vl100 i need to qinq to be delivered for some other devices bechinde R2.
My quastuon is i cant asigne vl20 to the client connected to R1 (this router)
I can make it working only if i do separate bridge interface, but i want to to via bridge-filtering
see the config:
vlan question. I got vlan 100 and under that i got vlan 20.
see the config:
Code: Select all
/interface vlan
add interface=vlan100 name=vlan20 vlan-id=20
add interface=br-vlan name=vlan100 vlan-id=100
[admin@R1] > /interface bridge export
add name=br-vlan vlan-filtering=yes
add bridge=br-vlan interface=ether4
add bridge=br-vlan interface=ether3 pvid=20
/interface bridge settings
set use-ip-firewall=yes
/interface bridge vlan
add bridge=br-vlan tagged=br-vlan,ether4 untagged=ether3 vlan-ids=100,20
