marwan001
Can someone help me
Wed Oct 20, 2021 11:43 pm
When i use ping from Mikrotik Terminal I get timeout
but when i use IP scan all the APs shows
When I am connected local to the network, whether by cable or wireless, I can reach all wireless APs devices.
so far I have successfully connected to the network using pptp,
but i can't access APs devices
thank you all..
k6ccc
Re: Can someone help me
Thu Oct 21, 2021 12:13 am
Please start off with a network diagram so we have some idea what you are trying to do.
Next a list of what equipment is involved (if the diagram does not make that obvious).
Lastly, your configuration. To export and paste your configuration (and I'm assuming you are using WebFig or Winbox), open a terminal window, and type (without the quotes) "/export hide-sensitive file=any-filename-you-wish". Then open the files section and right click on the filename you created and select download in order to download the file to your computer. It will be a text file with whatever name you saved to with an extension of .rsc. Then in your message here, click the code display icon in the toolbar above the text entry (the code display icon is the 7th one from the left and looks like a square with a blob in the middle). Then paste the text from the file in between the two code words in brackets.
Too much information is better than too little.
marwan001
Thu Oct 21, 2021 1:43 am
add distance=1 gateway=192.168.0.1
/ip service
set telnet disabled=yes
set ftp disabled=yes
set ssh disabled=yes
set api port=8727
set api-ssl port=8726
/ppp secret
add name=ppp1 profile=profile1
/radius
add address=192.168.1.1 service=ppp,hotspot
/radius incoming
set accept=yes
/system clock
set time-zone-name=Asia/Riyadh
/system ntp client
set primary-ntp=23.80.133.97 secondary-ntp=222.532.51.87
/system scheduler
add interval=30m name=ex_dis_new on-event=\
    "/system script run ex_dis_user_new" policy=\
    ftp,reboot,read,write,policy,test,password,sniff,sensitive,romon \
    start-time=startup
add interval=50m name=ex_dis on-event="/system script run ex_dis_user" \
    policy=ftp,reboot,read,write,policy,test,password,sniff,sensitive,romon \
    start-date=jun/22/2021 start-time=00:05:00
/tool user-manager database
set db-path=user-manager
/tool user-manager profile profile-limitation
add from-time=0s limitation=30dnew profile=30dnew till-time=23h59m59s \
    weekdays=sunday,monday,tuesday,wednesday,thursday,friday,saturday
add from-time=0s limitation=Lim10d profile=10d till-time=23h59m59s weekdays=\
/tool user-manager router
add coa-port=1700 customer=admin disabled=no ip-address=192.168.0.2 log=\
    auth-fail name=router1 use-coa=yes
add coa-port=1700 customer=admin disabled=no ip-address=192.168.1.1 log=\
    auth-fail name=router2 use-coa=no
/tool user-manager user
k6ccc
Thu Oct 21, 2021 6:49 am
You left off most of your config - including almost all the stuff we might need. Please try again. And please follow my instructions from my first post.
anav
Thu Oct 21, 2021 4:11 pm
Rant on...... Of course the OP did that, k6cccc, the arrogance of people coming here asking for help for their issues and then they assume they know what you need to see and ignore your logical request for context and information.
Clearly they know shit otherwise they wouldnt be here asking for help...... Rant off.
k6ccc
Thu Oct 21, 2021 5:10 pm
Rant on...... Of course the OP did that, k6ccc,
<snip>
Rant off.
That is one of my pet peeves. Not unique to this forum. People ask for help and then won't provide the specific information required for us to be able to help them. We're not mind-readers so we are dependent on the person requesting the help to tell us what we need to know.
marwan001
Thu Oct 21, 2021 5:47 pm
dear, if you have any information to give, or shut up
k6ccc
Thu Oct 21, 2021 5:51 pm
You want our help, please provide the information I requested in my first reply - or else neither I nor anyone else can help you.
marwan001
Thu Oct 21, 2021 5:59 pm
That's all, with users I thought you dont need it before
this all
# oct/21/2021 17:51:21 by RouterOS 6.48.1
# software id = RDJN-FHV7
# model = RB4011iGS+
# serial number = D4440DBA5D01
add name=bridge1
set 0 default-vlan-id=0
set 1 default-vlan-id=0
set 2 default-vlan-id=0
set 3 default-vlan-id=0
set 4 default-vlan-id=0
set 5 default-vlan-id=0
set 6 default-vlan-id=0
set 7 default-vlan-id=0
set 8 default-vlan-id=0
set 9 default-vlan-id=0
set 10 default-vlan-id=0
set 11 default-vlan-id=0
/ip hotspot profile
set [ find default=yes ] http-cookie-lifetime=42w6d login-by=\
    cookie,http-chap,https,http-pap,mac-cookie use-radius=yes
add dns-name=www.a.net hotspot-address=192.168.1.1 login-by=\
    http-chap,https,http-pap,mac-cookie name=hsprof1 use-radius=yes
/ip hotspot user profile
set [ find default=yes ] mac-cookie-timeout=4w2d
add mac-cookie-timeout=4w2d name=mumpro on-login="{:local date [ /system clock\
    \_get date ];:if ( [ /ip hotspot user get \$user comment ] = \"\" ) do={[ \
    /ip hotspot user set \$user comment=\$date ];}}"
add name=dhcp_pool0 ranges=192.168.1.50-192.168.1.254
add address-pool=dhcp_pool0 authoritative=after-2sec-delay \
    conflict-detection=no disabled=no interface=bridge1 lease-time=1h10m \
    name=dhcp1 use-framed-as-classless=no
/ip hotspot
add address-pool=dhcp_pool0 addresses-per-mac=1 disabled=no interface=bridge1 \
