ofirule
[Feature request] Copy and paste on web-ui terminal
Sat Nov 20, 2021 12:41 pm
From at least version 6.44.2 forward (probably even before) it's impossible to copy using Ctrl+c or pasting scripts using Ctrl+v or any other method , to the web ui terminal.
Allowing copy and paste in the web ui is very usefull and saves a lot of time.
It's probably a a helpfull feature for a lot of customers
krafg
Re: [Feature request] Copy and paste on web-ui terminal
Sat Nov 20, 2021 3:15 pm
Ctrl + C on every terminal is used for terminate the execution if a command.
ofirule
Sun Jan 16, 2022 11:22 pm
You are correct, in terminal I use `Ctrl + Shift + C` but on web pages `Ctrl + C` should do the job
Users browsing this forum: Bing [Bot], jrypacek, majestic, rootbodnar and 208 guests
