sitnikov
rancid script stop collecting config after upgrade to 6.49
Fri Oct 15, 2021 12:08 pm
rancid (expect) debug (before 6.49)
send: sending "system package print detail without-paging\r" to { exp5 }
expect: does "system package print detail without-paging\r\n"
rancid (expect) debug (after 6.49)
expect: does "[rancid@sihome-mt] > s\u001b[Ky\r[rancid@sihome-mt] > sy\u001b[Ks\r[rancid@sihome-mt] > sys\u001b[Kt\r[rancid@sihome-mt] > syst\u001b[Ke\r[rancid@sihome-mt] > syste\u001b[Km\r[rancid@sihome-mt] > system\u001b[K \r[rancid@sihome-mt] > .....
rextended
Re: rancid script stop collecting config after upgrade to 6.49
Fri Oct 15, 2021 12:29 pm
Rancid is not a MikroTik product.
Ask the authors of Rancid.
sitnikov
Fri Oct 15, 2021 12:33 pm
Rancid is not a MiroTik product.
yes, but rancid only get response from mikrotik and output from router look curiously. pls check my post carefully, thanks.
rextended
Fri Oct 15, 2021 12:35 pm
Like all software on the world, MikroTik can change something on his product, and are the other software producers than must align his own product.
Your post is confusing, and I don't understand anything about it.
It assumes someone uses Rancid and knows what you're talking about.
You must ask the question in an intelligent and intelligible way by those who must not use Rancid to know what you are talking about.
sitnikov
Fri Oct 15, 2021 12:41 pm
check and compare "send: sending" and "expect: does" for both version
"send: sending" - command was send over ssh connection
"expect: does" - response received from router
andrey0001
Wed Oct 27, 2021 3:04 am
Of course MikroTik can(even must) change something on his product.
We just wanna know what changed - nothing in CHANGELOG about it.
Knowledge will help us to understand how to solve the issue.
Might be enough to do some small changes in mrancid - thats all.
But you, instead to help us, silencing everyone about the problem.
rejecting, offer - that is the point.
There is no other convenient product for saving backup versions.
sitnikov
Thu Oct 28, 2021 6:10 pm
in my opinion the problem is described sufficiently ... for delevopers not for plain users
You have just subscribed to write your own ***what***?
I do not silenced anyone, also because I'm only an user, not an administrator or moderator.
I only ask the OP to write the question "in an intelligent and intelligible way by those who must not use Rancid to know what you are talking about".
If the OP can not do that, are only OP's problems,
and also you do not add absolutly nothing of value, only sht.
0LlVE
Mon Nov 01, 2021 11:36 pm
Hi
the solution : add +cte to the username in the login config.
something like that :
add user * rancid+cte
hansel84
Wed Nov 03, 2021 9:18 am
I'm also having the exact same issue with Rancid after updating to 6.49
hansel84
Wed Nov 03, 2021 10:54 pm
Hi
Thanks a lot .. it works!
lpvl
Tue Nov 16, 2021 4:40 pm
This does work indeed, could you point us to documentation describing why this is needed ? I do not see it explained in the docs on the dev's site.
I found the options after the username on https://help.mikrotik.com/docs/display/ ... +Interface, however we have used this for years without the +cte and there is no mention in the changelogs on 6.49 that this may have changed.
Thank you.
Hi
ashmash
Wed Nov 17, 2021 9:52 am
Users browsing this forum: Bing [Bot], GoogleOther [Bot], UkRainUa and 46 guests
