santoshmikrotik
MikroTik routerboard antenna(LHG 5 RBLHG-5nD) internet frequent disconnection
Tue Dec 14, 2021 9:21 am
I am an internet consumer & ISP provider has provided internet connection using MikroTik routerboard antenna(LHG 5 RBLHG-5nD). Antenna is set at 50 feets height from the ground. Aerial distance between two points(producer and receiver) is 2.5km. High voltage electrical lines passing between two points(producer and receiver)
Internet connection disconnect frequently for 1 second or 2 seconds and then reconnecting again.
ISP provider informed that frequent disconnection is happening due to High voltage electrical lines and too much noise signal distrubance in my area. ISP proivder has multiple users with same producer antenna but other people are not facing disconnection problem.
I have been advised to upgrade Antenna to MikroTik RBLHG-5HPnD-XL to get strong signal. I don't have configuration/setup access to check setting details.
Users browsing this forum: gigabyte091 and 81 guests