    name=hotspot1 profile=hsprof1
/lora servers
add address=eu.mikrotik.thethings.industries down-port=1700 name=TTN-EU \
    up-port=1700
add address=us.mikrotik.thethings.industries down-port=1700 name=TTN-US \
    up-port=1700
/ppp profile
add dns-server=8.8.8.8 local-address=10.0.0.1 name=profile1 remote-address=\
    dhcp_pool0 wins-server=8.8.4.4
/tool user-manager customer
set admin access=\
    own-routers,own-users,own-profiles,own-limits,config-payment-gw
add name=30dnew name-for-users=30dnew override-shared-users=unlimited owner=\
    admin price=30 starts-at=logon validity=4w2d
add name=10d name-for-users=10d override-shared-users=unlimited owner=admin \
    price=10 starts-at=logon validity=1w3d
/tool user-manager profile limitation
add address-list="" download-limit=0B group-name="" ip-pool="" ip-pool6="" \
    name=30dnew owner=admin transfer-limit=0B upload-limit=0B uptime-limit=\
    4w2d
    name=Lim10d owner=admin transfer-limit=0B upload-limit=0B uptime-limit=\
    1w3d
/interface pptp-server server
set enabled=yes
/interface sstp-server server
set enabled=yes
add address=192.168.0.2/24 interface=ether1 network=192.168.0.0
add address=192.168.1.1/24 interface=bridge1 network=192.168.1.0
/ip cloud
set ddns-enabled=yes ddns-update-interval=5m
add address=192.168.1.0/24 dns-server=8.8.8.8 gateway=192.168.1.1
set allow-remote-requests=yes servers=8.8.8.8,4.4.4.4
add action=passthrough chain=unused-hs-chain comment=\
    "place hotspot rules here" disabled=yes
add action=accept chain=input src-address=192.168.1.0/24
add action=masquerade chain=srcnat comment="masquerade hotspot network" \
add action=dst-nat chain=dstnat disabled=yes dst-port=3399 in-interface-list=\
    all protocol=tcp to-addresses=192.168.0.1 to-ports=80
/ip hotspot user
add email=30@0_30.ptd name=48885199 profile=mumpro
add email=30@0_30.ptd name=63389829 profile=mumpro
add email=30@0_30.ptd name=29246435 profile=mumpro
add email=1@0_0.ptd limit-uptime=1h name=7190395 profile=mumpro
add email=1@0_0.ptd limit-uptime=1h name=1975010 profile=mumpro
add email=1@0_0.ptd limit-uptime=1h name=9666749 profile=mumpro
add email=1@0_0.ptd limit-uptime=1h name=1134869 profile=mumpro
add email=1@0_0.ptd limit-uptime=1h name=6866379 profile=mumpro
add email=1@0_0.ptd limit-uptime=1h name=9422925 profile=mumpro
add email=1@0_0.ptd limit-uptime=1h name=7011319 profile=mumpro
add email=1@0_0.ptd limit-uptime=1h name=8688944 profile=mumpro
add email=30@0_100.ptd limit-uptime=4w2d name=27500386 profile=mumpro
add email=30@0_100.ptd limit-uptime=4w2d name=73872279 profile=mumpro
add email=30@0_100.ptd limit-uptime=4w2d name=88393540 profile=mumpro
add email=30@0_100.ptd limit-uptime=4w2d name=50029757 profile=mumpro
add email=30@0_100.ptd limit-uptime=4w2d name=17296136 profile=mumpro
add email=30@0_100.ptd limit-uptime=4w2d name=65733670 profile=mumpro
add email=30@0_100.ptd limit-uptime=4w2d name=59481292 profile=mumpro
add email=30@0_100.ptd limit-uptime=4w2d name=63069694 profile=mumpro
add email=30@0_100.ptd limit-uptime=4w2d name=61554702 profile=mumpro
add email=30@0_100.ptd limit-uptime=4w2d name=10172426 profile=mumpro
add email=10@0_100.ptd limit-uptime=1w3d name=125801534 profile=mumpro
add comment=mums-aug/01/2021 email=365@0_0.ptd limit-uptime=52w1d name=\
    126644292126 profile=mumpro
add comment=mums-aug/03/2021 email=365@0_0.ptd limit-uptime=52w1d name=\
    344572815261 profile=mumpro
add email=10@0_0.ptd limit-uptime=1w3d name=1100396254 profile=mumpro
add email=10@0_0.ptd limit-uptime=1w3d name=1665345773 profile=mumpro
add email=10@0_0.ptd limit-uptime=1w3d name=1518898021 profile=mumpro
add comment=sep/10/2021 email=10@0_0.ptd limit-uptime=1w3d name=1021921533 \
    profile=mumpro
add comment=sep/10/2021 email=10@0_0.ptd limit-uptime=1w3d name=1058075094 \
    profile=mumpro
add comment=sep/16/2021 email=10@0_0.ptd limit-uptime=1w3d name=1886408115 \
    profile=mumpro
add comment=sep/28/2021 email=10@0_0.ptd limit-uptime=1w3d name=1083234405 \
    profile=mumpro
add email=10@0_10.ptd limit-uptime=1w3d name=49850585 profile=mumpro
add email=30@0_30.ptd limit-uptime=4w2d name=42313095 profile=mumpro
add email=10@0_30.ptd limit-uptime=1w3d name=65472779 profile=mumpro
add email=10@0_30.ptd limit-uptime=1w3d name=31084683 profile=mumpro
add email=10@0_30.ptd limit-uptime=1w3d name=58725084 profile=mumpro
add email=10@0_30.ptd limit-uptime=1w3d name=61888079 profile=mumpro
add email=30@0_30.ptd limit-uptime=4w2d name=2137784291 profile=mumpro
add email=30@0_30.ptd limit-uptime=4w2d name=2323961815 profile=mumpro
add email=30@0_30.ptd limit-uptime=4w2d name=2865566299 profile=mumpro
add email=30@0_30.ptd limit-uptime=4w2d name=2328332887 profile=mumpro
add email=30@0_30.ptd limit-uptime=4w2d name=2862907603 profile=mumpro
add email=30@0_30.ptd limit-uptime=4w2d name=2852765729 profile=mumpro
add email=30@0_30.ptd limit-uptime=4w2d name=2247301229 profile=mumpro
add email=30@0_30.ptd limit-uptime=4w2d name=2446601512 profile=mumpro
add email=30@0_30.ptd limit-uptime=4w2d name=2071672210 profile=mumpro
add email=30@0_30.ptd limit-uptime=4w2d name=2837325294 profile=mumpro
add email=30@0_30.ptd limit-uptime=4w2d name=2010493757 profile=mumpro
add email=30@0_30.ptd limit-uptime=4w2d name=2885705048 profile=mumpro
