ffries
[Request] Disable network led in RouterOS
Fri Oct 29, 2021 12:45 pm
Dear all,
RouterOS allows to disable LEDs but this is not always possible.
Examples: CCR2004-1G-12S+2XS and CRS312-4C+8XG
Normally, all LEDs should be controllable (by RouterOS).
But RouterOs says that LED cannot be switched-off.
Another example, I purchased a CRS305-1G-4S+in for my parents and it is passive cooling (with a lot of hole in casing).
But there is so much light that it is nearly unusable, for example in a sleeping room.
My parents are annoyed by the light in the living room.
On my previous switches (Cisco), I could switch off all LEDs.
For example the Cisco SG350-10 LEDS can be turned-off.
As a result, I could use it in my sleeping-room.
Maybe Mikrotik is not taking this issue seriously, but for home use, this is quite unacceptable to have dozens of LEDs blinking constantly.
Please study this issue seriously.
Kind regards,
French Friens
krafg
Re: [Request] Disable network led in RouterOS
Tue Nov 16, 2021 5:36 pm
For all leds and little displays that are a powerful laser for eyes at night and you can't control powering state or bright level, I use polarizing film sheet to lower the brightness. I know that is not the best, but it can help a lot.
Regards.
Users browsing this forum: Bing [Bot], glueck05, marekm and 22 guests
