otorenik
subnets
Thu Nov 25, 2021 9:14 pm
HI,
can you help me?
I have three LANs - Bridges on CRS326:
ISP on ether 1
Bridge A: 192.168.1.0/24 (2-22) CRS326
Bridge B: 192.168.2.0/24 (23 - spf1) connected with CSS326 number1
Bridge C: 192.168.3.0/24 (24-spf2) connected with CSS326 number2
On Bridge B, I have connected NAS server (Qnap)
On Bridge C, I have connected another server
I CAN ping all of them from any bridge and connect to Internet
Issue:
I can see my servers only when am I in same subnet ??
When I am connected with PC (win10) on different subnet ,then it is not working (It doesn´t connect)except ping????
Please for help and sorry for my english ;)
mkx
Re: subnets
Fri Nov 26, 2021 2:46 pm
It is probably issue with firewall settings, but it's impossible to say for sure ... unless you post (anonymized) configuration. Execute command /export hide-sensitive file=anynameyouwish inside terminal window, fetch resulting file, open it in text editor, obfuscate any remaining sensitive information (e.g. public IP address or PPPoE username and password) and copy-paste it in post inside [code] [/code] environment.
anav
Re: subnets
Fri Nov 26, 2021 3:09 pm
In short,
Please post your config,
otorenik
Re: subnets
Sun Nov 28, 2021 10:42 am
Thank you for helping me;
I have been adding new test bridge 40....
Here is configuration:
add name=bridge20
add name=bridge30
add name=bridge40_test
add name=bridge_Main priority=0x9000
add name=WAN
add name=LAN
add name=dhcp ranges=192.168.10.2-192.168.10.254
add name=pool20 ranges=192.168.20.2-192.168.20.254
add name=pool30 ranges=192.168.30.2-192.168.30.254
add name=pool40 ranges=192.168.40.2-192.168.40.254
add address-pool=pool30 disabled=no interface=bridge30 name=dhcp3
add address-pool=pool20 disabled=no interface=bridge20 name=dhcp2
add address-pool=dhcp disabled=no interface=bridge_Main name=dhcp1
add address-pool=pool40 disabled=no interface=bridge40_test name=dhcp40_test
add bridge=bridge_Main interface=ether2
add bridge=bridge_Main disabled=yes interface=ether19
add bridge=bridge_Main interface=ether4
add bridge=bridge_Main interface=ether5
add bridge=bridge_Main interface=ether6
add bridge=bridge_Main interface=ether7
add bridge=bridge_Main interface=ether8
add bridge=bridge_Main interface=ether9
add bridge=bridge_Main interface=ether10
add bridge=bridge_Main interface=ether11
add bridge=bridge_Main interface=ether13
add bridge=bridge_Main interface=ether14
add bridge=bridge_Main interface=ether15
add bridge=bridge_Main interface=ether16
add bridge=bridge_Main interface=ether17
add bridge=bridge_Main interface=ether18
add bridge=bridge_Main disabled=yes interface=ether20
add bridge=bridge_Main interface=ether3
add bridge=bridge_Main interface=ether21
add bridge=bridge_Main interface=ether22
add bridge=bridge20 interface=ether23
add bridge=bridge30 interface=ether24
add bridge=bridge20 interface=sfp-sfpplus1
add bridge=bridge30 interface=sfp-sfpplus2
add bridge=bridge40_test interface=ether19
add bridge=bridge40_test interface=ether20
add interface=ether1 list=WAN
add interface=bridge_Main list=LAN
add interface=bridge30 list=LAN
add interface=bridge20 list=LAN
add address=192.168.10.1/24 interface=bridge_Main network=192.168.10.0
add address=192.168.20.1/24 interface=bridge20 network=192.168.20.0
add address=192.168.30.1/24 interface=bridge30 network=192.168.30.0
add address=192.168.40.1/24 interface=bridge40_test network=192.168.40.0
/ip dhcp-client
add disabled=no interface=ether1
add address=192.168.10.0/24 dns-server=8.8.8.8 gateway=192.168.10.1
add address=192.168.20.0/24 dns-server=8.8.8.8 gateway=192.168.20.1
add address=192.168.30.0/24 dns-server=8.8.8.8 gateway=192.168.30.1
add address=192.168.40.0/24 dns-server=8.8.8.8 gateway=192.168.40.1
set servers=8.8.8.8
/ip firewall address-list
add address=192.168.10.0/24 comment=main_bridge list=moji_LANi
add address=192.168.20.0/24 comment=bridge20 list=moji_LANi
add address=192.168.30.0/24 comment=bridge30 list=moji_LANi
add address=192.168.40.0/24 comment=bridge40_test list=moji_LANi
add action=accept chain=input src-address-list=moji_LANi
/ip kid-control device
anav
Re: subnets
Sun Nov 28, 2021 6:07 pm
Okay so the switch is also a router and you are using bridges to dish subnets to sets of ports vice using VLANs.
