richard_s
CRS328-4C-20S-4S+RM question
Sun Oct 17, 2021 1:09 pm
Hello all. Is it possible to run this router directly from a 24v (preferred) or 48v DC supply? I want to use it on an off grid location powered by solar panels.
Many thanks
Richard
ConnyMercier
Forum Veteran
Forum Veteran
Re: CRS328-4C-20S-4S+RM question
Sun Oct 17, 2021 2:08 pm
electrically speaking, the answer is Yes..
I don't thing Rackmount Devices have a wide Voltage-Ranges ,
So mesure the build-In Power-Supply to see what Voltage and Amps the Board wants...
--- Warnings ---
including but not limited to :)
- You will VOID any Mikrotik-Support / Garanties
- Voltage from Batteries, Solar-Panel or Main's can be hazardous (
- Any voltage fluctuation may translate to Performace degradation
- Any voltage or power fluctuation may also result in RouterOS crashes or Errors
- Don't forget to provide an adequate Battery Protection Circuit (over-discharge protection)
richard_s
Sun Oct 17, 2021 2:38 pm
Thanks ConnyMercier I have had a quick look at the PSU and the electrolytic capacitors are 35v rated which suggests the output voltage will be 24v. I will get it on the bench tomorrow and check voltage with meter. As to batteries panels etc I am a qualified electrician. But thanks for your warnings they might be of use to others.
Richard
ConnyMercier
Forum Veteran
Forum Veteran
Sun Oct 17, 2021 3:06 pm
Ahh, qualified electrician meaning "Man wo plays with electricity and asn't killed ihmself yet!"
:lol: :lol:
i am looking forward to seeing the results of your experiment!
Especially power savings!!
If i would be a betting man,
I would expect ~12% less then via Power-Inverter
richard_s
Sun Oct 17, 2021 3:11 pm
Nope Connie qualified = taken the courses and passed them. As to mains power there is none nearby. Semi jungle area in Panama. Local houses solar powered.
ConnyMercier
Forum Veteran
Forum Veteran
Sun Oct 17, 2021 3:14 pm
Sorry Richard,
thought it was clear, It was only a Joke !
Greating from a German colleague
richard_s
Sun Oct 17, 2021 3:18 pm
LOL missed the joke I was up late last night and I am a bit tired 6 hours difference in UK and Panama time. I have the challenge of designing an off grid fiber network for a new eco village all off grid. Hence no local power.
ConnyMercier
Forum Veteran
Forum Veteran
Sun Oct 17, 2021 3:28 pm
That sounds like a very cool and fun Project!
What kind of availability does your network need to Provide, 90% ?
richard_s
Sun Oct 17, 2021 3:34 pm
Aiming for 99.99% using 2 unconnected routes for fallover. My friend is over there collecting info for me, Then he will oversee the network build.
ConnyMercier
Forum Veteran
Forum Veteran
Sun Oct 17, 2021 3:49 pm
99.99% is a very respectable goal for a Offgrid-Solution!
i wish you the best of luck and if you need more help, i'll be glad to assist
richard_s
Sun Oct 17, 2021 3:57 pm
Cheers
Users browsing this forum: ShindigNZ and 84 guests