add email=30@0_30.ptd limit-uptime=4w2d name=2783227255 profile=mumpro
add email=30@0_30.ptd limit-uptime=4w2d name=2278042623 profile=mumpro
add email=30@0_30.ptd limit-uptime=4w2d name=2260410595 profile=mumpro
add email=30@0_30.ptd limit-uptime=4w2d name=2466331235 profile=mumpro
add email=30@0_30.ptd limit-uptime=4w2d name=2660376265 profile=mumpro
add email=30@0_30.ptd limit-uptime=4w2d name=2013056373 profile=mumpro
add email=30@0_30.ptd limit-uptime=4w2d name=2838631545 profile=mumpro
add email=30@0_30.ptd limit-uptime=4w2d name=2067543508 profile=mumpro
add email=30@0_100.ptd limit-uptime=4w2d name=2424931137 profile=mumpro
add email=30@0_100.ptd limit-uptime=4w2d name=2553368027 profile=mumpro
add email=30@0_100.ptd limit-uptime=4w2d name=2450208248 profile=mumpro
add email=30@0_100.ptd limit-uptime=4w2d name=2397708505 profile=mumpro
add email=30@0_100.ptd limit-uptime=4w2d name=2590232781 profile=mumpro
add email=30@0_100.ptd limit-uptime=4w2d name=2844517413 profile=mumpro
add email=30@0_100.ptd limit-uptime=4w2d name=2758463986 profile=mumpro
add email=30@0_100.ptd limit-uptime=4w2d name=2603373375 profile=mumpro
add email=30@0_100.ptd limit-uptime=4w2d name=2933609715 profile=mumpro
add email=30@0_100.ptd limit-uptime=4w2d name=2826316216 profile=mumpro
add email=30@0_100.ptd limit-uptime=4w2d name=2273265228 profile=mumpro
add email=30@0_100.ptd limit-uptime=4w2d name=2200912817 profile=mumpro
add email=30@0_100.ptd limit-uptime=4w2d name=2230320629 profile=mumpro
add email=30@0_100.ptd limit-uptime=4w2d name=2281425336 profile=mumpro
add email=30@0_100.ptd limit-uptime=4w2d name=2226667399 profile=mumpro
add email=30@0_100.ptd limit-uptime=4w2d name=2213584425 profile=mumpro
add email=30@0_100.ptd limit-uptime=4w2d name=2231984721 profile=mumpro
add email=30@0_100.ptd limit-uptime=4w2d name=2247147751 profile=mumpro
add email=30@0_100.ptd limit-uptime=4w2d name=2257121651 profile=mumpro
add email=30@0_100.ptd limit-uptime=4w2d name=2202272500 profile=mumpro
add email=30@0_100.ptd limit-uptime=4w2d name=2265626031 profile=mumpro
add email=30@0_30.ptd limit-uptime=4w2d name=1189242465 profile=mumpro
add comment=mums-sep/06/2021 disabled=yes email=30@0_30.ptd limit-uptime=4w2d \
    name=1474822020 profile=mumpro
add comment=sep/06/2021 email=30@0_30.ptd limit-uptime=4w2d name=1445827490 \
    profile=mumpro
    name=1665637153 profile=mumpro
add comment=oct/02/2021 email=30@0_100.ptd limit-uptime=4w2d name=1031835533 \
    profile=mumpro
add comment=sep/30/2021 email=30@0_100.ptd limit-uptime=4w2d name=1043510715 \
    profile=mumpro
add comment=oct/03/2021 email=30@0_100.ptd limit-uptime=4w2d name=1023390975 \
    profile=mumpro
add comment=oct/02/2021 email=30@0_100.ptd limit-uptime=4w2d name=1045589743 \
    profile=mumpro
add comment=sep/21/2021 email=30@0_100.ptd limit-uptime=4w2d name=1079851568 \
    profile=mumpro
add email=30@0_100.ptd limit-uptime=4w2d name=1015555327 profile=mumpro
add comment=sep/20/2021 email=30@0_100.ptd limit-uptime=4w2d name=1039723477 \
    profile=mumpro
add comment=sep/28/2021 email=30@0_100.ptd limit-uptime=4w2d name=1043094256 \
    profile=mumpro
add comment=oct/01/2021 email=30@0_100.ptd limit-uptime=4w2d name=1057375454 \
    profile=mumpro
add comment=sep/29/2021 email=30@0_100.ptd limit-uptime=4w2d name=1096282092 \
    profile=mumpro
add comment=sep/08/2021 email=30@0_100.ptd limit-uptime=4w2d name=1096885453 \
    profile=mumpro
add comment=sep/07/2021 email=30@0_100.ptd limit-uptime=4w2d name=1076108713 \
    profile=mumpro
add comment=sep/09/2021 email=30@0_100.ptd limit-uptime=4w2d name=1053731948 \
    profile=mumpro
add comment=sep/08/2021 email=30@0_100.ptd limit-uptime=4w2d name=1013645545 \
    profile=mumpro
add comment=sep/09/2021 email=30@0_100.ptd limit-uptime=4w2d name=1006108832 \
    profile=mumpro
add comment=sep/12/2021 email=30@0_100.ptd limit-uptime=4w2d name=1070971646 \
    profile=mumpro
add comment=sep/07/2021 email=30@0_100.ptd limit-uptime=4w2d name=1028443635 \
    profile=mumpro
add comment=sep/09/2021 email=30@0_100.ptd limit-uptime=4w2d name=1012383927 \
    profile=mumpro
add comment=sep/10/2021 email=30@0_100.ptd limit-uptime=4w2d name=1086535432 \
    profile=mumpro
add comment=sep/11/2021 email=30@0_100.ptd limit-uptime=4w2d name=1079332909 \
    profile=mumpro
add comment=sep/18/2021 email=30@0_30.ptd limit-uptime=4w2d name=1088055749 \
    profile=mumpro
add comment=sep/22/2021 email=30@0_30.ptd limit-uptime=4w2d name=1054406459 \
    profile=mumpro
add comment=sep/24/2021 email=30@0_30.ptd limit-uptime=4w2d name=1010057345 \
    profile=mumpro
add comment=sep/25/2021 email=30@0_30.ptd limit-uptime=4w2d name=1062304576 \
    profile=mumpro
add comment=sep/25/2021 email=30@0_30.ptd limit-uptime=4w2d name=1046125753 \
    profile=mumpro
add comment=sep/26/2021 email=30@0_30.ptd limit-uptime=4w2d name=1064174632 \
    profile=mumpro
add comment=sep/26/2021 email=30@0_30.ptd limit-uptime=4w2d name=1068205804 \
    profile=mumpro
add comment=oct/01/2021 email=27@0_30.ptd limit-uptime=4w2d name=1046896437 \
    profile=mumpro
add comment=sep/29/2021 email=30@0_30.ptd limit-uptime=4w2d name=1030770768 \
    profile=mumpro
add comment=sep/30/2021 email=30@0_30.ptd limit-uptime=4w2d name=1093728064 \
    profile=mumpro
