ultraprofissionais
BGP Confederation on Mikrotik V7
Thu Dec 09, 2021 10:32 pm
Could someone give some guidance regarding the configuration of BGP Confederation, in the new version of routerOs?
I took a CCR and updated it to version 7, but it remade the settings but when viewing via winbox, it changed something that made the session establish.
It seems to be an issue with the local.role option.
I even looked at the draft, but found it a little confused.
Could someone pass on any tips?
The settings made are:
/routing bgp connection
    add address-families=ip as=4560/65000 connect=yes disabled=no input.filter=ULTRA_CCR1072_IN \
     listen=yes local.role=ibgp name=ULTRA_CCR1072 \
     nexthop-choice=force-self output.filter-chain=ULTRA_CCR1072_OUT \
    .network=bgp-networks remote.address=172.30.29.1/32 .as=4560/65001 routing-table=main \
    templates=default
Here are some images with the error messages in the log.
Thank you in advance for your attention
Best Regards
João Pedro
edielson_atm
Trainer
Trainer
Re: BGP Confederation on Mikrotik V7
Tue Dec 14, 2021 3:11 pm
I have the same problem, did you get a solution?
Dude2048
Mon Jan 24, 2022 5:05 pm
Had the same problem. I seem to have solved it. The confedration AS is 78910. Sub AS 65534 is for R08. Sub AS 65535 is for R09
R08
add as=78910/65534 disabled=no local.address=10.1.89.8 .role=ebgp name="R08 - R09" remote.address=10.1.89.9/32 .as=65535/78910 router-id=172.16.0.8 routing-table=main
R09
add as=78910/65535 disabled=no local.address=10.1.89.9 .role=ebgp name="R09 - R08" remote.address=10.1.89.8/32 .as=65534/78910 router-id=172.16.0.9 routing-table=main
The remote.as is just the other way around.
psm
Wed Apr 06, 2022 2:34 pm
Something doesn't work properly in my opinion.
CHR1:
/routing bgp template
set default address-families=ip as=65001 disabled=no output.filter-chain=bgp-out .network=bgp-nets router-id=192.168.1.1 routing-table=main
add address-families=ip as=65001/1111 disabled=no local.role=ebgp name=bgp-CHR2 output.filter-chain=bgp-out .network=bgp-nets remote.address=10.0.0.2/32 .as=65002 router-id=192.168.1.1 routing-table=main templates=default
add address-families=ip as=1111 as-override=no disabled=no local.role=ebgp name=bgp-CHR3 output.filter-chain=bgp-out .network=bgp-nets remote.address=10.0.2.1/32 .as=65003 remove-private-as=no router-id=192.168.1.1 routing-table=main templates=default
CHR2:
set default address-families=ip as=65002 disabled=no output.filter-chain=bgp-out .network=bgp-nets router-id=192.168.1.2 routing-table=main
add address-families=ip as=65002/1111 disabled=no local.role=ebgp name=bgp-CHR1 output.filter-chain=bgp-out .network=bgp-nets remote.address=10.0.0.1/32 .as=65001 router-id=192.168.1.2 routing-table=main templates=default
CHR3:
set default address-families=ip as=65003 disabled=no output.filter-chain=bgp-out .network=bgp-nets router-id=192.168.1.3 routing-table=main
add address-families=ip as=65003 disabled=no local.role=ebgp name=bgp-CHR1 output.filter-chain=bgp-out .network=bgp-nets remote.address=10.0.2.2/32 .as=1111 remove-private-as=no router-id=192.168.1.3 routing-table=main templates=default
CHR1 and CHR2 are in confederation. CHR3 is "outside" router.
Routing table on CHR1
Routing table on CHR3
Problem is in AS-PATH for transited routes. On CHR3 router they should be visible as routes originated from 1111 not 65002.
Do you see any misconfiguration?
Thank you for any help :)
mrz
Wed Apr 06, 2022 2:47 pm
Currently, there are known problems with the BGP confederation configuration. It is not possible to set it up to work as intended, the problem will be solved in upcoming versions.
fleetinfo
Mon Feb 27, 2023 2:17 pm
is this issue now fixed ?
petkodmitriy
Thu Mar 30, 2023 9:38 am
any update about bgp confederation?
DarkNate
Thu Mar 30, 2023 2:07 pm
In modern network deployments, we avoid two things:
1. Fully-meshed iBGP/Route reflector bullshit.
2. BGP confederation bullshit.
We should use is-is/OSPF or underlay of learning loopbacks between adjacent neighbours. Then use iBGP for adjacent neighbours using loopbacks on each side.
Now for anything else use eBGP with private ASN for upstream/downstream relationships.
https://www.rfc-editor.org/rfc/rfc7938.html
I've successfully deployed this method in both ISP and DC environments. No complaints from clients.
