I have a simple setup, 2 Routerboards running 6.45.8. Ethernet 1 connects to the lan on each side, and the wireless interface extends the network between 2 switches. Ether 1 & wireless interface are bridged. Cisco switches configured for trunking on the connecting port with a native vlan 8.
I just want the two switches to form a trunk across the wireless connection that is bridged together. Making the wireless connection is no problem. Getting the trunk to work across it has been a challenge.
vlan 8 is native vlan for trunk, so would like this to be the untagged bridged interface IP
vlan 5,6,7,10,44 should be tagged across the bridge/wireless link to the other switch
tried many combinations to accomplish this simple task, but cannot make it work. The config is rather simple and currently looks like this on both devices:
add name=bridge1 protocol-mode=none
/interface wireless
set [ find default-name=wlan1 ] ssid=MikroTik
add authentication-types=wpa2-psk eap-methods="" management-protection=\
allowed mode=dynamic-keys name=5GBH supplicant-identity="" \
wpa2-pre-shared-key=xxxxxxxxxx
/interface wireless
set [ find default-name=wlan2 ] band=5ghz-a/n/ac channel-width=\
20/40/80mhz-Ceee country="united states3" disabled=no frequency=auto \
frequency-mode=manual-txpower mode=ap-bridge name=xx-xxx-5G-AP \
radio-name=xx-xxx-5G-AP security-profile=5GBH ssid=A3Prod5GBH vlan-mode=\
use-tag wireless-protocol=802.11
/interface wireless nstreme
set xx-xxx-5G-AP enable-nstreme=yes
add bridge=bridge1 interface=xx-xxx-5G-AP
/interface bridge vlan
add bridge=bridge1 tagged=ether1,xx-xxx-5G-AP vlan-ids=7
add bridge=bridge1 tagged=ether1,xx-xxx-5G-AP vlan-ids=44
add bridge=bridge1 tagged=ether1,xx-xxx-5G-AP vlan-ids=5
add bridge=bridge1 tagged=ether1,xx-xxx-5G-AP vlan-ids=6
add bridge=bridge1 tagged=ether1,xx-xxx-5G-AP vlan-ids=10
add bridge=bridge1 untagged=ether1,xx-xxx-5G-AP vlan-ids=8
add address=x.x.x.x/24 interface=bridge1 network=x.x.x.x
add distance=1 gateway=x.x.x.x
What am I missing to allow trunk to establish across wireless bridge?
