danergo
Howto get the PTR record for a single IP?
Thu Nov 25, 2021 12:22 pm
Folks,
I'm looking for pretty obvious need: getting the PTR (string) for an IP address in my script.
For example: having "18.196.34.14" in a variable, and I want to get it's PTR (name): "ec2-18-196-34-14.eu-central-1.compute.amazonaws.com."
(even if it's a non-authoritative answer)
How can I do it with scripts? Or I shall use an external online service for this?
ConnyMercier
Forum Veteran
Forum Veteran
Re: Howto get the PTR record for a single IP?
Thu Nov 25, 2021 12:38 pm
Try the :resolve command
Exemple :
[admin@MikroTik] > :put [:resolve 18.196.34.14]
Jotne
Thu Nov 25, 2021 1:30 pm
To use it in the script
:local ptr  [:resolve 18.196.34.14]
This will resolve the IP and save it to the variable ptr
Try Splunk> to monitor your MikroTik Router(s). How to set it up. :mrgreen:
MikroTik->Splunk
danergo
Thu Nov 25, 2021 1:31 pm
OMG, thank you.
(I read a lot of old post and by that time this was unsupported)
danergo
Thu Nov 25, 2021 1:37 pm
Thank you! How can I make sure to not crash my script if I give it some invalid address? Like:
:local ptr  [:resolve 192.168.88.100]
danergo
Thu Nov 25, 2021 1:44 pm
I just have to put it into ":do" ?
Jotne
Thu Nov 25, 2021 7:52 pm
You can use
on-error
:do {
	:put $ptr
} on-error={
	:put "Could not resolve"
MikroTik->Splunk
Users browsing this forum: No registered users and 8 guests
