Naomie
firewall configuration in Mikrotik
Tue Nov 09, 2021 9:43 am
good day, to all
please I need your help, in the situation that I found myself into, and I need your assistance please???
automatically enables Firewall Rules in Mikrotik if it cannot ping a partilucar IP??
Example: if IP address 192.168.0.1 goes down, the script needs to then disable 2 NAT rules and then enable 2 others ??
i really need help and I'm grateful.
ConnyMercier
Forum Veteran
Forum Veteran
Re: firewall configuration in Mikrotik
Fri Nov 12, 2021 11:59 am
Step 1: Trigger
You can use "Scheduler" or "Netwatch" to trigger Scripts.
Step 2: Script A (IP-Online)
The quick and easy way is to use "comment" to find the correct NAT-Rules
After Creating the needed NAT-Rules simply add a unique string to you comments.
In the following exemple the comment must contain "abcdef" or "123456"
/ip firewall nat set [find where comment~"abcdef"] disabled=yes
/ip firewall nat set [find where comment~"123456"] disabled=no
Step 3: Script B (IP-Offline)
For Script B you just have to do the reverse
/ip firewall nat set [find where comment~"abcdef"] disabled=no
/ip firewall nat set [find where comment~"123456"] disabled=yes
rextended
Fri Nov 12, 2021 8:11 pm
Right, but I prefer this syntax:
/ip firewall nat disable [find where comment~"abcdef"]
/ip firewall nat enable [find where comment~"123456"]
# or better
ConnyMercier
Forum Veteran
Forum Veteran
Fri Nov 12, 2021 9:03 pm
As always, thank you @rextended !
Users browsing this forum: baragoon and 54 guests