add comment=oct/08/2021 email=30@0_30.ptd limit-uptime=4w2d name=1083108621 \
    profile=mumpro
add comment=oct/06/2021 email=30@0_30.ptd limit-uptime=4w2d name=1058721098 \
    profile=mumpro
add comment=oct/06/2021 email=30@0_30.ptd limit-uptime=4w2d name=1028430752 \
    profile=mumpro
add comment=oct/06/2021 email=30@0_30.ptd limit-uptime=4w2d name=1008452896 \
    profile=mumpro
add comment=oct/08/2021 email=30@0_30.ptd limit-uptime=4w2d name=1049842872 \
    profile=mumpro
add email=30@0_30.ptd limit-uptime=4w2d name=1092476805 profile=mumpro
add comment=sep/27/2021 email=30@0_30.ptd limit-uptime=4w2d name=1032050488 \
    profile=mumpro
add comment=sep/27/2021 email=30@0_30.ptd limit-uptime=4w2d name=1028056165 \
    profile=mumpro
add comment=sep/27/2021 email=30@0_30.ptd limit-uptime=4w2d name=1037371492 \
    profile=mumpro
add email=30@0_30.ptd limit-uptime=4w2d name=1031282061 profile=mumpro
add comment=sep/27/2021 email=30@0_30.ptd limit-uptime=4w2d name=1020059114 \
    profile=mumpro
add comment=sep/27/2021 email=30@0_30.ptd limit-uptime=4w2d name=1006631077 \
    profile=mumpro
add comment=sep/27/2021 email=30@0_30.ptd limit-uptime=4w2d name=1054692881 \
    profile=mumpro
add comment=sep/27/2021 email=30@0_30.ptd limit-uptime=4w2d name=1010336552 \
    profile=mumpro
add comment=sep/27/2021 email=30@0_30.ptd limit-uptime=4w2d name=1097858666 \
    profile=mumpro
add comment=sep/27/2021 email=30@0_30.ptd limit-uptime=4w2d name=1015553248 \
    profile=mumpro
add comment=sep/28/2021 email=30@0_30.ptd limit-uptime=4w2d name=1076974210 \
    profile=mumpro
add comment=sep/28/2021 email=30@0_30.ptd limit-uptime=4w2d name=1067911114 \
    profile=mumpro
add comment=oct/04/2021 email=30@0_30.ptd limit-uptime=4w2d name=1095484595 \
    profile=mumpro
add comment=oct/07/2021 email=30@0_30.ptd limit-uptime=4w2d name=1076783287 \
    profile=mumpro
add comment=oct/04/2021 email=30@0_30.ptd limit-uptime=4w2d name=1094393494 \
    profile=mumpro
add comment=oct/11/2021 email=30@0_30.ptd limit-uptime=4w2d name=1041933263 \
    profile=mumpro
add comment=oct/09/2021 email=30@0_30.ptd limit-uptime=4w2d name=1031934678 \
    profile=mumpro
add comment=oct/11/2021 email=30@0_30.ptd limit-uptime=4w2d name=1051634005 \
    profile=mumpro
add comment=oct/13/2021 email=30@0_30.ptd limit-uptime=4w2d name=1070444795 \
    profile=mumpro
add comment=oct/15/2021 email=30@0_30.ptd limit-uptime=4w2d name=1034802240 \
    profile=mumpro
add comment=oct/19/2021 email=30@0_30.ptd limit-uptime=4w2d name=1054317997 \
    profile=mumpro
add comment=oct/20/2021 email=30@0_30.ptd limit-uptime=4w2d name=1055056273 \
    profile=mumpro
add email=30@0_30.ptd limit-uptime=4w2d name=1096948651 profile=mumpro
add email=30@0_30.ptd limit-uptime=4w2d name=1010113511 profile=mumpro
add email=30@0_30.ptd limit-uptime=4w2d name=1009233645 profile=mumpro
add email=30@0_30.ptd limit-uptime=4w2d name=1096411772 profile=mumpro
add email=30@0_30.ptd limit-uptime=4w2d name=1003270209 profile=mumpro
add email=30@0_30.ptd limit-uptime=4w2d name=1007240421 profile=mumpro
add email=30@0_30.ptd limit-uptime=4w2d name=1002678528 profile=mumpro
add email=30@0_30.ptd limit-uptime=4w2d name=1065120744 profile=mumpro
add email=30@0_30.ptd limit-uptime=4w2d name=1084177377 profile=mumpro
add email=30@0_30.ptd limit-uptime=4w2d name=1063827308 profile=mumpro
add email=30@0_30.ptd limit-uptime=4w2d name=1047428875 profile=mumpro
add email=30@0_30.ptd limit-uptime=4w2d name=1028598189 profile=mumpro
add email=30@0_30.ptd limit-uptime=4w2d name=1033763955 profile=mumpro
add email=30@0_30.ptd limit-uptime=4w2d name=1044009813 profile=mumpro
add email=30@0_30.ptd limit-uptime=4w2d name=1021777995 profile=mumpro
add email=30@0_30.ptd limit-uptime=4w2d name=1005366891 profile=mumpro
add email=30@0_30.ptd limit-uptime=4w2d name=1086271767 profile=mumpro
add email=30@0_30.ptd limit-uptime=4w2d name=1098427106 profile=mumpro
add email=30@0_30.ptd limit-uptime=4w2d name=1024818059 profile=mumpro
add email=30@0_30.ptd limit-uptime=4w2d name=1061765213 profile=mumpro
add email=30@0_30.ptd limit-uptime=4w2d name=1092258675 profile=mumpro
add email=30@0_30.ptd limit-uptime=4w2d name=1097929523 profile=mumpro
add comment=oct/06/2021 email=10@0_100.ptd limit-uptime=1w3d name=107310801 \
    profile=mumpro
add comment=oct/09/2021 email=10@0_100.ptd limit-uptime=1w3d name=105183391 \
    profile=mumpro
add comment=oct/18/2021 email=10@0_100.ptd limit-uptime=1w3d name=101999270 \
    profile=mumpro
add email=10@0_100.ptd limit-uptime=1w3d name=106242515 profile=mumpro
add email=10@0_100.ptd limit-uptime=1w3d name=100651318 profile=mumpro
add comment=oct/14/2021 email=10@0_100.ptd limit-uptime=1w3d name=104913041 \
    profile=mumpro
add comment=oct/15/2021 email=10@0_100.ptd limit-uptime=1w3d name=102723344 \
    profile=mumpro
add comment=oct/18/2021 email=10@0_100.ptd limit-uptime=1w3d name=109642143 \
    profile=mumpro
add comment=oct/11/2021 email=10@0_100.ptd limit-uptime=1w3d name=104750461 \
    profile=mumpro
add comment=oct/12/2021 email=10@0_100.ptd limit-uptime=1w3d name=105807485 \
    profile=mumpro
add comment=oct/17/2021 email=10@0_100.ptd limit-uptime=1w3d name=102608933 \
    profile=mumpro
add email=10@0_100.ptd limit-uptime=1w3d name=103511885 profile=mumpro
add comment=oct/16/2021 email=10@0_100.ptd limit-uptime=1w3d name=101714263 \
