spisarau
Cisco ASA and Mikrotik IPSEC
Mon Nov 29, 2021 10:20 am
I'm trying to configure the following configuration
when everything's done I'm getting the following situation
cisco has the following configuration
the connection cannot be established for the second network. If I disable a policy for the first network PH2 State is establishing.
Could anyone help me to resolve this issue?
SPKA16
Re: Cisco ASA and Mikrotik IPSEC
Mon Nov 29, 2021 12:01 pm
The Cisco most likely wants to seperate SA's
Try to set both policies to level=unique
spisarau
Mon Nov 29, 2021 12:56 pm
unfortunately same result
mrz
Mon Nov 29, 2021 1:02 pm
ipsec debug logs should show more info on why second policy fails.
spisarau
Mon Nov 29, 2021 1:22 pm
no info about second network
spisarau
Mon Nov 29, 2021 1:30 pm
when I disabled and enabled policy again I got a following error
spisarau
Re: Cisco ASA and Mikrotik IPSEC  [SOLVED]
Tue Nov 30, 2021 10:02 am
Thanks.
This advice has helped. But to make things work PFS group of proposal should be set to none.
Users browsing this forum: Amazon [Bot] and 65 guests
