I have a pi-hole and pivpn setup with wireguard and I'm having trouble connecting to it from outside my network.
My setup is as follows:
1. pihole/pivpn: 192.168.88.105
2. connected to internet through PPPOE
3. trying to access pivpn through dynamic DNS provided by my ISP since they don't give out static IPs
Code: Select all
add address=192.168.88.0/24 comment=defconf dns-server=192.168.88.105 gateway=192.168.88.1
set allow-remote-requests=yes servers=192.168.88.105
add action=dst-nat chain=dstnat comment="pihole stuff 1" dst-address=!192.168.88.105 dst-port=53 in-interface=bridge protocol=udp src-address=!192.168.88.105 to-addresses=192.168.88.105
add action=masquerade chain=srcnat comment="pihole stuff 2" dst-address=192.168.88.105 dst-port=53 protocol=udp src-address=192.168.88.0/24
add action=dst-nat chain=dstnat comment="pivpn port forward" dst-port=51820 in-interface=pppoe-out1 protocol=tcp to-addresses=192.168.88.105
The following two entries are me trying to make all the clients on the local network use the PiHole even if they don't want to.
The third is my attempt at port forwarding port 51820 for WireGuard.
Anyone have any idea what I'm doing wrong?
Thanks!