    profile=mumpro
add comment=oct/13/2021 email=10@0_100.ptd limit-uptime=1w3d name=103074422 \
    profile=mumpro
add comment=oct/21/2021 email=10@0_100.ptd limit-uptime=1w3d name=103843570 \
    profile=mumpro
add comment=oct/17/2021 email=10@0_100.ptd limit-uptime=1w3d name=100196341 \
    profile=mumpro
add comment=oct/14/2021 email=10@0_100.ptd limit-uptime=1w3d name=100218907 \
    profile=mumpro
add email=10@0_100.ptd limit-uptime=1w3d name=101688099 profile=mumpro
add comment=oct/17/2021 email=10@0_100.ptd limit-uptime=1w3d name=108352971 \
    profile=mumpro
add comment=oct/09/2021 email=10@0_100.ptd limit-uptime=1w3d name=108228171 \
    profile=mumpro
/ip service
set api port=8728
set api-ssl port=8727
/ppp secret
/radius
/radius incoming
set accept=yes
/system clock
/system ntp client
set primary-ntp=18.98.226.79 secondary-ntp=200.244.50.89
/system scheduler
    start-time=startup
/system script
add dont-require-permissions=no name=ex_dis_user owner=admin policy=\
    ftp,reboot,read,write,policy,test,password,sniff,sensitive source="{:globa\
    l today;{:local date [ /system clock get date ];:local montharray ( \"jan\
    \",\"feb\",\"mar\",\"apr\",\"may\",\"jun\",\"jul\",\"aug\",\"sep\",\"oct\"\
    ,\"nov\",\"dec\" );:local monthdays ( 31, 28, 31, 30, 31, 30, 31, 31, 30, \
    31, 30, 31 );:local days [ :pick \$date 4 6 ];:local monthtxt [ :pick \$da\
    te 0 3 ];:local year [ :pick \$date 7 11 ];:local months ([ :find \$montha\
    rray \$monthtxt]);:for nodays from=0 to=\$months do={:set days ( \$days + \
    [ :pick \$monthdays \$nodays ] )};:set days (\$days + \$year * 365);:set t\
    oday \$days;};:foreach i in [ /ip hotspot user find where disabled=no ] do\
    ={:if ([ :find [ /ip hotspot user get \$i comment ] ] = 0 && [ :find [ /ip\
    \_hotspot user get \$i email ] ] = 0) do={:local date [ /ip hotspot user g\
    et \$i comment ];:local oldemail [ /ip hotspot user get \$i email ];:local\
    \_atmark [ :find \$oldemail \"@\" ];:local dotmark [ :find \$oldemail \".\
    \" ];:if ( \$atmark >= 0 && \$dotmark >= 0 ) do={:local validity [ :pick \
    \$oldemail 0 \$atmark];:local rest [ :pick \$oldemail (\$atmark + 1) [ :le\
    n \$oldemail] ];:if ( [:tonum \$validity] != \"\" ) do={:if ( [:tonum \$va\
    lidity] != \"0\" ) do={:local montharray ( \"jan\",\"feb\",\"mar\",\"apr\"\
    ,\"may\",\"jun\",\"jul\",\"aug\",\"sep\",\"oct\",\"nov\",\"dec\" );:local \
    monthdays ( 31, 28, 31, 30, 31, 30, 31, 31, 30, 31, 30, 31 );:local days [\
    \_:pick \$date 4 6 ];:local monthtxt [ :pick \$date 0 3 ];:local year [ :p\
    ick \$date 7 11 ];:local months ( [ :find \$montharray \$monthtxt ] );:for\
    \_nodays from=0 to=\$months do={:set days ( \$days + [ :pick \$monthdays \
    \$nodays ] )};:set days (\$days + \$year * 365);:if ( (\$days + \$validity\
    ) < \$today ) do={ :local name [/ip hotspot user get \$i name];:log info \
    \"HOTSPOT VALITITY EXPIRE: Disabling Hotspot user \$name first logged in \
    \$date\";[ /ip hotspot user disable \$i ];}}}}}}}"
add dont-require-permissions=no name=ex_dis_user_new owner=admin policy=\
    read,write source="{:global today;{:local date [ /system clock get date ];\
    :local montharray ( \"jan\",\"feb\",\"mar\",\"apr\",\"may\",\"jun\",\"jul\
    \",\"aug\",\"sep\",\"oct\",\"nov\",\"dec\" );:local monthdays ( 31, 28, 31\
    , 30, 31, 30, 31, 31, 30, 31, 30, 31 );:local days [ :pick \$date 4 6 ];:l\
    ocal monthtxt [ :pick \$date 0 3 ];:local year [ :pick \$date 7 11 ];:loca\
    l months ([ :find \$montharray \$monthtxt]);:for nodays from=0 to=\$months\
    \_do={:set days ( \$days + [ :pick \$monthdays \$nodays ] )};:set days (\$\
    days + \$year * 365);:set today \$days;};:foreach i in [ /ip hotspot user \
    find where disabled=no ] do={:if ([ :find [ /ip hotspot user get \$i comme\
    nt ] ] = 0 && [ :find [ /ip hotspot user get \$i email ] ] = 0) do={:local\
    \_datee [ /ip hotspot user get \$i comment ];:local mums [ :pick \$datee 0\
    \_4 ]; :if ( \$mums = \"mums\" ) do={ :local date [ :pick \$datee 5 16 ];:\
    local oldemail [ /ip hotspot user get \$i email ];:local atmark [ :find \$\
    oldemail \"@\" ];:local dotmark [ :find \$oldemail \".\" ];:if ( \$atmark \
    >= 0 && \$dotmark >= 0 ) do={:local validity [ :pick \$oldemail 0 \$atmark\
    ];:local rest [ :pick \$oldemail (\$atmark + 1) [ :len \$oldemail] ];:if (\
    \_[:tonum \$validity] != \"\" ) do={:if ( [:tonum \$validity] != \"0\" ) d\
    o={:local montharray ( \"jan\",\"feb\",\"mar\",\"apr\",\"may\",\"jun\",\"j\
    ul\",\"aug\",\"sep\",\"oct\",\"nov\",\"dec\" );:local monthdays ( 31, 28, \
    31, 30, 31, 30, 31, 31, 30, 31, 30, 31 );:local days [ :pick \$date 4 6 ];\
    :local monthtxt [ :pick \$date 0 3 ];:local year [ :pick \$date 7 11 ];:lo\
    cal months ( [ :find \$montharray \$monthtxt ] );:for nodays from=0 to=\$m\
    onths do={:set days ( \$days + [ :pick \$monthdays \$nodays ] )};:set days\
    \_(\$days + \$year * 365);:if ( (\$days + \$validity) < \$today ) do={ :lo\
    cal name [/ip hotspot user get \$i name];:log info \"HOTSPOT VALITITY EXPI\
    RE: Disabling Hotspot user \$name first logged in \$date\";[ /ip hotspot u\
    ser disable \$i ];}}}}}}}}"
add caller-id=bind customer=admin disabled=no ipv6-dns=:: shared-users=\
