shawan
Custom Hotspot HTML Redirection is not working on v7.1
Fri Dec 17, 2021 2:49 pm
Custom Hotspot HTML redirection is not working on version 7.1 stable, Same file working perfectly on v6.49.2. After redirect the the page goes to "404 not found" and URL should be http://hotspoturl/login.
*Attached hotspot html login file.
login.zip
razua
Re: Custom Hotspot HTML Redirection is not working on v7.1
Thu Dec 23, 2021 3:56 pm
Same problem after upgrade to V7.1 stable. Please help
khialb32
Wed Dec 29, 2021 12:26 am
Try enabling arp on the hotspot interface.
If not try the 7.2rc1, but be careful losing ur data!
ahmedalmosowe
Fri Dec 31, 2021 9:46 am
v 6 work ok
v 7 problem hotspot
Bitto
Thu Jan 13, 2022 11:55 am
Any solutions or updates on this issue ?
jkohan
Tue Sep 13, 2022 11:16 pm
Hello.
We have the same problem. Hostspot working OK on 6.48.6, stopped showing login page after upgrade 7 (and correcting OSPF and multi-wan scopes "litlle joke").
Google didn´t help us in this, either.
Tried 7.1.x, 7.5 and 7.6beta6 with identical results.
Deleted hotspot and recreated, read and analyzed every firewall rule, seem OK
Webserver is alive at 64874, I allowed input to that port and can see the login page.
Is there any bug report about this or documented changes to do ? (couldnt find anything).
Else, any ideas of what else to check ?
bentw
Thu Nov 03, 2022 6:41 pm
If I try to visit any IP in from a range in /ip address it will redirect to the hotspot page, but not automatically like with v6
suserevent
Mon Dec 04, 2023 10:21 am
pues parece que todo es igual
tengo mismo problema
Users browsing this forum: No registered users and 11 guests
