RyperX
rb5009 Partitioning not working
Wed Dec 01, 2021 3:35 pm
Hey,
i got today my rb5009 and the first thing what i tried was to repartioning the storage. So that i can keep the "stable" pre Installed Firmware 7.0.5 and upgrade to latest RC.
Sadly partitioning is not working, after failing on 7.0.5 i upgrade to latest RC 7.1rc7 but still paritioning is not working.
Any idea?
Best regards
hostank
Re: rb5009 Partitioning not working
Fri Dec 31, 2021 5:45 am
I also encountered this problem...
Is there any solution now?
I already upgrade to 7.1.1 stable
j0n1th4n
Wed Jan 05, 2022 4:19 pm
Just got my RB5009. Same problem, even with the latest 7.2rc1.
When i try to repartition the device, everything seems to work but after the reboot there's only 1 partition.
I tried Web, Winbox and Telnet.
Will that be fixed in the future or is this feature not supported on this device?
huntermic
Fri Mar 25, 2022 3:10 pm
still not fixed in 7.2rc5 :?
brg3466
Thu Apr 07, 2022 4:23 am
still doesn't work on 7.2 stable
ObliteRon
Thu May 19, 2022 2:33 am
Is it supposed to be available on the RB5009?
According to the docs, it is only supported on MIPS, TILE and PowerPC RouterBOARD, and the RB5009 is ARM64.
brg3466
Thu May 19, 2022 4:09 am
Yes, it is supposed to support partitioning. I have CCR2004 as welll which is also a arm64 based, and it can be repartitioned.
mkx
Fri May 20, 2022 10:42 pm
It seems that docs are a bit outdated. Partitioning works on audience which is ARM (it's not usable with wifiwave2 driver though, not enough space to do upgrades if flash is partitioned).
Users browsing this forum: No registered users and 37 guests
