keefus
CRS354-48G-4S+2Q+ SFP+ ports dropping after 3hrs
Thu Oct 28, 2021 8:03 pm
I have just installed a CRS354-48G-4S+2Q+ and I've found that the SFP+ ports are dropping after 3hrs. I am running SWOS 2.13 is this a known issue or has anyone else come across the issue.
Cheers
Keefus
Zacharias
Re: CRS354-48G-4S+2Q+ SFP+ ports dropping after 3hrs
Thu Oct 28, 2021 8:25 pm
Did you try with RouterOS and see if the problem remains ?
I can see in 6.49 *) sfp - improved link stability for 10G, 25G and 40G modules on CRS309, CRS312, CRS326-24S+2Q+ CRS354 and CCR2004 devices;
keefus
Thu Oct 28, 2021 10:17 pm
No as its a working site. I'll try both ways on a demo kit in the office next week and see if i can replicate
keefus
Fri Oct 29, 2021 12:24 pm
I'm also using 2.13p sware as this is the latest one
keefus
Mon Nov 01, 2021 3:57 pm
I have found this issue is not just on SFP but also on ethernet ports.... I think there is an issue on the VLAN's within the software. Any idea how I flag this up to Mikrotik???? I replaced the 48port switch with another 48port switch and the same issue happened. I resolved the issue by installing 2 x 24 port POE (CRS328-24P-4S+RM) and no issues 3+ days later.
Zacharias
Tue Nov 02, 2021 7:09 pm
Search in the forum for similar issues, for example viewtopic.php?t=160561&hilit=crs354
You can contact support here https://mikrotik.com/support
keefus
Wed Nov 10, 2021 12:03 pm
couple of things I have found and was wondering about the working of routeros and switchos..... I have upgraded routeros to 6.49 and upgraded routerboard does this have a direct effect on swos? I have also upgraded both partions on the switch with swos 2.13 as one was 2.13p on both switches would this cause issues as well. I'm struggling to replicate the issues I was having on site but on site I had 30+ ruckus h510's connected to it so now I'm wondering if my problems are with power.
Zacharias
Wed Nov 10, 2021 4:44 pm
No...
Users browsing this forum: No registered users and 18 guests
