mux2hot
failed to register on network
Fri Nov 05, 2021 3:41 pm
Hi!
I am a new owner of Microtik device (WRL LHGG LTE6 KIT, RouterOS v6.49) and I am experiencing a situation where LTE link goes down with error message "failed to register on network". What could be reason for that and how to debug the failure? And any suggestion how to fix it would be ideal.
baz
Re: failed to register on network
Mon Mar 14, 2022 11:32 am
I have same problem, any idea?
holvoetn
Mon Mar 14, 2022 11:40 am
Are you sure your APN settings are correct for the provider you want to use ?
Users browsing this forum: AndreKR, MartinsG, mstanciu and 78 guests
