jult
Re: v7.1.1 is released! CAKE / FQ_Codel Support
Fri Jan 07, 2022 9:49 pm
Nevertheless, I notice that that CAKE / FQ_Codel Queueing Disciplines don't appear to be offered in either the Web GUI or /queue/types/print.
I would like some more info on cake / fq_codel queueing as well. For instance, isn't it about time some of the defaults are using those queue types by now? The upgrade to 7.* does not seem to have changed any of them in my devices;
I would very much like to know which I can change to cake and/or fq_codel now. Any advice on this? It's not in the wiki (yet)..
mhaluska
Fri Jan 07, 2022 11:35 pm
Just define new type...
> /queue/type/add kind=[TAB]
bfifo  cake  codel  fq-codel  mq-pfifo  none  pcq  pfifo  red  sfq
jult
Sat Jan 08, 2022 12:54 am
That's not the question, I see it listed among the types. I'm curious why it's not being used..
pe1chl
Sat Jan 08, 2022 1:34 am
1. it isn't stable and finished
2. it is likely not the optimal type for the usage scenarios hinted by the type name
you would use such queues e.g. on an internet link, so maybe in the future there will be a type name for that?
even then of course it only is used when you select it.
denasu
Sat Jan 08, 2022 11:06 am
I have a hap ac2 with version 7.1.1 when i turn it off via winbox then it turns on again in this version
The same problem with hAP ac3. I tried on versions 7.1, 7.1.1, 7.2rc1. Version 6.49.2 turns off successfully. (SUP-71006)
mac112
Sat Jan 08, 2022 11:33 am
Still writing "Calculating download size ..."
You need to remove any extra packages installed before upgrading. This has been mentioned in nearly every 7.x release post.
I used system and dhcp.
It still writes "Calculating download size ..."
jult
Sat Jan 08, 2022 12:35 pm
2. it is likely not the optimal type for the usage scenarios hinted by the type name you would use such queues
Hmm.. I strongly disagree there. I've been part of the bufferbloat testers for over a decade now. fq_codel can be enabled for everything you'd like to try it on, and would probably already yield better results than the older current queue types. CAKE has also been widely tested and usually ends up better than sfq for wifi, even with CAKE defaults, but hey. If you mean to say you have not tested them with mikrotik hardware, I'd say go ahead and try. Try default to fq_codel for the internet port and run some tests. Switch all Flow Control to Off for that port (Interfaces > Ethernet > Tx and Rx Flow Control > Off), and maybe default to CAKE for wireless facing interface(s) and run some tests and compare.
pe1chl
Sat Jan 08, 2022 12:48 pm
But you can do that, right? The existing queue type names are for purposes like a plain (local) ethernet interface, a WiFi interface, etc.
I don't think it is useful to put some advanced queue on there, e.g. for ethernet.
When you want to use these queues on the internet port, just add your queue type for it and use it.
I have not yet tried it on my router as I read regular reports of routers crashing and about missing features (queue direction) so I wait until it stabilizes a little.
I use a queue tree with DSCP-determined priority and it serves me well enough.
haedertowfeq
Sat Jan 08, 2022 5:28 pm
Can you share your configure
mducharme
Trainer
Trainer
Sat Jan 08, 2022 6:19 pm
You have to download the npk and upgrade that way. There is no "dhcp" or "system" package in RouterOS v7 and so it can't find those package to download, which is why it is stuck at "calculating download size". You can only upgrade normally to RouterOS v7 when the bundle package was used in RouterOS v6. You have used the individual packages instead of the bundle.
sstybel
Sat Jan 08, 2022 8:11 pm
I have a problem with ROS version 7.1.1. on wAP ac old devices (RBwAPG-5HacT2HnD on mipsbe). The problem mainly concerns 5G WiFi and is manifested by a decrease in speed towards the upload. The problem does not occur on wAP ac new (RBwAPG-5HacD2HnD on arm). I did not observe the problem on hAP ac3 (RBD53iG-5HacHnD on arm). After downgrading to 6.49.2 the problem disappears and even wAP ac new (RBwAPG-5HacD2HnD on arm) and hAP ac3 (RBD53iG-5HacHnD on arm) work better (more efficiently). The screenshot shows an example of 5G WiFi transfer for a 600/60 Mbps Internet connection. The same problem is in the internal network, e.g. when copying files via WiFi to a NAS in the LAN network (even the WiFi connection is broken / disconnected).
Pomo
Sun Jan 09, 2022 3:28 am
HAP AC RouterBOARD 962UiGS-5HacT2HnT on 7.1.1, 5GHz wifi when set to 5500, 20/40/80 a/n/ac, Ceee it is impossible to connect to.
Same setting I have on Hap AC2 and AC3 on 7.1.1., and it works fine.
