RcRaCk2k
BGP + ECMP
Tue Dec 07, 2021 6:20 pm
Hi Guys,
how to enable ECMP for BGP routes?
> /ip/route/print detail where !inactive
Flags: D - dynamic; X - disabled, I - inactive, A - active; c - connect, s - static, r - rip, b - bgp, o - ospf, d - dhcp, v - vpn, m - modem, y - copy; H - hw-offloaded; + - ecmp
   D b   dst-address=0.0.0.0/0 routing-table=main gateway=172.16.11.129 immediate-gw=172.16.11.129%sfp-sfpplus1.uplink.v2221
            distance=20 scope=40 target-scope=10 suppress-hw-offload=no
   DAb   dst-address=0.0.0.0/0 routing-table=main gateway=172.16.11.1 immediate-gw=172.16.11.1%sfp-sfpplus1.uplink.v2220
 0   s   dst-address=0.0.0.0/0 routing-table=main pref-src="" gateway=172.16.11.1 immediate-gw=172.16.11.1%sfp-sfpplus1.uplink.v2220
           distance=100 scope=30 target-scope=10 suppress-hw-offload=no
Both BGP default-routes are installed in fib, but only one is active.
smyers119
Re: BGP + ECMP
Tue Dec 07, 2021 8:27 pm
On other venders you can increase "maximum-paths" 2, to enable ecmp. I was looking through the options in ROS CLI and could not find something similar.
clambert
Re: BGP + ECMP
Tue Dec 07, 2021 11:02 pm
I think that this feature it's not available in ROS v6.
Also not available in ROS v7 yet:
https://help.mikrotik.com/docs/display/ ... col+Status
RcRaCk2k
Re: BGP + ECMP
Tue Dec 07, 2021 11:17 pm
I thought that v7 is the first ROS that support BGP with multipath (ECMP).
This makes me a little bit angry.
Currently i use Ubiquiti Routers to achive ECMP with BGP. I moved many routers to Mikrotik because in some topics ECMP for BGP on Mikrotik was planed for v7.x - and now, this feature is not ready yet? Damn it :lol:
aleksis
Re: BGP + ECMP
Wed Dec 08, 2021 8:28 am
Edit: I stand corrected, BGP multi path is not supported at the moment.
ECMP is supported. You should look at '/routing/route/print detail' to debug this.
RcRaCk2k
Re: BGP + ECMP
Thu Feb 10, 2022 11:23 am
To the Mikrotik Engineers:
Please add BGP ECMP to the List of https://help.mikrotik.com/docs/display/ ... col+Status so we can track the availability of that feature in ROS v7.x
Thank you.
gammy69er
Re: BGP + ECMP
Tue Mar 22, 2022 12:06 am
I am here because it does apper to be working for me... in ONE case... and I am not sure how. It's also "Almost" working in a second case - but the secondary route is still blue - even though both are stating ECMP (+ in status)
In both of these cases - they are iBGP - but i cannot confirm the trigger 100%. I can confirm that if I set nexthop to the upstream as the "Mid" router - the + in status dissappears in one of the cases (have yet to test more)
7.1.3
gammy69er
Re: BGP + ECMP
Tue Mar 22, 2022 3:20 am
OK, for more fuel to the flames - I found why case 2 "works" - but doesnt - but does
The situation where the ECMP was running - but onlu one route was active - was only partially true. The secondary route had injected itself into the primary - so WAS ECMP - tested and was multipathing randomly.
This was due to 2 things - as far as i can tell.
1. The Gateway was the same - being sent via BPG (from 2 sources pointing to the same point - neither were the gaterway)
2. There was a ECMP Path to the gateway of each of these routes. As an aside - the ECMP route WAS NOT active (was blue) but was still an equivalent to an ECMP route.
Had added long distance static ECMP failove to part of my setup - and on one of the tails - saw this.
The router in question is 7.1.3, it's peers are 7.1.3 and 6.47.10
The other one in question - the 7.1.3 upstream - get routes from the router above, but as a failover - also gets routes from it's 6.47.10 companion for the router above.
In this case - there are no static routes to the downstream - but this router IS showing both sets as ECMP... ALSO, rather than injecting the 2 routes into one - they are being shown as 2 seperate active routes - like when doing static in ROS 7x (unlike the one above which was more similar to ECMP in ROS 6x)
The problem I have is that is that in the last case here - I don't think I want ECMP - as both paths are actually going to 1 router - but one is 1 hop and the other is 2... I'd rather have failover route for if a bgp drops or ip drop or something... Either way - I got work to do.
If i can knuckle down how it works - and I remeber - will post here. Otherwise hope that rough outline helps someone figure out their ECMP.
mrz
Re: BGP + ECMP
Tue Mar 22, 2022 9:25 am
BGP routes recursively resolved on ECMP routes will also be ECMP, see here:
https://wiki.mikrotik.com/wiki/Manual:B ... interfaces
Feature where BGP creates multipath routes (BGP multipath) is not implemented at the moment.
tiernano
Re: BGP + ECMP
Tue Mar 28, 2023 1:29 am
Any idea when this will be enabled?
spippan
Re: BGP + ECMP
Tue Mar 28, 2023 3:05 am
also working in v7 ?
Amm0
Re: BGP + ECMP
Tue Mar 28, 2023 3:34 am
The crystal ball is unclear, it's not yellow or green, but also not red...
https://help.mikrotik.com/docs/display/ ... l+Overview
Isn't white the color of surrender?
oeyre
Re: BGP + ECMP
Mon Jul 17, 2023 6:59 pm
Sorry, can you please clarify the difference?
yuuzi41
Re: BGP + ECMP
Fri Aug 04, 2023 5:45 pm
+1 - I'm in need of BGP multipath. I'd like to use the feature to build an scalable IP Clos network.
amix
Re: BGP + ECMP
Thu Mar 14, 2024 9:23 pm
Something have silently changed
mrz
Re: BGP + ECMP
Thu Mar 14, 2024 11:31 pm
nothing is silently changed, multipath is still not implemented.
DarkNate
Re: BGP + ECMP
Tue Mar 19, 2024 11:54 am
Will MikroTik support BGP multipath UCMP? I.e. to allow us to specify the bandwidth profile for each interface? And therefore perform load balancing across the interfaces either using:
1. Per packet (bad idea for stability/traceroutes etc)
2. Per flow (layer 2/3/4 hashing)
https://vxplanet.com/2019/01/03/bgp-loa ... balancing/
RcRaCk2k
Re: BGP + ECMP
Sun Apr 21, 2024 11:16 pm
This happens when you have 2 or more BGP-Profiles.
Users browsing this forum: No registered users and 2 guests
