Hey all,
Ever since I have set up my MikroTik HexS router for home use - I have been getting WAN link drops. Sometimes happens once a day, sometimes once every other day, sometimes multiple times in a day.
If I check the log in the HexS, it says:
WANPORT link down
dhcp-client on WANPORT lost IP address xx.xx.xx.xx - lease stopped locally
I then go unplug the ethernet cable from the WANPORT and plug it back in and link is restored.
The log then says:
WANPORT link up (speed 1G, full duplex)
dhcp-client on WANPORT got IP address 135.23.174.167dhcp-client on WANPORT got IP address xx.xx.xx.xx
Easy layout - cable modem > cat6a > router. I had a tech from the ISP out to move the modem to the main incoming cable jack and he showed me all his fancy numbers on his diag tool for the modem. All looked solid. There doesn't seem to be a problem with the modem. The HexS is on v6.49 now. All equipment including new cat6a cables are <3mo old.
Any ideas?
