namespace
SNMP - snmpset ifAlias or ifAdminStatus - no effect, can't change
Mon Nov 29, 2021 1:28 pm
it's posible change interface description or disable interface via SNMP?
snmpwalk -c kancel -v2c ip.lan .1.3.6.1.2.1.31.1.1.1.18.8
IF-MIB::ifAlias.8 = STRING: STB
snmpset -c kancel -v2c ip.lan .1.3.6.1.2.1.31.1.1.1.18.8 s test
IF-MIB::ifAlias.8 = STRING: test
Return value looks OK, but no change
Same with OID .1.3.6.1.2.1.2.2.1.7 when i want disable interface.
RB2011, RB493AH, CCR1036
v6.49.1
Thnx
Jotne
Re: SNMP - snmpset ifAlias or ifAdminStatus - no effect, can't change
Mon Nov 29, 2021 3:18 pm
Did not work on my hEX router. SNMP string is set to write ok.
Not sure what you can and can not with SNMP.
What is your goal? Can you use oter tools: API SSH HTTP Script etc
Interface numbering can also be strange, so two router can have different number. Needs to be tested before changeing.
Eks:
IF-MIB::ifName.1 = STRING: ether1
IF-MIB::ifName.2 = STRING: Bridge1
IF-MIB::ifName.3 = STRING: ether3
IF-MIB::ifName.4 = STRING: ether4
IF-MIB::ifName.5 = STRING: ether5
IF-MIB::ifName.6 = STRING: pptp-in1
IF-MIB::ifName.8 = STRING: ether2
IF-MIB::ifName.12 = STRING: VLAN20
namespace
Mon Nov 29, 2021 3:32 pm
Eks:
I use uniform SNMP management
  • set description when device/customer/service is connect to port
  • disable port when i need
99% other devices can set description with this IF-MIB OID.
I dont want to use API for simple things
Thnx
tdw
Mon Nov 29, 2021 4:18 pm
The Mikrotik SNMP implementation is mostly read-only
Jotne
Mon Nov 29, 2021 5:47 pm
From the manual:
Since RouterOS v3, SNMP write is supported for some functions
Seems that not much has changed in many years :)
Users browsing this forum: Amazon [Bot] and 82 guests