Also, quick set, now there is no check for updates buton?
mafiosa
Sun Jan 09, 2022 10:02 am
Does RouterOS support multiple routing tables for IPv6?
osc86
Sun Jan 09, 2022 3:01 pm
they are just tables, you can use IPv4 and IPv6 routes with them. For adding IPv6 routes to a table other than main, you currently have to use the cli, winbox still doesn't show the routing-table parameter.
gotsprings
Sun Jan 09, 2022 4:03 pm
I have this error but it seem Winbox bug things. If u see the list with using terminal, it wont get double.
I have had issues with double or invalid information shown in winbox and I was told to press F5 in such cases.
A bit strange because I never had comparable issues with RouterOS v6, but it appears that the constant automatic refresh of information in (most) winbox windows was removed in v7.
So that's what that is. When I was working in wireless I saw an entry for the AP 2 times. It showed as the old routerOS and New. Closed windobx and reopened. Duplicates gone.
infabo
Sun Jan 09, 2022 4:04 pm
Sure there is one.
mafiosa
Sun Jan 09, 2022 4:26 pm
mac112
Sun Jan 09, 2022 4:37 pm
Atom 270N does not work
This kernel requries an x86-64 CPU, but only detected an i686 CPU
eenpahlefi
Sun Jan 09, 2022 4:57 pm
BGP > Template , disable or enable on click, erorr
RouterOS 7.1.1
mkx
Sun Jan 09, 2022 5:10 pm
Atom N270 is a 32-bit only processor: https://ark.intel.com/content/www/us/en ... z-fsb.html
Chupaka
Sun Jan 09, 2022 5:23 pm
RouterOS 7.1.1
You may want to try /routing/bgp/template/print in Terminal: it can show you the reason why it's Inactive
It definitely would help if you provide more details to describe problems.
Do you ask your doctor for help saying "I'm feeling ill"? :)
I'm sure veterinarians have to deal with this :) Sorry...
Russian-speaking forum: https://forum.mikrotik.by/. Welcome!
For every complex problem, there is a solution that is simple, neat, and wrong.
MikroTik. Your life. Your routing.
Pomo
Sun Jan 09, 2022 5:52 pm
Sure there is one.
Sure...
fragtion
Sun Jan 09, 2022 7:22 pm
Hi. I'm seeing these two issues with v7.1 & v7.1.1 on two RB5009's. It manifests the same way on both routers..
1. some interfaces will see roughly 50% packet loss. One ping goes through, next times out, next goes through, next times out, etc... Direct LAN cable (under 1m) to neighbor device. If I disable the connection for a few minutes and re-enable, the pings are fine for a few seconds and then packet loss starts again.
Edit: this specific issue could have been caused by bridging VLANs incorrectly.
While this is happening, interface traffic graphs show similar gaps in coverage, like this:
2. All interfaces (including eoips) randomly crash / go into "down" state together, and then come back up a few seconds later. Port flapping basically ...
The issue comes and goes. Some days it happens continuously and is bad, other days nothing. I don't know what's causing it.
Is this likely hardware-related, or software related? / Are either or both of these issues known ?
mac112
Sun Jan 09, 2022 8:34 pm
Dual core AMD G-T48E 64bit CPU
does not work, the router still restarts
I have a Wyse D10DP
pe1chl
Sun Jan 09, 2022 8:46 pm
Sure there is one.
Sure...
Increase your window size, it should be under what is shown for System.
Else check that you did not make a skin definition for webfig, that now also affects winbox.
Pomo
Sun Jan 09, 2022 9:28 pm
Sure...
Thanks.
Still cannot for the life of me make clients connect to 5GHz anything else than 5180. And yes, I am aware of dfs waiting periods.
Ideas?
/interface wireless
set [ find default-name=wlan1 ] adaptive-noise-immunity=ap-and-client-mode band=2ghz-g/n basic-rates-a/g=\
    9Mbps,12Mbps,18Mbps,24Mbps,36Mbps,48Mbps,54Mbps basic-rates-b="" country=no_country_set disabled=no \
    distance=indoors frequency-mode=manual-txpower mode=ap-bridge ssid=Matija station-roaming=enabled \
    supported-rates-a/g=9Mbps,12Mbps,18Mbps,24Mbps,36Mbps,48Mbps,54Mbps supported-rates-b="" wireless-protocol=\
    802.11 wps-mode=disabled
set [ find default-name=wlan2 ] adaptive-noise-immunity=ap-and-client-mode band=5ghz-a/n/ac channel-width=\
    20/40/80mhz-XXXX disabled=no distance=indoors installation=indoor mode=ap-bridge skip-dfs-channels=\
    10min-cac ssid=Matija station-roaming=enabled wireless-protocol=802.11 wps-mode=disabled
set [ find default=yes ] authentication-types=wpa2-psk eap-methods="" group-key-update=1h mode=dynamic-keys \
    supplicant-identity=MikroTik
add authentication-types=wpa-psk,wpa2-psk eap-methods="" group-key-update=1h mode=dynamic-keys name=ivukovic \
    supplicant-identity=""
/interface wireless
add disabled=no hide-ssid=yes keepalive-frames=disabled mac-address=66:D1:54:3C:DC:28 master-interface=wlan1 \
    multicast-buffering=disabled name=ivukovic security-profile=ivukovic ssid=ivukovic station-roaming=enabled \
    wds-cost-range=0 wds-default-cost=0 wps-mode=disabled
add disabled=no hide-ssid=yes keepalive-frames=disabled mac-address=66:D1:54:3C:DC:27 master-interface=wlan2 \
    multicast-buffering=disabled name=ivukovic_5 security-profile=ivukovic ssid=ivukovic station-roaming=\
    enabled wds-cost-range=0 wds-default-cost=0 wps-mode=disabled
mroccella
Mon Jan 10, 2022 4:48 pm
Any chance of getting QuickSet fixed so that CAPsMAN setup on the RB4011 works? The router will not find its internal radios or any CAPS until you enter:
/interface wireless cap set enabled=yes interfaces=wlan1,wlan2 caps-man-addresses=127.0.0.1 bridge=bridge
Then, CAPsMAN works like a charm.
