salt
Output Network in BGP Peer on Winbox lists "unknown" in 7.1rc5
Fri Oct 29, 2021 11:36 am
Weather there are some Networks in Address List or not, in this dropdown there ist always the word "unknown" in the menu.
See in Attached Screenshot.
salt
Re: Output Network in BGP Peer on Winbox lists "unknown" in 7.1rc5
Fri Oct 29, 2021 11:42 am
Just wanted to add the necessary information from normis, and red that only cli errors should be reported, so sorry,
see this as friendly reminder, i have overred that in first attemp.
When reporting an issue, please follow this template:
Version number (if the issue is upgrade related, specify which version was installed before as well);
-> Updated from 6.48.6 to 7rc.1 then all minor steps till rc5, error occured in every minor release
Router's model;
-> CCR1036
Steps to reproduce the issue;
-> Add new BGP peer and open output-network dialog on the tab
Configuration export (use '/export hide-sensitive' command);
Any additional information that would help troubleshoot the issue (screenshots, debug logs, etc.).
mrz
Fri Oct 29, 2021 11:45 am
Thank you for the report, this is a winbox cosmetic issue, we will fix it in the next RC version.
Currently use CLI to set networks.
ahmadzai
Tue Dec 21, 2021 9:06 am
Same issue here but still no luck to solve and back downgrade the version from 7.1 to 6.49.2. my local prefix was not working advertised via BGP Network in version 6.49.2.
Maggiore81
Trainer
Trainer
Thu Dec 23, 2021 7:38 am
That tip should be added to the WIKI.
I searched for hours...
mducharme
Trainer
Trainer
Thu Dec 23, 2021 7:51 am
Probably you do not have an IGP route for your local prefix. In RouterOS v6 there was a synchronize option for BGP networks, where you could set synchronize=no or synchronize=yes. The option is now fixed to synchronize=yes and cannot be changed, so you won't advertise the prefix unless you have a local IGP route for that same prefix as well.
ahmadzai
Mon Dec 27, 2021 6:05 am
Dear Sir,
I have added a blackhole route also for my Public IP prefix but not worked.
Users browsing this forum: No registered users and 75 guests
