Good day.
I am trying to port forward port 25565 to my internal IP address in order to be able to host a minecraft server for my friends via WAN. I have set up the nat rule /ip firewall nat add chain=dstnat protocol=tcp dst-address= <MY EXTERNAL IP> dst-port=25565 action=dst-nat to-address=<SERVER IP> to-ports=25565.
The server works locally but not via WAN. Interestingly the error message my friends receive is "Connection refused: no further information" as opposed to "Connection timed out".
When checking ports online via
https://www.yougetsignal.com/tools/open-ports/, port 25565 displays as closed. But after reading some of the other forum posts pertaining to port forwarding for minecraft, some users suggested that dst-nat rules will show their ports as closed. In any case, so far I have been unsuccessful in solving this problem myself.
Any help would be appreciated!
Edit: Added my config file