gotsprings
Mon Jan 10, 2022 5:27 pm
The WAVE2 driver works SO MUCH BETTER on the 5Ghz radio... why would you want to handicap the radio performance with the old drivers?
(now that I got my smart ass comment out of the way.)
Many routers running caps-man are either not wireless enabled, or placed in such a location where having their radio on is point less.
pe1chl
Mon Jan 10, 2022 5:32 pm
Because the stupid WAVE2 driver does not support the 2.4 GHz radio and cannot work together with the old drivers for 2.4 GHz.
No idea why that was ever implemented that way... it is ridiculous. A WiFi driver for a commercially sold 2.4+5GHz device that supports only the 5 GHz radio and makes use of the 2.4 GHz radio impossible.
infabo
Mon Jan 10, 2022 6:06 pm
Lol! Heard that for the first time. I guess people would stop asking for a slimmed down wave2 package for other devices with less flash, when they would know that there is no 2.4ghz support right now.
mkx
Mon Jan 10, 2022 6:14 pm
It's not that 2.4GHz is not supported ... the problem is what @pe1chl wrote that wave2 driver can not coexist with legacy drivers and that chipset running 2.4GHz wireless on RB4011 is not supported by wave2. 2.4GHz works just fine with wave2 drivers on Audience ...
pe1chl
Mon Jan 10, 2022 6:16 pm
Frankly I don't give a sh*t about how well it works with Audience, it does not work on my RB4011 which is a relatively modern and high-end device in the MikroTik line. It should be supported well.
"RB4011iGS+5HacQ2HnD-IN (WiFi model) is dual band, four chain unit with a supported data rate of up to 1733 Mbps in 5GHz. For legacy devices, the unit also has a dual chain 2GHz wireless card installed in miniPCI-e slot."
Ok. So the 2 GHz card is apparently changeable (I never opened this router). I think MikroTik should provide free replacement mini-PCI-e cards for users of the RB4011 who want the WiFi to be supported together with 5 GHz.
mkx
Mon Jan 10, 2022 7:17 pm
I guess that MT will eventually support combination of wave2 drivers and legacy drivers in parallel... I just hope it'll be in 7.2 rather than 7.38 ...
WeWiNet
Long time Member
Long time Member
Mon Jan 10, 2022 7:57 pm
I concur your request, having a WifiWave2 upgrade option for RB4011 2.4Ghz would be great, mandatory.
Having such a high perf. product limited to old Wifi driver or 5Ghz only with Wifiwave 2 is a pitty...
mkx
Mon Jan 10, 2022 8:01 pm
Wave2 driver won't work for 2.4GHz on RB4011 because hardware is not wave2 capable. The only possibility is what I wrote earlier: MT should enable co-existence of wave2 and legacy drivers.
WeWiNet
Long time Member
Long time Member
Mon Jan 10, 2022 8:07 pm
2.4Ghz Wifi in RB4011 is the R11E card, exact reference R11e-2HnD. I have device open in front of me.
Ideal would be to have a H/W upgrade via a 2x2 Qualcomm based Wifi card compatible with Qualcomm drivers/WifiWave2.
mkx
Mon Jan 10, 2022 8:20 pm
If you find a mini-PCIe 2.4GHz wifi card based on QCA9984 chip, then you have a winner. This is chip driving the 4x4 MIMO 5GHz radio in Audience and per specs it supports 2.4GHz as well.
The card probably shouldn't be dual-band (selectable), ROS might be unable to select the band you want it to operate in.
pe1chl
Mon Jan 10, 2022 9:03 pm
Yes that would be a solution, but I think it is not my task to find and purchase such a card, but rather it should be a replacement program via MikroTik.
