crusherlay
Dual Wan
Wed Nov 03, 2021 5:46 pm
Hello Everyone !
Want to ask a question
Which router can manage this below route table ?
if router have 4 port Lan/wan
port 1 & 2 use as wan ( dual wan )
port 3 & 4 use as lan ( different two router/ap )
port 1 wan use only for lan 3
port 2 wan use only for lan 4
if wan 1 fail use failover on lan 4
if wan 2 fail use failover on lan 3
that can be possible ?
thanks
brixsat
Re: Dual Wan
Fri Dec 24, 2021 12:24 am
sky is the limit with mikrotik
anav
Re: Dual Wan
Fri Dec 24, 2021 2:10 am
Yes very easy to do!
Hint, nothing is easy, but with the help of people here you will be singing and dancing and not forever configuring your router..
Multi-WAN scenarios are very common.
Users browsing this forum: miker3000, unhuzpt, zalciukaz and 102 guests
