02 system,info,account user admin logged in via local
21:34:20 system,info SNTP client configuration changed by admin
to55603
Re: WAP-R
Tue Oct 19, 2021 10:38 pm
Haha in Germany we say: The engineer is lazy :D
holvoetn
Re: WAP-R
Tue Oct 19, 2021 10:39 pm
DHCP-client seems to be missing again on lte1 interface ?
Can you check /ip addresses print ?
sindy
Re: WAP-R
Tue Oct 19, 2021 10:41 pm
In the last export, there is disabled=yes on the /ip dhcp-server row. Change that to disable=no.
And do not attempt to attach a dhcp client to the LTE interface, it is not necessary.
sindy
Re: WAP-R
Tue Oct 19, 2021 10:43 pm
Also, under /interface detect-internet, set all the lists to none. That feature only causes headache.
holvoetn
Re: WAP-R
Tue Oct 19, 2021 10:45 pm
Good catch on the DHCP-server !
Re: dhcp-client:
I do agree it is not needed normally (it's not needed on my SXT LTE device) but there are LTE devices where it has to be done.
And from what I read left and right, WAP-R is one of them for some reason.
Before the upgrade, we could only get the external internet working after adding DHCP-client.
Could be this is not needed anymore after upgrade to 6.49.
to55603
Re: WAP-R
Tue Oct 19, 2021 10:52 pm
How do I set / interfaceDetect-Internet to none?
And how do I change / ip dhcp-server to disable = no?
Unfortunately, Winbox is difficult to understand ...
holvoetn
Re: WAP-R
Tue Oct 19, 2021 10:58 pm
1) Winbox - interfaces - there is a button "detect Internet". Open it and set everything to none.
2) Winbox - IP - DHCP-server - tab DHCP. Most likely there is a grayed line. Select it and make it active (blue tick mark on top)
anav
Re: WAP-R
Tue Oct 19, 2021 11:20 pm
Or
to55603
Re: WAP-R  [SOLVED]
Wed Oct 20, 2021 6:07 pm
I've tried it again now. I finally have internet through the device. Thank you so much both of you
holvoetn
Re: WAP-R
Wed Oct 20, 2021 7:39 pm
Yeah !!
<High Five to anav and sindy!>
anav
Re: WAP-R
Wed Oct 20, 2021 8:04 pm
So what was the key, something previous before dhcp server was turned off, or the removal of detect internet
Users browsing this forum: ejaka2s and 104 guests