I.e. they make a new R11e-2HnD-QCA card and supply one to everyone proving purchase of a RB4011iGS+5HacQ2HnD-IN.
(or of course they solve this issue in software in another way)
fragtion
Mon Jan 10, 2022 11:53 pm
I tried loading wifiwave2 on a brand-new US (United States) model RB4011, and it was a total disaster. None of the bands for 5Ghz work because of channel/bandwidth limitations, and 2Ghz is obviously disabled. If they can't offer some kind of solution here there's probably going to be a lot of anger...to put it mildly
llpax
Tue Jan 11, 2022 1:22 pm
sorry. 7.1.1 unusable: x3 cpu load
1. clear FW (only src-nat), no ip-lists.
2. and full config (filer + mange + nat) + Queue tree
3 .VS ros6 full config (filer + mange + nat) + Queue tree
Only one Im have a high cpu load rb3011 with ros7.1.1 ? (x3 compared with ros6)
one core processes IRQ full time! (100mbps Full Duplex static routing + queue)
f1r3
Tue Jan 11, 2022 8:30 pm
Hey, i have the same Problem with my RB3011. With ROS6 i have with src nat, 40 Firewall rules, some mangle and two queue rules 200Mbit/s from my ISP and with ROS7 only 150Mbit/s. The CPU is then at 75-85% and with ROS6 only at 20%
Maggiore81
Trainer
Trainer
Tue Jan 11, 2022 8:44 pm
@f1r3 I suggest you saving your config, reset the router to factory default and then reapply the config. Something is broken during upgrade.
I have some RB3011 upgraded to ROS7.1.1 and they works flawlessy.
About 100M traffic, and 120simple queues
llpax
Tue Jan 11, 2022 9:17 pm
Yeep! Absolutely identical problem.
do you have 100 IRQ load for some one core?
/system resource cpu print
llpax
Tue Jan 11, 2022 9:26 pm
@Maggiore81
im tested 7.1.1 and 7.1 with rb3011 after FULL RESET. Empty FW and mangle, with no queues, only 1 src-nat rule. And I get 50% load cpu with 100mbps full duplex.
Check end of previous page of this thread for my screens.
Ros 7 have problem with rb3011 and 4011. Its fact.
I doubt that it is. Or may be rb3011 have hardware differents(revisions), that cause this situation on some modification.
f1r3
Tue Jan 11, 2022 10:16 pm
Hey, yes i upgraded from 6 to 7 with the config.
And after that and the poor Performance i installed the Router with netinstall and i don‘t Import my config. I configured the Router new.
I also tested it without the Firewall rules, when i disabled 20 rules then i have instead of 150Mbit/s 190Mbit/s.
With Fasttrack i have the Full 200Mbit/s but the Ping goes from 5ms to over 150ms
mafiosa
Tue Jan 11, 2022 10:41 pm
With RB3011 pcc with 140+ 105mbps eats 86% cpu with zero firewall just a scr nat rule. Earlier it used to go maximum 35% . Mikrotik is so broken and they don't even acknowledge the problem. Same config on hap ac^2 I am getting maximum 27% CPU utilisation.
llpax
Tue Jan 11, 2022 10:52 pm
Yes, its depends on hardware. hap ac2 with ros7.1.1 look better than 3011 or 4011... Exist some problem with drivers(hardware level layer) on some devices, I think. Obviously mikrotik not tested ros7 with all devices.
squidstable
Tue Jan 11, 2022 11:43 pm
4011:
OSPF not aggeegating routes generated by PPPoE (based on area ranges)
PPPoE sessions stuck in active connections.
This is not a stable release. This is a joke.
P.
leonardogyn
Wed Jan 12, 2022 12:13 am
Just to register it here, as I have already submitted it as a support bug ticket (SUP-71205)
with 7.1.1, randomly and I could not find a way of reproducing it, a simple 'reboot' makes a ovpn-client interface dissapears. It's not 'it stops working', it's really GONE after the box returns online (and working absolutely fine). The ovpn-client interface, who was there and fully working 2 minutes earlier, when I issued the reboot connected to the box via that ovpn-client interface, is now gone. A /export shows absolutely no signs of it, neither logs from boot. It's simply gone without any traces. Firewall rules, based on that interface, all becames invalid.
Recreating the interface works just fine, no problem on that. But after facing it at least 5 times, I'm pretty sure this wasn't a one-time glitch and it's really happening.
I'm using TCP ovpn-client mode, hadn't migrated to UDP yet, the ovpn-client config is absolutely the same used from 6.4x.x era, no change on that after migrating to ROSv7
pe1chl
Wed Jan 12, 2022 12:22 am
That may be just a special case of "under v7 sometimes config items disappear during a reboot".
When I reboot my RB4011 I lose the /ip ipsec identity records that are statically defined (the key of the IPsec tunnel). I have read other reports from people losing other things.
