ultiman
No poe but net on these ports
Fri Nov 19, 2021 6:51 pm
Hello forum memberrs,
does someone know what happen here ? in the picture ?
kind regards from Germany
ulti
k6ccc
Re: No poe but net on these ports
Mon Nov 22, 2021 8:33 pm
Are you asking about the short circuit on port 2? Most likely a bad cable.
ultiman
Mon Nov 22, 2021 11:31 pm
Hello and thank you Jim,
no the RED one is in perfect conditions, it has detected a LAN Cabel without need of POE.
The missing Part is "waiting for load" so one of the Power distri. boards had a mal funktion or needs a reset ?
I can interchange them and the 8 Block POE is moved to other ports
Users browsing this forum: No registered users and 47 guests
