sealouiw
MikroTik RBGPOE - usable as PoE splitter?
Fri Oct 22, 2021 7:11 pm
Is it possible to use two RGBPOE to inject and extract power from cabling like this:
(inject power via 5.5x2.1mm plug) RGBPOE <---> RGBPOE (extract power via 5.5x2.1mm male-to-male adapter)
ConnyMercier
Forum Veteran
Forum Veteran
Re: MikroTik RBGPOE - usable as PoE splitter?  [SOLVED]
Fri Oct 22, 2021 11:25 pm
Soo i used it in the past as a PoE-Splitter, and it worked !
Tried it again today... still works =)
** I don't know why mikrotik doesn't advertise it as a Splitter!
Maybe it is missing some voltage protection circuit or something...
r00t
Long time Member
Long time Member
Sat Oct 23, 2021 12:31 am
Yes, it will work perfectly fine. It's just a passive device and 100% bi-directional. Injector and splitter for passive POE is exactly the same inside, only difference is in the connectors...
Users browsing this forum: No registered users and 10 guests
