tom65
Romon discover
Thu Nov 18, 2021 4:32 pm
Hi all,
I need to retrieve results from /tools/romon/discover with my python mikrotik api but as I understand, only print/getall is possible.
Other option in lieu of api I thought to commit output of /tools/romon/discover into a file.
I need to build an inventory of all mikrotik devices behind the vpn connected routers of my vpn server for management/upgrade purposes.
All the mikrotiks have romon turned on.
Someone with an idea?
Jotne
Re: Romon discover
Thu Nov 18, 2021 5:05 pm
Not directly a reply to your question, but I do use syslog to send out all neighbor a device find and then make a table of it.
Se my signature for more info.
tom65
Re: Romon discover
Thu Nov 18, 2021 8:23 pm
Thanks for the reply. I like the presentation on your picture. Sadly I need romon since I have layer 3 between devices and cannot thus use "neighbors" since it only supports layer 2.
I have about 250+ vpn connected routers to my VPN server CHR. Behind these VPN connected routers, I have a stack of routers/switches/APs that I would like to discover and ultimately manage through python mikrotik_API. I thought, if I cannot get the romon discovery hosts by API, I could at least write them to a file and retrieve and build them in a list to build my list.
Jotne
Re: Romon discover
Thu Nov 18, 2021 8:55 pm
If I can get output of "/tools romon discover" in to an variable (seem to not be possible), you can send it using syslog and get same graph as neighbors.
tom65
Re: Romon discover
Fri Nov 19, 2021 8:57 am
If I can get output of "/tools romon discover" in to an variable (seem to not be possible), you can it using syslog and get same graph as neighbors.
Ahh, thanks. You gave me an idea. I will try to put it to local log file and just filter for that.
Users browsing this forum: No registered users and 29 guests
