brutmus
NordVPN problem on local network
Tue Dec 07, 2021 1:03 pm
I have NordVPN setup on RB5009 7.1 working with vlans.
I have problems accessing devices on different vlans internally, all routing seems to go through the tunnel.
/ip firewall mangle
add action=mark-connection chain=prerouting new-connection-mark=under_nordvpn \
passthrough=yes src-address-list=under_nordvpn
I can't figure this out, so please help me.
ConnyMercier
Forum Veteran
Forum Veteran
Re: NordVPN problem on local network  [SOLVED]
Tue Dec 07, 2021 1:29 pm
You need an exception to your Mangle-Rule.
Many ways to solve this Problem..
You can add an address-list with the IP`s and/or IP-Ranges you would like to exclude from NORDVPN
For exemple "LAN_List" and include add 10.10.0.0/24
/ip firewall mangle
passthrough=yes src-address-list=under_nordvpn dst-address-list=!LAN_List
brutmus
Tue Dec 07, 2021 1:33 pm
Thank you! Working great!
ConnyMercier
Forum Veteran
Forum Veteran
Tue Dec 07, 2021 1:39 pm
Glad i could Help !
The new Mangle-Rule basicly says :
Every Client-IP listed under "under_nordvpn" schould go thru the VPN,
EXCEPT if the Destination-IP is listed under "LAN_List"
Users browsing this forum: clinttt, Majestic-12 [Bot] and 151 guests