    unlimited username=7134983 wireless-enc-algo=none wireless-enc-key="" \
    wireless-psk=""
    unlimited username=46888601 wireless-enc-algo=none wireless-enc-key="" \
    wireless-psk=""
    unlimited username=78939087 wireless-enc-algo=none wireless-enc-key="" \
    wireless-psk=""
    unlimited username=44091951 wireless-enc-algo=none wireless-enc-key="" \
    wireless-psk=""
    unlimited username=744827510 wireless-enc-algo=none wireless-enc-key="" \
    wireless-psk=""
    unlimited username=897270420 wireless-enc-algo=none wireless-enc-key="" \
    wireless-psk=""
    unlimited username=721317087 wireless-enc-algo=none wireless-enc-key="" \
    wireless-psk=""
    unlimited username=773339558 wireless-enc-algo=none wireless-enc-key="" \
    wireless-psk=""
    unlimited username=626316951 wireless-enc-algo=none wireless-enc-key="" \
    wireless-psk=""
    unlimited username=312178722 wireless-enc-algo=none wireless-enc-key="" \
    wireless-psk=""
    unlimited username=948244163 wireless-enc-algo=none wireless-enc-key="" \
    wireless-psk=""
    unlimited username=372078255 wireless-enc-algo=none wireless-enc-key="" \
    wireless-psk=""
    unlimited username=1456569795 wireless-enc-algo=none wireless-enc-key="" \
    wireless-psk=""
    unlimited username=19211291793 wireless-enc-algo=none wireless-enc-key="" \
    wireless-psk=""
add caller-id=5C:D0:6E:85:86:09 customer=admin disabled=no ipv6-dns=:: \
    shared-users=unlimited username=1066785995 wireless-enc-algo=none \
    wireless-enc-key="" wireless-psk=""
add caller-id=EA:1A:A8:05:99:29 customer=admin disabled=no ipv6-dns=:: \
    shared-users=unlimited username=1022674969 wireless-enc-algo=none \
add caller-id=76:AF:5C:37:58:35 customer=admin disabled=no ipv6-dns=:: \
    shared-users=unlimited username=1070032703 wireless-enc-algo=none \
add caller-id=B6:0D:AF:E8:A9:CE customer=admin disabled=no ipv6-dns=:: \
    shared-users=unlimited username=1093110457 wireless-enc-algo=none \
add caller-id=84:B8:B8:65:1E:42 customer=admin disabled=no ipv6-dns=:: \
    shared-users=unlimited username=1079193598 wireless-enc-algo=none \
add caller-id=1A:2E:07:65:0A:06 customer=admin disabled=no ipv6-dns=:: \
    shared-users=unlimited username=1022950876 wireless-enc-algo=none \
add caller-id=48:DB:50:9A:67:0D customer=admin disabled=no ipv6-dns=:: \
    shared-users=unlimited username=1049892955 wireless-enc-algo=none \
add caller-id=F4:D6:20:B6:33:86 customer=admin disabled=no ipv6-dns=:: \
    shared-users=unlimited username=1011124823 wireless-enc-algo=none \
add caller-id=C6:F8:DA:83:67:C4 customer=admin disabled=no ipv6-dns=:: \
    shared-users=unlimited username=1046165129 wireless-enc-algo=none \
add caller-id=B2:F9:8E:91:E3:92 customer=admin disabled=no ipv6-dns=:: \
    shared-users=unlimited username=1043328096 wireless-enc-algo=none \
add caller-id=E2:F2:39:8E:F7:DD customer=admin disabled=no ipv6-dns=:: \
    shared-users=unlimited username=1015955317 wireless-enc-algo=none \
add caller-id=04:BA:8D:42:49:FA customer=admin disabled=no ipv6-dns=:: \
    shared-users=unlimited username=1062724553 wireless-enc-algo=none \
add caller-id=A6:60:D2:47:7D:01 customer=admin disabled=no ipv6-dns=:: \
    shared-users=unlimited username=1005906958 wireless-enc-algo=none \
add caller-id=94:2D:DC:48:26:0E customer=admin disabled=no ipv6-dns=:: \
    shared-users=unlimited username=1079141085 wireless-enc-algo=none \
add caller-id=74:EB:80:E4:F4:D8 customer=admin disabled=no ipv6-dns=:: \
    shared-users=unlimited username=1051893107 wireless-enc-algo=none \
add caller-id=40:A1:08:23:EC:C6 customer=admin disabled=no ipv6-dns=:: \
    shared-users=unlimited username=1044416809 wireless-enc-algo=none \
add caller-id=02:98:E0:08:5E:D0 customer=admin disabled=no ipv6-dns=:: \
    shared-users=unlimited username=1057076710 wireless-enc-algo=none \
add caller-id=26:26:01:61:E3:40 customer=admin disabled=no ipv6-dns=:: \
    shared-users=unlimited username=1096358825 wireless-enc-algo=none \
add caller-id=E4:34:93:B0:EA:7B customer=admin disabled=no ipv6-dns=:: \
    shared-users=unlimited username=1030550319 wireless-enc-algo=none \
add caller-id=C0:10:B1:25:F0:30 customer=admin disabled=no ipv6-dns=:: \
    shared-users=unlimited username=1017881419 wireless-enc-algo=none \
add caller-id=74:22:BB:5F:E2:A2 customer=admin disabled=no ipv6-dns=:: \
    shared-users=unlimited username=1051629602 wireless-enc-algo=none \
    shared-users=unlimited username=1025205503 wireless-enc-algo=none \
add caller-id=FE:3B:82:75:AB:AF customer=admin disabled=no ipv6-dns=:: \
    shared-users=unlimited username=1068089725 wireless-enc-algo=none \
add caller-id=34:29:12:EB:E7:66 customer=admin disabled=no ipv6-dns=:: \
    shared-users=unlimited username=1033325317 wireless-enc-algo=none \
    unlimited username=1011772546 wireless-enc-algo=none wireless-enc-key="" \
    wireless-psk=""
add caller-id=3A:D2:3C:8D:E4:4C customer=admin disabled=no ipv6-dns=:: \
    shared-users=unlimited username=1072311032 wireless-enc-algo=none \
add caller-id=98:9C:57:6E:06:79 customer=admin disabled=no ipv6-dns=:: \
    shared-users=unlimited username=1088994372 wireless-enc-algo=none \
    shared-users=unlimited username=1025915425 wireless-enc-algo=none \
add caller-id=6C:C7:EC:B5:F5:59 customer=admin disabled=no ipv6-dns=:: \