Four bridges
Four pools
Four dhcp servers.
so far so good.
(1) Why is bridge test NOT part of the LAN interface group??
(2) if this is acting as a router why dont you have any firewall rules??
otorenik
Re: subnets
Mon Nov 29, 2021 10:22 am
Yes, I forgot to assign bridge40 test - but it is not matter because important bridges are main, 20 and 30...;)
About firewall - I am testing without any rules to resolute issue.
Do I need forward port 443 for traffic between subnets?
anav
Re: subnets
Mon Nov 29, 2021 3:16 pm
Sorry if you are connected to the internet without any rules I will not help further.
The default firewall rules are safe and do not stop any connectivity (do not cause issuesa) and by removing them you have no security.
Sob
Re: subnets
Mon Nov 29, 2021 9:06 pm
If there's no firewall on router, then it's certainly not blocking access between your subnets. It could be the other devices, maybe their firewalls don't like access from other than their local subnet.
otorenik
Re: subnets
Wed Dec 01, 2021 8:48 am
Thanks....I think "Sob" are right......
I would like to have NAS on different subnet.....but I am afraid it is not solution to do this.
When I connected in same subnet with PCs it works fine......but......:(
jvanhambelgium
Forum Veteran
Forum Veteran
Re: subnets
Wed Dec 01, 2021 9:18 am
All these sorts of "discovery" mechanisms are design to only work WITHIN THE SAME LAN / IP-SUBNET !!
So it might be very normal certain devices don't automagically "show" up if your main PC is sitting in another subnet.
The bottom line, can you connect manually ? Eg on your PC on 192.168.1.x can you for example reach a QNAP managemt interface on https://192.168.2.x
Can you for example RDP to a server in 192.168.3.x
What applications / ports / services are you tryingg to use across the different subnets ?
otorenik
Re: subnets
Wed Dec 01, 2021 9:18 pm
Yes,
I can connected to WEB management QNAP(static address) on different subnet, but I cant find server over Qfinder (asked on QNAP forum-they told me no-go).
Also I have another server bOS Configurator (static address) for smart living house configure.....but I can not connected to server, only on WEB Client!
They told me that I need to open 443 port.
Do I need top open specially on FW?
BR
Sob
Re: subnets
Wed Dec 01, 2021 11:03 pm
No firewall = everything is open (it's btw good idea to fix that). And port 443 is usually used by https, so web. Seems unusual that if would be used for some kind of autodiscovery.
otorenik
Re: subnets
Thu Dec 02, 2021 9:15 pm
Yes, server address is https://192.168.40.x/
otorenik
Re: subnets
Thu Dec 02, 2021 10:25 pm
and also port 16100
Sob
Re: subnets
Thu Dec 02, 2021 10:55 pm
I'm not sure what useful info I can add. Firewall in RouterOS allow everything by default (when it's blank), so anything you don't block can pass through. Different subnets may be problem, because manufacturers of other devices may not support that scenario. In some cases you may be able to live without their tools.
For example file sharing with NAS between subnets is no problem, you just won't be able to discover it automatically, but you can access it by IP address, or configured hostname (either locally or on router). Either make a shortcut for it, or map network drive, you do it once and it's there. Configuration should also be no problems, NASes usually have web interface, which you again can access using IP address.
With something else it may be more problematic. If the only way to control something is proprietary tool that simply doesn't support devices in other subnets, you may be out of luck there.
mkx
Re: subnets
Fri Dec 03, 2021 9:39 am
In addition to what @sob mentioned: since security became high-profile stuff lately, quite some gadgets won't allow connections (either management only or even service) from IP addresses outside device's own IP subnet. So check settings to see if some sort of firewall on device blocks such connections.
otorenik
Re: subnets
Fri Dec 03, 2021 4:16 pm
ok, how to open or forward port
-example: 16100 from 192.168.10.x to 192.168.20.x?
Is it possible to check in Winbox which ports are open?
Thank you
BR
otorenik
Re: subnets
Fri Dec 03, 2021 4:46 pm
Also this server using multicast. Is it here maybe issue?
tdw
Re: subnets
Fri Dec 03, 2021 5:57 pm
Yes, only unicast traffic is routed unless you install and configure the multicast package.
spynappels
Re: subnets
Fri Dec 03, 2021 8:35 pm
Thank you
BR
Ports are open between LAN subnets unless explicitly blocked using the firewall.
Users browsing this forum: AndreKR, Bing [Bot], JRnet, mkx, PLJ020, Tony93 and 112 guests