It appears there is some database with config information where updates are not always "committed" and get rolled back at a reboot.
When the router is running, a /export shows the relevant info. But when rebooted (either a reboot from the menu, or as part of an upgrade) it loses bits of config.
I always make a /export before I reboot and after the reboot or upgrade I do that again and diff them, to make sure I have not lost something without immediately noticing. Fortunately the router is otherwise very stable, I have not rebooted it since the upgrade to 7.1.1 which I did Dec 19 (when it was released).
leonardogyn
Wed Jan 12, 2022 12:32 am
I'm being somehow forced to reboot it, at least once a week, because of a severe memory leak I have reported here ( viewtopic.php?t=180831&start=600#p897760 ) and also as SUP-68885. It was confirmed, on that support ticket, that the hotspot module (which I'm using) seems to be the problem, but no fix yet. So I need to reboot here and there.
About items dissapearing, i wasn't aware that it's also happening with other items. If that's happening on other places, maybe it's really related. Funny is that at least 4-5 times I faced it, only the ovpn-client dissapeared, nothing else. It's funny its somehow "fixed" on some specific items, like you're having problem with ipsec identify only. Very weird ...
pe1chl
Wed Jan 12, 2022 12:42 am
That could be, I am not using that and my memory usage remains between 100 and 130 MB (I cannot explain the variation, there are some highs and one low during that month of uptime that I cannot correlate to changes I made). In a 1GB RAM router that of course means most memory is unused.
(I have asked several times to implement the RAMdisk on all routers, not just those with 16MB flash, but that never happened. maybe some time the container feature comes back and can use some memory)
f1r3
Wed Jan 12, 2022 8:09 am
Yes! One Core have 100% IRQ load.
llpax
Wed Jan 12, 2022 11:30 am
@ f1r3
ros 7 have some problem with the drivers for 3011 hardware, obviously. It's a pity.
rpingar
Long time Member
Long time Member
Wed Jan 12, 2022 3:55 pm
INTEL X710 hardware (x86 and CHR with passthrough like advised in the posted link) interface queue seems not correctly associated to cpus:
glow
Wed Jan 12, 2022 3:58 pm
Is that the queue or all 64 enumerable SR-IOV ports?
rpingar
Long time Member
Long time Member
Wed Jan 12, 2022 3:59 pm
yes
holvoetn
Wed Jan 12, 2022 4:47 pm
yes
And that's an answer to which question ?
rpingar
Long time Member
Long time Member
Wed Jan 12, 2022 4:50 pm
yes
sorry, its the queue
lele
Wed Jan 12, 2022 5:34 pm
An RB3011 is my home's main router, doing bgp, ospf, dhcp, firewall, nat, mangle, but no queues. With ROS 7.1.1 cpu gets 50%+ under load but I get 950Mb/s bidirectional over the gigabit upstream.
jorgeflange
Wed Jan 12, 2022 5:47 pm
Recently Upgraded CCR1072-1G-8S+ (tile)
All seems to be ok, the packages now are all in one ?
The router is Zero Config, planned for a replacement of actually in production BGP Router CCR1036-8G-2S+ (tile).
I´m configuring manually again this new router.
Any other with real experience in CCR1072 as BGP with V7.1.1 ?
rpingar
Long time Member
Long time Member
Wed Jan 12, 2022 6:51 pm
in this scenario I could load on ccr1072 the v6.49.2 with the backup of CCR1036 and then manually adjust the ports.
Only in a secon moment go about the upgrade to v7.1.1, that now seems fine to convert all the configs.
regards
pe1chl
Wed Jan 12, 2022 7:04 pm
Never load a backup from another device! backups are only to be loaded into the same device where they were made.
When you want to migrate the config from another device, use /export and /import only.
llpax
Wed Jan 12, 2022 8:13 pm
"RB3011" and "950Mb/s bidirectional"
nice joke :)))
m.b. comutation - not routing and nat-ing
vasilaos
Wed Jan 12, 2022 9:15 pm
I bought a RB5009 and I have to address some problems with RouterOS 7
1. There is no routin-table parameter in the ping option (scripts for monitoring wan's depend on that in order to monitor same host's with different routing mark and in order to make a nice working script)
2. Packet marks in mangle not working as expected for download and upload. All download falls in upload rule after a while. Using chain forward and in or out interface is wan interface. Selected packet no-mark to not mark packets twice. Some have sugested to use parent in queue tree the wan interface for upload and bridge inteface for download. This does not fit in my situation since multiple wan interfaces and multiple bridges in place so i have to use global as parent as it was in RouterOS 6. If you delete the rules in mangle and make them new it works for a while as expected then again download is marked all as upload. I think there might be a bug with the no-mark parameter in order to not mark packets twice. I have tried also with the option bypass set to no.
3. After installing an extra package and rebooting the device i have lost part of the configuration like bridge ports and scripts.
