abeluko
RB750GL loop in boot
Thu Nov 04, 2021 7:44 pm
Hi, I have a problema with my RB750GL, when I plug the power aparently is booting, but past 6 seconds aprox, all lan leds blink twice and then reboot, and this loop never ends…
Note: the ACT led is always on, this maybee will be important.
some idea how can fix it ??
abeluko
Re: RB750GL loop in boot
Sat Nov 06, 2021 4:19 pm
I tried to use Netinstall to restore, but has useless...
form support say me this, and not work... have some any idea to restart my device??
Please check the article at:
https://help.mikrotik.com/docs/display/RKB/Reboot+loop
Please try to perform Netinstall:
https://help.mikrotik.com/docs/display/ROS/Netinstall
Power off the device, press the reset button, power on the device and keep the reset button pressed for 1-2 minutes.
While holding the reset button during Netinstall - please pay attention to how LEDs behave. Check if the device goes into the loop while the button is pressed.
abeluko
Tue Nov 16, 2021 11:23 pm
please one by one, do not answer all at once
krafg
Thu Nov 18, 2021 11:42 am
Netinstall is the only procedure that you can do to fix it.
If you can't do netinstall, you can't do anything for your device.
Regards.
Users browsing this forum: Bing [Bot] and 35 guests
