gotsprings
RB3011 7.1 and ZeroTier No discovery
Fri Dec 17, 2021 3:47 pm
(Moved Post)
Here is an odd one I am chasing after.
My test router at the shop has Zerotier 1.6.5 on it as the RB3011 is running 7.1rc4
The router we put at a the bosses brother's has Zerotier 1.6.6 on it, as the RRB3011 is running 7.1
Both have Zerotier bridged to the bridge
The RB3011 with 7.1rc4 on it... I can discover things via ARP.
The RB3011 with 7.1 on it... I can't. But I can connect to devices if I manually enter the MAC address.
I have several hAP AC2s Running 7.1 and they work normally. Open winbox and they pop up in discovery. Devices on their LANs are discoverable too.
I think this might be specific to the RB3011 with 7.1 RELEASE
smyers119
Re: RB3011 7.1 and ZeroTier No discovery
Fri Dec 17, 2021 5:21 pm
(Moved Post)
I think a packet capture and config would help.
gotsprings
Mon Dec 20, 2021 11:52 pm
This is a fun one... I CAN CONNECT TO DEVCIES VIA MAC. Just no discovery.
Comparing to a 7.1RC4.
gotsprings
Sun Jan 23, 2022 4:50 pm
Put Zerotier on a rb3011 running only as a switch.
Discovery worked...
Guess I have to dig through my config line by line looking for something on the bridge or maybe firewall.
kiler129
Wed Jan 26, 2022 2:35 am
Make sure you don't have arp=reply-only on any VLAN interfaces - whenever I set that weird things like that start to happen.
gotsprings
Wed Jan 26, 2022 12:24 pm
Definitely don't have that.
Same base template applied to a hAP AC2 doesn't have this problem. So it's annoying me.
Users browsing this forum: No registered users and 5 guests