4. No extra package for ups and a test package that i downloaded didn't work on my device. It is showing 0 ports and no usbhid1 port to select on ups.
5. Port 1 which is 2.5G is not working with my provider modem even after removing 2.5g advertisement. I read even after negotiating 2.5G speed correctly the router is performing worse than with 1G speed.
irmankurnia
Wed Jan 12, 2022 9:19 pm
translation address or to-address in hotspot didn't work, i have client with address 172.16.0.2 with to-address 192.168.1.2 it's not work after upgrade from v6 to v7
winap
Wed Jan 12, 2022 9:42 pm
vasilaos:
1.And what speed do you have now? And what from your provider?
2. Do you have also problems like me with port 1 aftter few minutes, if the cable is unplug?
When I unplug the cable, after 5-15 minutes the LED orange shine, no POE on port 1..so there is no reason to shine (a little).
infabo
Wed Jan 12, 2022 9:45 pm
7.1.1 is a great thing
fragtion
Thu Jan 13, 2022 1:20 am
It's possible to create a NAT rule with an "arbitrary" chain name (neither of dstnat, input, output, srcnat). Possible bug? I'm not sure if this would lead to corruption or not, I haven't tested. I'm using Winbox 3.32.
mkx
Thu Jan 13, 2022 8:11 am
Ability to create firewall chain (filter, NAT,...) is not a bug, it's a feature. One then needs to add rule with action=jump jump-target=<custom chain> in one of standard chains (input, output, forward for filter or whatever standard chains for NAT). After packet passes custom chain without triggering any of rukes, the evaluation returns to original chain where next rule (after action=jump) gets evaluated. This enables to create some convoluted designs which either allow nicer designs (e.g. same rules for input and forward chains without entering same rules twice) or better performance (only select packets get handed off to custom chain, other packets skip evaluating those rules which reduces processing time).
kovaga
Thu Jan 13, 2022 2:00 pm
One out of 4 RB4011 is constantly rebooting after the upgrade to 7.1.1. The maximum uptime i saw was about 5 minutes.
Have disabled IPSEC and now it runs for 3.5 hrs already-
The funny thing is that another RB4011 is handling IPSEC connection just fine and has an uptime of 5 days with pretty much identical config. WTF!?
How can you call it a stable release while it has so many problems is beyond me.
pe1chl
Thu Jan 13, 2022 3:58 pm
I have a 4011 with several IPsec sessions that has been running since the day 7.1.1 was released, but it only has "client" sessions and it seems the problems mainly exist in the "server" side.
(L2TP/IPsec server, for example)
kovaga
Fri Jan 14, 2022 10:08 am
Indeed, thats exactly my case. The client ipsec RB4011 with 7.1.1 was working fine connected to server RB4011 running 6.49 for a week or so. So my assumption was that it is a second minor release, so that so far worked fine, considered it safe to upgraded the server ipsec RB4011 and thats when the fun begun.
What I also noticed is that changes to the NTP client configuration on RB4011 with 7.1.1 may result in the spontaneous reboot shortly after.
jimmer
Fri Jan 14, 2022 11:46 pm
I also notice a jump in CPU load from 6.49.x to 7.1.x on my RB3011 - fortunately it has the extra grunt to absorb it, so much so that fasttrack only saves about 10% CPU usage, one other thing ive noticed to is that the amount of RAM that is being used creeps up too.. at first boot its using 80Mb of RAM.. over the course of the last 23 days it has crept up to over 100Mb used, I see a similar pattern on a RB2011 running 7.1, my hAPac2's are similarly doing it with a small creep upward running 7.1.1 but they are only running as CAPsMAN controlled AP's and do nothing else. it does look like 7.1.x may have a memory leak of some sort.
yottabit
Sat Jan 15, 2022 6:32 am
IPIP+IPSec tunnels are still broken if the default keepalive is left enabled. If you unset the keepalive, the tunnels come right up.
I am using ROS 7.1.1 on one end and ROS 6.49.2 on the other end.
I saw this reported in the beta and it is still not fixed.
mobyfab
Sun Jan 16, 2022 4:26 am
Wanted to try sr-iov on chr but sadly the bnx2x drivers I need have not been included so it won't work.
dll2003
Sun Jan 16, 2022 10:26 pm
I would recommend Mikrotik to create a wiki page containing all relevant changes when upgrading from V6 to v7. Not everybody has to ask the same questions all over again.
Even the small changes like "?" on CLI or the invertion of hide-sensitive to show-sensitive of export command.
Name the breaking changes and don't let people left in the dark.
I fully support this post.
So far, the lack of such information greatly slows down upgrade to ver.7.x.x.
moiskey
Mon Jan 17, 2022 3:50 pm
Greetings. i lost compatibility with my old network card in mikroitk x86 (qlogic bmc5709c).
When configuring, it is simply with the status of the network cable disconnected (it does not change the status of running).