StubArea51
Trainer
Trainer
Thu Mar 30, 2023 4:31 pm
If the thread was whether or not to use Confederations, this would be a valid discussion but there will always be a corner case where different protocols are useful and without context, you can't say if if it's the right solution or not. It's better to keep debate about protocol usage out of the threads relating to feature support and whether it's working or not. It clutters the conversation.
404Network
Thu Mar 30, 2023 5:01 pm
Well stated Sir, and to add even MT recognized there are issues with their implementation and are actively seeking to fix it...........so its worth it from their perspective as well.
mozerd
Forum Veteran
Forum Veteran
Thu Mar 30, 2023 7:36 pm
@404network …. What happened to you ??? Did they ban your remarkable friend “Anav” again for being a PITA? I can’t believe Anav is in the penalty box … tell me it ain’t so!
404Network
Thu Mar 30, 2023 7:49 pm
Sad but true mozerd. Undergoing therapy and counselling at the moment.
Larsa
Fri Mar 31, 2023 12:02 am
My grieving pal @Anav, bless his poor soul!
mrz
Fri Mar 31, 2023 12:37 am
Do you still have confederation problems with v7.8 or newer? If yes, contact support.
nichky
Fri Mar 31, 2023 4:52 am
if i do remember well on v6 multihop must to be able to make it work, unlike v7.
mrz
Fri Mar 31, 2023 11:43 am
Like I said, if you have a non-working confederation setup with the latest v7 version, contact support.
benniej
Wed Apr 19, 2023 4:14 pm
Ticket logged SUP-113377. Please see if you can assist.
benniej
Mon May 08, 2023 4:45 pm
Still not working in ROS 7.9
nichky
Tue May 09, 2023 2:55 am
how u mean?
export your config, or do what @mrz suggested
petkodmitriy1
Fri Jun 16, 2023 4:38 pm
will you solve the problem? if so please share the result
benniej
Fri Jun 30, 2023 6:44 pm
Tested BGP Confederations with ROS v7.10.1 and still does not seem to work.
Steps to reproduce:
1) Set-up 2 X ROS 6.48.7 CHR/routers with BGP Confederations etc. See example config below.
CORE1:
add name=loopback0 protocol-mode=none
set [ find default-name=ether1 ] comment=CORE2 disable-running-check=no
/routing bgp instance
set default as=64600 cluster-id=0.0.0.2 confederation=64555 router-id=192.168.61.25
/routing ospf instance
set [ find default=yes ] router-id=192.168.61.255
/user group
set full policy=local,telnet,ssh,ftp,reboot,read,write,policy,test,winbox,password,web,sniff,sensitive,api,romon,dude,tikapp
add address=192.168.61.1/30 interface=ether1 network=192.168.61.0
add address=192.168.61.254 interface=loopback0 network=192.168.61.254
set allow-remote-requests=yes
/routing bgp peer
add default-originate=if-installed name=CORE2 remote-address=192.168.61.254 remote-as=64600 update-source=loopback0
/routing ospf interface
add passive=yes
add interface=ether1 network-type=point-to-point use-bfd=yes
add interface=loopback0 network-type=broadcast passive=yes
/routing ospf network
add area=backbone network=192.168.61.0/24
/system identity
set name=CORE1
/system package update
set channel=long-term
CORE2:
set [ find default-name=ether1 ] comment=CORE1 disable-running-check=no
set default as=64600 cluster-id=0.0.0.2 confederation=64555 router-id=192.168.61.254
set [ find default=yes ] router-id=192.168.61.254
/user group
add address=192.168.61.2/30 interface=ether1 network=192.168.61.0
set servers=192.168.61.1
/routing bgp peer
add name=CORE1 remote-address=192.168.61.255 remote-as=64600 update-source=loopback0
add passive=yes
/system identity
set name=CORE2
2) Upgrade one of the routers and BOOM!
