shunkica
Unable to export configuration on hAP mini 7.1
Thu Dec 02, 2021 8:20 pm
For some reason the DHCP client on my hAP mini stopped working on 7.1rc6 and I lost any ability to connect to it, even though all the clients connected to it (both ethernet and wlan) had access to the internet.
I reset the router using the hardware button, set up my configuration again, and then saw that 7.1 is released, so I upgraded to that.
After update I noticed terminal is very slow, it takes about 2-3 seconds after starting it for it to become interactive and autocomplete is very slow as well.
I did /export , and the export takes a very long time printing lines very slowly, then stops after /ip pool and becomes unresponsive. Did the same thing over SSH, and the same thing happened, export stopped after /ip pool. Then I did the same thing but trying to export the config to a file. This also never finishes and leaves a ".in_progress file".
Under resource monitor I can see CPU is hammered 100% for about 15 seconds after executing /export, but after a while it goes back to 0-1-2% even though the export doesn't ever finish.
volkirik
Re: Unable to export configuration on hAP mini 7.1
Thu Dec 02, 2021 8:28 pm
same here.
one of many v7 bugs, probably
Jotne
Fri Dec 03, 2021 9:22 am
Export RouterOS 7.1 on:
SXT 5HPnD r2 (600Mhz) slow
SXT 5HPnD (400Mhz) weeeeery slow.
Some time when logging in on the 400MHz I do get "Console has crashed; please log in again."
Edit:
When trying to export the config from SXT 5HPnD (400Mhz), it does loos its client and Winbox may be disconnected (connected using cable)
volkirik
Sat Dec 04, 2021 11:31 am
Edit:
same here. please fix it, mikrotik
jhbarrantes
Mon Dec 06, 2021 3:45 pm
I've got exactly the same issue with the hAP-mini. But mysteriously, it is not happening with mAP lite, which I think it shares CPU (but different architecture)
Anyone knows if that's the correct place for reporting this kind of issues, or any other we find out in 7.1 ?
Thanks.
anav
Mon Dec 06, 2021 3:51 pm
NM...
tdw
Wed Dec 08, 2021 2:02 am
Same issue on a hAP lite with a fairly minimal configuration.
Upgraded from 6.48.6 to 7.1 by selecting upgrade channel in System > Packages. Export stalls after emitting the /ip dhcp-server section, the next would be /interface bridge port under v6.
Edit: If left in this state for some time the following messages appear in the terminal window followed by more of the export:
#error exporting /mpls/traffic-eng/path
#error exporting /routing/bgp/template
#error exporting /routing/pimsm/instance
Stalls again after /interface ovpn-server server, next would be /ip address. Continues after the following message:
#error exporting /interface/vpls/bgp-vpls
And again after /ipv6 nd, next would be /system clock. Continues after the following messages:
#error exporting /mpls/interface
#error exporting /mpls/ldp
#error exporting /mpls/ldp/accept-filter
#error exporting /mpls/ldp/advertise-filter
#error exporting /mpls/ldp/interface
#error exporting /mpls/ldp/local-mapping
#error exporting /mpls/ldp/neighbor
#error exporting /mpls/ldp/remote-mapping
#error exporting /mpls/traffic-eng/interface
#error exporting /mpls/traffic-eng/tunnel
#error exporting /routing/bgp/connection
#error exporting /routing/bgp/vpn
#error exporting /routing/pimsm/bsr/candidate
#error exporting /routing/pimsm/bsr/rp-candidate
#error exporting /routing/pimsm/interface-template
#error exporting /routing/pimsm/static-rp
Eventually finished well over 2 hours later!
Possibly something to do with MPLS and routing packages not previously being present, to save space only some individual packages were installed. Log from upgrade:
jan/02/1970 00:00:23 system,error broken package ppp-7.1-smips.npk
jan/02/1970 00:00:23 system,error broken package security-7.1-smips.npk
jan/02/1970 00:00:23 system,error broken package wireless-7.1-smips.npk
jan/02/1970 00:00:23 system,error broken package advanced-tools-7.1-smips.npk
jan/02/1970 00:00:23 system,error broken package dhcp-7.1-smips.npk
jan/02/1970 00:00:23 system,error broken package ipv6-7.1-smips.npk
jan/02/1970 00:00:23 system,info installed system-7.1
jan/02/1970 00:00:23 system,info crossfig will upgrade version 6 configuration
jan/02/1970 00:00:23 system,info router rebooted
shunkica
Wed Dec 29, 2021 1:38 am
Issue is still present in 7.1.1 and 7.2rc1
vrgpy
Tue Jan 25, 2022 3:08 am
I got the same issue in a hAP lite (RouterBOARD 941-2nD) on 7.1.1 (Dec/21/2021 11:53:05)
It starts the export and on some point it freezes.