I hope it can be solved
Jotne
Mon Jan 17, 2022 11:23 pm
Not a quick fix, but if you do run RouterOS x86 you can change to RouterOS CHR (run on VmWare).
dtaht
Tue Jan 18, 2022 3:42 am
fq_codel and cake work brilliantly with flow control on and without a shaper. why turn it off?
mducharme
Trainer
Trainer
Tue Jan 18, 2022 3:48 am
I am curious as to what you mean by "without a shaper" - do you mean setting fq_codel or cake as the interface queue? MikroTik abstracts away many of the parts of tc (which I haven't used on regular Linux, only MikroTik's abstraction of it), and so I do not have a complete understanding of what "without a shaper" means in this context.
kos
Tue Jan 18, 2022 11:16 am
"/tool mac-server set allowed-interface-list=none" doesn't disable mac telnet until reboot.
mktwifi
Tue Jan 18, 2022 3:57 pm
Hi All,
HTTPS within the HOTSPOT service doesn't work anymore.
Upgraded from 6.79.2 to 7.1.1 no changes in already working Hap Lite, now I get Handshake failure.
Downgraded and it works back again.
holvoetn
Tue Jan 18, 2022 4:17 pm
Hi All,
Hotspot is an issue in general since ROS 7.
maaathieu
Tue Jan 18, 2022 4:59 pm
I found something weird on my RB750Gr3 running v7.1.1:
when this rule is enabled:
 0    ;;; defconf: masquerade
      chain=srcnat action=masquerade out-interface-list=internet ipsec-policy=out,none
my pppoe client are stable.
as soon as I disable this rule, that I don't need, my ppp clients are disconnected after a few seconds, whith this message in the log:
terminating... - peer is not responding
If a re-enable this rule, everything goes back to normal.
maaathieu
Tue Jan 18, 2022 5:25 pm
forget my previous message: a script couldn't run without this rule, then believed internet was down and disabled the lan port. my bad.
mktwifi
Tue Jan 18, 2022 6:10 pm
Hi All,
now it works back with 7.2 rc1.
holvoetn
Tue Jan 18, 2022 7:15 pm
Other issues with cpu and accessibility preventing me to use that version.
rodpp
Tue Jan 18, 2022 10:26 pm
I had a Wireguard problem here, maybe someone can check.
I configured an external paid VPN service. To change the contry the connection output will be, I have to change the endpoint field in the Peer configuration.
The problem is that after changing the endpoint address, the RouterOS ramdomly connect to the old and to the new value.
For example, the endpoint is configured as us.samplevpn.com. I change it to de.samplevpn.com. After that, RouterOS connect to us.samplevpn.com, disconnect and connect to de.samplevpn.com, disconnect and connect to us.samplevpn.com again, and so on...
Rebooting the router after the configuration change fix the problem.
eworm
Forum Veteran
Forum Veteran
Tue Jan 18, 2022 11:02 pm
That's how Wireguard works... If a package with valid authentication from a peer is received the current endpoint address is updated automatically. Generally this is a good think as it help for a stable connection when peers are roaming.
I guess the reboot helps as it clears your tracked connections. I would suggest to try two things here:
  • Remove the old connection from tracking (/ip/firewall/connection/) or
  • Update the listen port on wireguard interface
Not tested, but either of both should fix the issue.
andacb
Wed Jan 19, 2022 1:01 pm
Could someone please comment on the availability of "Dude Server" in 7.x.x versions?
Thank you,
alfonzz
Wed Jan 19, 2022 1:43 pm
I have 7.1.1 on RB4011 with CAPS-man - here is some bug with bridge/capsman - any change with bridge (disable port, or change mode to rstp/none) cause almost frozen routerboard, reboot required.
Simple: create bridge with eth ports, create caps-man with datapath add to bridge, then add cap.
without capsman disable/enable bridge, change rtsp etc. works normally, but with bridge/port/dynamic cap interfaces = "death"
tested on latest RC 7 build and same result, on ROS6 - no problem
This configuration was applied on reseted device with v7 - so its no relevant to upg with config from v6 to v7.
indy
Thu Jan 20, 2022 11:17 pm
I am also having massive performance problems with the RB3011 and RouterOS v7.
Other devices like HAP-AC2 or mAP do not suffer from this.