    shared-users=unlimited username=1049619467 wireless-enc-algo=none \
add caller-id=94:BE:46:6F:B4:44 customer=admin disabled=no ipv6-dns=:: \
    shared-users=unlimited username=1051964258 wireless-enc-algo=none \
add caller-id=7A:95:1E:88:93:EF customer=admin disabled=no ipv6-dns=:: \
    shared-users=unlimited username=1080872250 wireless-enc-algo=none \
add caller-id=D8:C7:71:31:B3:59 customer=admin disabled=no ipv6-dns=:: \
    shared-users=unlimited username=1067131615 wireless-enc-algo=none \
add caller-id=F0:8A:76:EC:E9:6E customer=admin disabled=no ipv6-dns=:: \
    shared-users=unlimited username=1032442172 wireless-enc-algo=none \
add caller-id=42:69:93:76:F0:F9 customer=admin disabled=no ipv6-dns=:: \
    shared-users=unlimited username=1089150681 wireless-enc-algo=none \
add caller-id=7A:C6:BA:F8:1C:0E customer=admin disabled=no ipv6-dns=:: \
    shared-users=unlimited username=1058736868 wireless-enc-algo=none \
add caller-id=34:12:F9:64:A4:26 customer=admin disabled=no ipv6-dns=:: \
    shared-users=unlimited username=1025685069 wireless-enc-algo=none \
add caller-id=9E:3A:1F:DC:5A:74 customer=admin disabled=no ipv6-dns=:: \
    shared-users=unlimited username=1015505380 wireless-enc-algo=none \
add caller-id=B4:CD:27:7F:AF:AD customer=admin disabled=no ipv6-dns=:: \
    shared-users=unlimited username=1048851435 wireless-enc-algo=none \
add caller-id=2E:CF:82:4C:69:7D customer=admin disabled=no ipv6-dns=:: \
    shared-users=unlimited username=1092142034 wireless-enc-algo=none \
add caller-id=A8:7D:12:0E:EF:35 customer=admin disabled=no ipv6-dns=:: \
    shared-users=unlimited username=1035590296 wireless-enc-algo=none \
add caller-id=B6:14:10:47:8C:E7 customer=admin disabled=no ipv6-dns=:: \
    shared-users=unlimited username=1009085438 wireless-enc-algo=none \
    shared-users=unlimited username=1065508376 wireless-enc-algo=none \
add caller-id=84:C7:EA:C1:95:AD customer=admin disabled=no ipv6-dns=:: \
    shared-users=unlimited username=1048393940 wireless-enc-algo=none \
    unlimited username=1035679667 wireless-enc-algo=none wireless-enc-key="" \
    wireless-psk=""
add caller-id=BE:4F:19:7F:47:1C customer=admin disabled=no ipv6-dns=:: \
    shared-users=unlimited username=1038142785 wireless-enc-algo=none \
add caller-id=AA:7D:2A:52:84:71 customer=admin disabled=no ipv6-dns=:: \
    shared-users=unlimited username=1084396198 wireless-enc-algo=none \
add caller-id=1C:02:19:E8:42:DF customer=admin disabled=no ipv6-dns=:: \
    shared-users=unlimited username=1057975361 wireless-enc-algo=none \
add caller-id=10:3F:44:71:D3:04 customer=admin disabled=no ipv6-dns=:: \
    shared-users=unlimited username=1042779034 wireless-enc-algo=none \
    unlimited username=1037484606 wireless-enc-algo=none wireless-enc-key="" \
    wireless-psk=""
    unlimited username=1057944521 wireless-enc-algo=none wireless-enc-key="" \
    wireless-psk=""
    unlimited username=1013332096 wireless-enc-algo=none wireless-enc-key="" \
    wireless-psk=""
    unlimited username=1019470738 wireless-enc-algo=none wireless-enc-key="" \
    wireless-psk=""
    shared-users=unlimited username=1033988985 wireless-enc-algo=none \
    unlimited username=1049947139 wireless-enc-algo=none wireless-enc-key="" \
    wireless-psk=""
    unlimited username=1086288892 wireless-enc-algo=none wireless-enc-key="" \
    wireless-psk=""
    shared-users=unlimited username=1074459977 wireless-enc-algo=none \
    unlimited username=1081857114 wireless-enc-algo=none wireless-enc-key="" \
    wireless-psk=""
    unlimited username=1090556358 wireless-enc-algo=none wireless-enc-key="" \
    wireless-psk=""
    unlimited username=1050147082 wireless-enc-algo=none wireless-enc-key="" \
    wireless-psk=""
add caller-id=B8:C3:85:2F:97:D8 customer=admin disabled=no ipv6-dns=:: \
    shared-users=unlimited username=1008192570 wireless-enc-algo=none \
    unlimited username=1039659003 wireless-enc-algo=none wireless-enc-key="" \
    wireless-psk=""
    unlimited username=1015944296 wireless-enc-algo=none wireless-enc-key="" \
    wireless-psk=""
add caller-id=F6:9E:46:13:F8:78 customer=admin disabled=no ipv6-dns=:: \
    shared-users=unlimited username=1035425258 wireless-enc-algo=none \
    unlimited username=1037963149 wireless-enc-algo=none wireless-enc-key="" \
    wireless-psk=""
add caller-id=18:19:D6:DD:6D:29 customer=admin disabled=no ipv6-dns=:: \
    shared-users=unlimited username=1001253691 wireless-enc-algo=none \
    unlimited username=1025085692 wireless-enc-algo=none wireless-enc-key="" \
    wireless-psk=""
    unlimited username=1095651633 wireless-enc-algo=none wireless-enc-key="" \
    wireless-psk=""
    shared-users=unlimited username=1088877398 wireless-enc-algo=none \
    unlimited username=1003842863 wireless-enc-algo=none wireless-enc-key="" \
    wireless-psk=""
add caller-id=0E:7F:38:C1:75:9F customer=admin disabled=no ipv6-dns=:: \
    shared-users=unlimited username=1073080068 wireless-enc-algo=none \
    unlimited username=1030980924 wireless-enc-algo=none wireless-enc-key="" \
    wireless-psk=""
    unlimited username=1044623159 wireless-enc-algo=none wireless-enc-key="" \
    wireless-psk=""
    unlimited username=1033065220 wireless-enc-algo=none wireless-enc-key="" \
    wireless-psk=""