CORE2:
/interface lte apn
/port
set 0 name=serial0
set 1 name=virtual0
set default as=64555/64600 cluster-id=0.0.0.2 disabled=no output.network=bgp-networks router-id=192.168.61.254
add disabled=no name=default-v2 router-id=192.168.61.254
/routing ospf area
add disabled=no instance=default-v2 name=backbone-v2
/ip settings
set max-neighbor-entries=8192
/ipv6 settings
/interface ovpn-server server
set auth=sha1,md5
add gateway=192.168.61.1
/routing bfd configuration
add disabled=no interfaces=all min-rx=200us min-tx=200us multiplier=5
add cisco-vpls-nlri-len-fmt=auto-bits connect=yes listen=yes local.address=loopback0 .role=ibgp name=CORE1 remote.address=192.168.61.255 .as=64555/64600 .port=179 templates=default
/routing ospf interface-template
add area=backbone-v2 auth-id=1 auth-key="" cost=10 disabled=no interfaces=ether1 networks=192.168.61.0/30 priority=1 type=ptp use-bfd=yes
add area=backbone-v2 auth-id=1 auth-key="" cost=10 disabled=no interfaces=loopback0 networks=192.168.61.254 passive priority=1 use-bfd=no
/system identity
set name=CORE2
/system note
set show-at-login=n
CORE 2 Logs:
 15:35:42 route,bgp,error Invalid remote AS, expected 64555BgpStarter{ c=Connection{ ConnId{ 192.168.61.254:37037 -> 192.168.61.253:179 } Socket{ 4 ida } out } readsz=45 } cancelRemoteAs=64600
 15:35:42 route,bgp,error Invalid remote AS, expected 64555BgpStarter{ c=Connection{ ConnId{ 192.168.61.254:41837 -> 192.168.61.255:179 } Socket{ 6 ida } out } readsz=45 } cancelRemoteAs=64600
 15:35:42 route,bgp,error Invalid remote AS, expected 64555BgpStarter{ c=Connection{ ConnId{ 192.168.61.254:35453 -> 192.168.61.252:179 } Socket{ 5 ida } out } readsz=45 } cancelRemoteAs=64600
 15:35:53 route,bgp,error Invalid remote AS, expected 64555BgpStarter{ c=Connection{ ConnId{ 192.168.61.254:35205 -> 192.168.61.253:179 } Socket{ 4 ida } out } readsz=45 } cancelRemoteAs=64600
 15:35:53 route,bgp,error Invalid remote AS, expected 64555BgpStarter{ c=Connection{ ConnId{ 192.168.61.254:40565 -> 192.168.61.252:179 } Socket{ 6 ida } out } readsz=45 } cancelRemoteAs=64600
 15:35:53 route,bgp,error Invalid remote AS, expected 64555BgpStarter{ c=Connection{ ConnId{ 192.168.61.254:46835 -> 192.168.61.255:179 } Socket{ 5 ida } out } readsz=45 } cancelRemoteAs=64600
 15:35:54 route,bgp,error Invalid remote AS, expected 64555BgpStarter{ c=Connection{ ConnId{ 192.168.61.254:179 -> 192.168.61.252:37954 } Socket{ 4 ida } in } readsz=45 } cancelRemoteAs=64600
 15:36:05 route,bgp,error Invalid remote AS, expected 64555BgpStarter{ c=Connection{ ConnId{ 192.168.61.254:36141 -> 192.168.61.252:179 } Socket{ 5 ida } out } readsz=45 } cancelRemoteAs=64600
 15:36:05 route,bgp,error Invalid remote AS, expected 64555BgpStarter{ c=Connection{ ConnId{ 192.168.61.254:43623 -> 192.168.61.253:179 } Socket{ 4 ida } out } readsz=45 } cancelRemoteAs=64600
 15:36:05 route,bgp,error Invalid remote AS, expected 64555BgpStarter{ c=Connection{ ConnId{ 192.168.61.254:37851 -> 192.168.61.255:179 } Socket{ 6 ida } out } readsz=45 } cancelRemoteAs=64600
CORE1 Logs:
15:35:42 route,bgp,info Connection opened by remote host
15:35:42 route,bgp,info     RemoteAddress=192.168.61.254
15:35:42 route,bgp,error Received notification
15:35:42 route,bgp,error     OPEN error: bad remote-as
15:35:52 route,bgp,info Connection opened by remote host
15:35:52 route,bgp,info     RemoteAddress=192.168.61.254
15:35:52 route,bgp,error Received notification
15:35:52 route,bgp,error     OPEN error: bad remote-as
15:36:02 route,bgp,info Connection opened by remote host
15:36:02 route,bgp,info     RemoteAddress=192.168.61.254
15:36:05 route,bgp,error Received notification
15:36:05 route,bgp,error     OPEN error: bad remote-as
Notes:
1) Conversion from v6 to v7 seems to be correct(at least according to my interpretation of the manual)
2) BFD without confederations seems to be stable.
benniej
Fri Jun 30, 2023 6:51 pm
how u mean?
Already done that...... but only crickets
Ticket Logged: 2023/04/14
Last Generic Reply: 2023/05/08
petkodmitriy1
Sat Jul 01, 2023 2:42 pm
i know why confederation doesn't workinkg on ROS7.
In open message in ROS7 send packet with confederation_as instead SUB_as. In result peer discard this open message.
mikrotik tech support says that is OK))))). and dont wont confirm the bug and resolve problem.
SUP-119427
petkodmitriy1
Sat Jul 01, 2023 2:43 pm
support doesn't help
petkodmitriy
Thu Jul 13, 2023 9:40 am
Help, problem still not solved
benniej
Wed Aug 23, 2023 12:04 pm
Tested with:
ROS v6.49.8
ROS v7.11
Still not working. Despite the below URL say it does work…..
https://help.mikrotik.com/docs/display/ ... l+Overview
petkodmitriy
Tue Apr 23, 2024 6:03 am
Users browsing this forum: No registered users and 21 guests
