TUNG0407
OSPF receive one dst-address with two gateway
Mon Nov 01, 2021 8:05 pm
Dear ALL,
I'm setting the MPLS + OSPF network, the CPE are connecting to the two PE router, the CPE can receive the dst address from the two PE router, but i want to force the traffic via the PE router 1(10.1.8.1) , how to do this?
TungHo
joegoldman
Forum Veteran
Forum Veteran
Re: OSPF receive one dst-address with two gateway
Mon Nov 01, 2021 11:45 pm
You might be able to use filters to adjust distance on one vs the other imported route - as changing the interface cost will affect both.
Alternatively, deliver both PE's on a separate ports, or if it must remain single port, split it out in VLANs, this way you can adjust the cost of PE2 slightly higher so it always prefers PE1.
TUNG0407
Tue Nov 02, 2021 5:16 am
i tried to use the filter to adjust distance, but donesnt work. Is there possible to receive two same dst-address split to two route?
our upstream provide said the circuit cant support vlan passthrough and Q-in-Q,
Users browsing this forum: No registered users and 50 guests