Has no problem with: /system/backup
If a do a "Make supout.rif" the export section is empty. (viewed with https://mikrotik.com/client/supout)
With another device, a cAP ac (RBcAPGi-5acD2nD) this problem is not happening with 7.1.1
hrcho
Mon Feb 07, 2022 12:06 pm
Works ok with v7.2rc3, perhaps it is fixed in v7.2rc2 (2022-Jan-28):
*) route - fixed routing configuration export on SMIPS devices;
hecatae
Tue Feb 08, 2022 4:03 pm
That's great news, time to see if my hap lites will do what I need on 7.2rc3.
Edit, no they are still hanging and not accessible until rebooted.
hecatae
Thu Mar 24, 2022 9:26 pm
Anyone else testing 7.2rc5 on their SMIPS device?
My web interface will not load
DNS is failing to resolve
About to test export
> export
# jan/02/1970 00:22:09 by RouterOS 7.2rc5
# software id =
# model = RB941-2nD
# serial number =
add name=bridge1
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-onlyn country="united kingdom" disabled=no mode=station-pseudobridge ssid= wireless-protocol=nv2-nstreme-802.11
add name=WAN
add name=LAN
set [ find default=yes ] authentication-types=wpa-psk,wpa2-psk group-ciphers=tkip,aes-ccm mode=dynamic-keys supplicant-identity=MikroTik unicast-ciphers=tkip,aes-ccm
add bridge=bridge1 interface=wlan1
add interface=wlan1 list=WAN
add list=LAN
add interface=ether1 list=LAN
add interface=ether2 list=LAN
add interface=ether3 list=LAN
add interface=ether4 list=LAN
/ip dhcp-client
add interface=bridge1
/ip service
set www disabled=yes
set api disabled=yes
set api-ssl disabled=yes
/system package update
set channel=testing
took 30 seconds.
export verbose has a lot of things enabled that I do not need.
zerog
Fri Apr 22, 2022 9:52 am
Any updates on this?
fragtion
Fri Apr 22, 2022 11:43 am
Could this issue maybe be related to this one viewtopic.php?t=170883 ?
tdw
Fri Apr 22, 2022 1:49 pm
Difficult to say, I have one running v7.2 which idles at around 5% when showing interfaces and resources in Winbox. Exporting a near factory-default configuration does now complete, but takes around 2 minutes at 100% CPU and wlan connections will sometimes disconnect.
Upgrading to 7.2.1 eventually worked after a critical error and another wlan disconnection:
 11:16:40 system,error,critical,0,28168,38212,59248,0,21524,1376,44964,radius error while running customized default configuration script: std failure: timeout (13)
 11:16:50 wireless,info 76:4D:28:xx:xx:xx@wlan1: lost connection, received deauth: group key handshake timeout (16)
 11:16:55 wireless,info 76:4D:28:xx:xx:xx@wlan1 established connection on 2437000, SSID xxxxxxxxxxx
 11:17:07 wireless,info 76:4D:28:xx:xx:xx@wlan1: lost connection, unicast key exchange timeout
 11:17:09 wireless,info 76:4D:28:xx:xx:xx@wlan1 established connection on 2437000, SSID xxxxxxxxxxx
Now idles around 9%. Crashed during export (appears to have used previous system time, likely not updated due to crash)
 11:16:08 system,error,critical router was rebooted without proper shutdown
 11:16:09 system,error,critical kernel failure in previous boot
 11:16:09 system,error,critical out of memory condition was detected
 11:17:17 system,critical,info ntp change time Apr/22/2022 11:17:16 => Apr/22/2022 11:30:14
The next attempt to export caused a wlan disconnect, but not a crash, after about 5 minutes. Yet another export attempt finally worked taking one and a half minutes at 100% CPU.
hecatae
Sun Apr 24, 2022 2:46 am
The 7.3beta33 worked lovely on my hap Lite, but 7.3beta34 boot looped my audience with wifiwave2.
I've just downgraded both to 6.48.6 long term as while wifiwave2 is nice, I see no benefits for my hap lite.
shunkica
Fri Sep 02, 2022 11:16 pm
Issue has gotten better with 7.5
The export finishes now but it takes a minute and hammers the cpu at 100% for the entire minute.
FillippoGonzalez
Wed Jun 21, 2023 12:43 pm
hAP mini 7.10
I started export about 15min ago
Still waiting... CPU: 100%
rextended
Wed Jun 21, 2023 1:28 pm
It's really ridiculous that you could think of using RouterOS 7 on a SMIPS device.
Why don't you install macOS Ventura on an older PowerPC?
Users browsing this forum: No registered users and 71 guests
