jhbarrantes
How to check if fasttrack is really working in V7
Wed Oct 20, 2021 10:57 am
I recently migrate one of my router's to RouterOS v7rc4 version. I notice fasttrack counters (either packages/bytes) are the same for this firewall rule and for the subsequence one that accept new traffic in forward. If I'm not wrong, these counters should be different when fasttrack is active, due to the fact that traffic related should be entering through the first rule, and not the second one, hence the first rule should receive much more traffic than the second one. Is my assumption wrong?
Attached my configuration, which is just a default config from default init script.
add admin-mac=E4:8D:8C:50:A3:F0 auto-mac=no comment=defconf name=bridge
add comment=defconf name=WAN
add comment=defconf name=LAN
/ip hotspot profile
add address-pool=default-dhcp interface=bridge name=defconf
    192.168.88.0
/ip dhcp-client
    192.168.88.1
set allow-remote-requests=yes
/ip dns static
    established,related,untracked
    invalid
    in-interface-list=!LAN
    ipsec-policy=in,ipsec
    ipsec-policy=out,ipsec
    connection-state=invalid
/ipv6 firewall address-list
/ipv6 firewall filter
    invalid
    icmpv6
add action=accept chain=input comment="defconf: accept UDP traceroute" port=\
    33434-33534 protocol=udp
    udp src-address=fe80::/10
    protocol=udp
    ipsec-ah
    ipsec-esp
    !LAN
    icmpv6
    500,4500 protocol=udp
    ipsec-ah
    ipsec-esp
    !LAN
/system clock
set time-zone-name=Europe/Madrid
/system routerboard settings
set silent-boot=yes
/tool mac-server
/tool mac-server mac-winbox
Thanks a lot in advance.
gabacho4
Re: How to check if fasttrack is really working in V7
Wed Oct 20, 2021 6:35 pm
If you navigate to IP -> Settings in Winbox, you see a section toward the bottom that will indicate if IPV4 fasttrack is active. It will also show you the number of bytes and packets that have been handled by fasttrack.
mducharme
Trainer
Trainer
Wed Oct 20, 2021 7:32 pm
Yes, your assumption is wrong. Fasttracked connections don't hit the firewall anymore except for rule 0. If you look at your rule 0 in your firewall in your screenshot above you see 25.5MiB of data. That is the counter rule ("special dummy rule to show fasttrack counters") that shows how much is being fasttracked. So I can already see from your screenshot that fasttrack is working fine.
jhbarrantes
Wed Oct 20, 2021 7:48 pm
You're absolutely right. I just reset another router with 6.49 and is working the same way. I don't know why I had the feeling these numbers were different before, but it might be the case I had it like this because I stopped some of the rules at some point, therefore the difference in counters.
Thanks both for the quick reply!
howdey57
Tue Aug 16, 2022 4:19 pm
If the Fasttracked connections don't hit the firewall anymore, why do we need the "fasttrack-connection" rule?
mkx
Tue Aug 16, 2022 6:35 pm
When certain connection matches selection critera of this rule, action of this rule "registers" the connection for fasttracking. And this applies to connections that are not fasttracked (yet). Without such rule fasttrack doesn't work at all. Sometimes it's good to exclude some connections from being fasttracked for various reasons and it's good to have possibility to fine tune selection process.
The top-most "rule" which shows meaningfull counters is a dummy rule (as noted by a comment for this rule) and doesn't affect actual packet flow of any packets.
howdey57
Tue Aug 16, 2022 10:59 pm
Thank you. That makes sense.
Users browsing this forum: gigabyte091 and 26 guests