add caller-id=24:6F:8C:B3:46:0D customer=admin disabled=no ipv6-dns=:: \
    shared-users=unlimited username=1029466713 wireless-enc-algo=none \
    unlimited username=1013736538 wireless-enc-algo=none wireless-enc-key="" \
    wireless-psk=""
    unlimited username=1035796470 wireless-enc-algo=none wireless-enc-key="" \
    wireless-psk=""
    unlimited username=1029842512 wireless-enc-algo=none wireless-enc-key="" \
    wireless-psk=""
    unlimited username=1065997896 wireless-enc-algo=none wireless-enc-key="" \
    wireless-psk=""
    unlimited username=1033287525 wireless-enc-algo=none wireless-enc-key="" \
    wireless-psk=""
    shared-users=unlimited username=1027499917 wireless-enc-algo=none \
    unlimited username=1007321270 wireless-enc-algo=none wireless-enc-key="" \
    wireless-psk=""
    unlimited username=1045964624 wireless-enc-algo=none wireless-enc-key="" \
    wireless-psk=""
    unlimited username=1052122642 wireless-enc-algo=none wireless-enc-key="" \
    wireless-psk=""
    unlimited username=1069081117 wireless-enc-algo=none wireless-enc-key="" \
    wireless-psk=""
    unlimited username=1025285883 wireless-enc-algo=none wireless-enc-key="" \
    wireless-psk=""
add caller-id=20:32:6C:5F:D3:BC customer=admin disabled=no ipv6-dns=:: \
    shared-users=unlimited username=1049677783 wireless-enc-algo=none \
    unlimited username=1020163367 wireless-enc-algo=none wireless-enc-key="" \
    wireless-psk=""
    unlimited username=1027266263 wireless-enc-algo=none wireless-enc-key="" \
    wireless-psk=""
add caller-id=3E:0B:58:37:58:E1 customer=admin disabled=no ipv6-dns=:: \
    shared-users=unlimited username=1039473544 wireless-enc-algo=none \
    unlimited username=1087030853 wireless-enc-algo=none wireless-enc-key="" \
    wireless-psk=""
    unlimited username=1029015336 wireless-enc-algo=none wireless-enc-key="" \
    wireless-psk=""
    unlimited username=1001866788 wireless-enc-algo=none wireless-enc-key="" \
    wireless-psk=""
add caller-id=F8:C3:9E:FD:20:47 customer=admin disabled=no ipv6-dns=:: \
    shared-users=unlimited username=1027659576 wireless-enc-algo=none \
    unlimited username=1026329715 wireless-enc-algo=none wireless-enc-key="" \
    wireless-psk=""
    shared-users=unlimited username=1034999900 wireless-enc-algo=none \
    unlimited username=1045051345 wireless-enc-algo=none wireless-enc-key="" \
    wireless-psk=""
    unlimited username=1036780115 wireless-enc-algo=none wireless-enc-key="" \
    wireless-psk=""
    unlimited username=1082198362 wireless-enc-algo=none wireless-enc-key="" \
    wireless-psk=""
add caller-id=FC:42:03:C3:30:76 customer=admin disabled=no ipv6-dns=:: \
    shared-users=unlimited username=1014203699 wireless-enc-algo=none \
add caller-id=62:1F:ED:A7:F2:08 customer=admin disabled=no ipv6-dns=:: \
    shared-users=unlimited username=1018474051 wireless-enc-algo=none \
runningsystemchanger
Thu Oct 21, 2021 6:17 pm
Please behave yourself. You're coming here for help so be a bit humble and at least try to be decent. BTW, it's also in your own best interest that the people that are spending their free time to help us don't loose their motivation.
k6ccc
Thu Oct 21, 2021 6:28 pm
On a quick read, assuming that the internet modem is plugged into port 1 and the WiFi devices all plug into ports 2 - 5, I don't see any reason that ping is not working. However I note that you have NO FUNCTIONAL FIREWALL at all. Unless this is sitting in a closed lab environment, that is VERY dangerous and should be fixed immediately.
Curious why you have ports 2 - 5 on Bridge 1 and ports 6 - 10 and the SFP functionally idle?
More detailed read when I have more time.
anav
Thu Oct 21, 2021 6:38 pm
Yup looks like a router behind a router based on wan ip structure.
My observation is the funny NAT rules.......
SOURCENAT:
add action=masquerade chain=srcnat ???????????? Should be removed.
Whats wrong with the standard rule?? There is only one subnet and only one wan, so not sure need to anything more than the default.
add action=masquerade chain=srcnat out-interface-list=WAN ( or out-interface=ether1) But your interface lists are not defined!
Destination NAT, is also very wonky,
all
Multiple Issues:
a. The problem here is what is "all"??
I dont see either interface list or interface list members defined in the config?
b. For a fixed static IP one should delineate the wanip, but the wrong thing here on the port forwarding is stating AN IP on the WAN side of the router is the device being port forwarded to0??? You need to use the IP of the server that is behind the router????
The right format should be or at least typically is
add action=dst-nat chain=dstnat dst-port=3399 dst-address=192.168.0.2 \
protocol=tcp to-addresses=192.168.1.xx to-ports=80
marwan001
Thu Oct 21, 2021 8:13 pm
Thanks to everyone who tried to help me
Forgive me, because English is not my mother tongue, I try to communicate with you through Google, I hope the translation is correct. I'm not a network engineer and I don't understand anything except what I watch from YouTube
The goal of the network is to connect the internet to the subscribers inside the residential complex. I want to access the network via the internet and control all the devices connected to it, modem, router and access point.
Users browsing this forum: No registered users and 40 guests
