Mikegyver42
User Manager (Radius) 7.1 migration issue
Thu Dec 16, 2021 12:22 pm
I have a radius server which was running under Router OS 6.49.2 and I just migrated my router to version 7.1
The Radius lost all its configuration when upgrading to version 7.1 and I cannot restore the old database.
I still get an error message saying "Failed to migrate legacy data: legacy database not found in provided path" while pointing to the old version folder!
What to do is disaster!
khialb32
Re: User Manager (Radius) 7.1 migration issue
Thu Dec 16, 2021 12:34 pm
well i would say it is completely your mistake, yet,
first take the files you can find using winbox and keep them somewhere you can access them again later,
second downgrade to v6 as it can load the old DB I believe
if it could not load it, try loading it by copying the files you saved earlier to the filesystem of the router, and access your userman interface, and go to maintenance, and load the db if you could find it.
Mikegyver42
Thu Dec 16, 2021 12:47 pm
The old version files are still in the router in the user-manager folder.
The new version is in the user-manager5 folder.
The import of the Legacy database does not work!
Tvink
Fri Jan 21, 2022 10:17 am
Hey all,
I've got exactly the same issue. I ran this on a test machine and gives exactly the same behaviour.
I've tried to fix the sqllite db from the 6.49.2 version as well, but no luck.
I'd like to migrate to 7.1 but not if this issue is not resolved.
Mikegyver42
Fri Jan 21, 2022 1:10 pm
I still haven't solved the problem, I downgraded the router to version 6.49.2 while waiting for a solution that works.
ddejager
Mon Feb 28, 2022 3:46 am
migration also does not work on 7.1.3
Mikegyver42
Tue Mar 01, 2022 12:23 pm
same problem for me, version 7.1.3 does not solve the problem and Mikrotik seems to give a damn :-(
infomate
Sun Mar 13, 2022 2:32 pm
Is there a manual db migration from 6 to 7... I also need the old template with qr code
ddejager
Sun Mar 13, 2022 9:13 pm
@infomate: I don't believe there is any reasonable manual or documentation, and no one has been able to get the migration tool to work.
leprime
Mon Mar 14, 2022 11:08 am
As they said in this topic viewtopic.php?t=185562 , documentation are not available for now. we have to wait.
My advice is to go back, or try to create a new database.
Users browsing this forum: GoogleOther [Bot] and 41 guests
