gateff
webfig strange bug
Thu Nov 25, 2021 4:01 pm
how to fix that?
Successful login shows Terminal page first, if i hit WebFig Button that page appears:
note: there is no easy access to the cAP, it is in production also - so "reset" is not a great option.
Is there a quick fix?
Thank you!
pe1chl
Re: webfig strange bug  [SOLVED]
Thu Nov 25, 2021 4:43 pm
I heard that it helps to clear cache and cookies on the PC.
infabo
Long time Member
Long time Member
Thu Nov 25, 2021 9:04 pm
I have this bug too. When I login, QuickSet button is active. But it shows the interface list instead. As I hardly use webfig - I do not care much. But it is this way for some RCs already. So MT QA guys seem to not use webfig much either...
pe1chl
Thu Nov 25, 2021 9:26 pm
It works for me. Switching between QuickSet and WebFig buttons is a bit quirky, but otherwise it works OK.
gateff
Fri Nov 26, 2021 11:22 am
Hitting "refresh" browser button, fill login credentials - works, clear cache also, but until i switch between WebFig -> Terminal ->WebFig
Best Regards!
Users browsing this forum: anav and 187 guests
