patintexas
use security profile on another router
Wed Oct 20, 2021 2:06 am
I looked everywhere I could think of but didn't find anything close to what I am hoping is possible.
I have a core router configured thusly:
All routers are running 6.49
ether1 = WAN
ether2 = 192.168.11.0/24 connected to RB951Ui-2HnD
ether3 = 192.168.88.0/24 connected to RB951Ui-2HnD
wlan1 = 192.168.88.0/24
wlan2 = 192.168.88.0/241DHCP (2 pools/server) are on core router.
I am trying to use the core router as much configuration information as possible. Is it possible to have the wlan security profiles that are used on the RB951Ui-2HnD routers, which are configured to be switches, stored on the core router? It's not a big thing, just makes things easier.
Thanks in advance.
Peace,
Pat
mkx
Re: use security profile on another router
Wed Oct 20, 2021 8:15 am
You can use CAPsMAN ... it's main task (and strength) is to provision CAP's wireless interface(s) which includes security profiles and more. The only constraint is that all involved devices are ROS devices. With some minor tinkering it is possible to make CAPsMAN provision wireless on very device running CAPsMAN manager.
patintexas
Thu Oct 21, 2021 3:54 am
Thanks, I'll check CAPsMAN out soon.
Users browsing this forum: 0xAA55, adrianmartin16, Ahrefs [Bot], Bing [Bot], donmunyak, kolopeter and 42 guests