Not to be too negative though - this is a great release with many desirable features!
ivicask
Fri Jan 21, 2022 12:17 am
Noticed same bug with same setup.
mducharme
Trainer
Trainer
Sat Jan 22, 2022 8:17 pm
I'm sure they will add defaults for those later. They probably do not consider it to be urgent at this time, and are focusing on fixing a lot of bugs instead of dealing with minor things like this.
leonardogyn
Sun Jan 23, 2022 12:18 am
I have uploaded a VERY strong case on 'dissapearing items on reboot' to Mikrotik (SUP-71205). I connected to a RB2011 running 7.1.1, generated a support file, issued a reboot, and mayhen was made: after the reboot, VLAN interfaces were gone, bridge interface was gone, ovpn-client interface was gone, etherNN interfaces that had custom names were all renamed back to etherNN default names (which breaks other things, like pppoe-client that was attached to ether1-EXTERNAL and became attached to no interface after reboot). I had to go physically to that RB to fix it, as the pppoe-client interface, now attached to nowhere, couldn't connect. While there, downgraded to 6.49.2. When locally on the box, on first access, I created a new support file and uploaded both (before and after reboot) to Mikrotik team, hope they can figure out what's happening, as I have absolutely no doubt it's a SEVERE bug, which can render boxes completly down and might require physical access to repair it, just like it happened to me.
pe1chl
Sun Jan 23, 2022 1:30 pm
Yes it is a nasty issue but it could be easy to fix, maybe it is just a database thing where a transaction is used and it is not always properly committed. It could be a single line fix.
fragtion
Sun Jan 23, 2022 3:02 pm
@leonardogyn Firstly well done for catching that rare gremlin with such a precise and correct methodical approach. Could I ask what prompted you to create the supout before the reboot? It's not like there's a need to create supouts randomly all the time. I'm guessing something went wrong?
I'm asking because, FWIW, personally I'm not fully convinced that the config loss issue is actually triggered on a reboot. I was once having an issue with a wireguard interface (I can't remember exactly what the issue was, but something wasn't saving or taking effect correctly..) So I rebooted, and then afterwards the wg interface was corrupt (I think private key changed to some AAAAAAAAAAAAAAz or something) along with other missing config post-reboot. It's like the database actually got corrupt while the router was still running, but still "appeared" fine in winbox (some kind of caching maybe?) - until reboot, then the real destruction became clear/apparent. If that's true, then your "VERY strong case" may not actually even reveal any culprit in spite of your thorough approach, which is even more haunting as to how elusive this bug is. I hope everyone is making regular backups until a definite fix for this appears in the changelogs
leonardogyn
Sun Jan 23, 2022 5:58 pm
My idea to also create the supout file before the reboot was to "prove" the config, that was there minutes before, simply vanished, and that all was simply caused by a reboot. While I can't say the reboot is the culprit, it's very clear to us that a single reboot (that shouldn't be a big deal) at least makes the problem presents itself. As I had experienced that a few times before, I was prepared to "prove" what's going on. Instead of showing the "after" config and reporting what's missed, I created both (before and after) and now even the own Dev Team can compare configs, side by side, and *see* what's missing. That was my idea of generating both files, before and after reboot, because I was already expecting something to dissapear and, with both, comparing them would be trivial and stronger than just believing in my words that something went wrong.
I really don't know if that'll help on the solving itself. But I expect that's hard to question it's really happening, given the mayhen caused by a simple reboot on a config that was fully working 2 minutes ago. For that, I really believe having both files was a success.
And at the meantime, I have downgraded the few boxes I had upgraded to 7.1.1 back to 6.49.2. There's really no way I can afford to "lose" connectivity to remote located boxes. I'll personally give ROS7 a few more months of maturing. There's no question the evolution from ROS6 to ROS7, but I can't afford taking this risk.
riktoktik
Sun Jan 23, 2022 6:24 pm
I have a RB4011iGS+5HacQ2HnD and after upgrading to version 7.1.1 the SFP+ function was no longer available. Although the SFP+ interface worked and also the LED indicated the function, no communication / connection via SFP+ was possible. I could fortunately communicate with the router via the normal RJ45 interface.
Downgrading the packages and the routerBOARD fixed the problem.
(I'm using a 10Gtek 10GBase-SR SFP+ transceiver and a digitus fiber optic cable.)
jdodge
Mon Jan 24, 2022 6:27 am
I just upgraded a RB1100AHx4 to 7.1.1 -- on reconnection after reboot I see a warning that I don't have a key:
I thought it might be a weird 7.1.1 glitch -- the other two RB1100AHx4's I've upgraded were running 7.1 not 7.1.1 - so I tried a downgrade to 7.1 -- no luck, same message:
MikroTik RouterOS 7.1 (c) 1999-2021 https://www.mikrotik.com/
ROUTER HAS NO SOFTWARE KEY
You have 14h18m to configure the router to be remotely accessible,
and to enter the key by pasting it in a Telnet window or in Winbox.
Turn off the device to stop the timer.
See www.mikrotik.com/key for more details.
Current installation "software ID": C67I-7SHJ
Please press "Enter" to continue!
How do I fix this??!!
EvgenyPlekhanov
Mon Jan 24, 2022 7:31 am
Good afternoon.
Has anyone tried using chr-7.1.1 in EVE-NG?
When I created a node, the sequence of mac-addresses of interfaces was mixed up. In version 6.48.6 everything is fine.
elbob2002
Mon Jan 24, 2022 10:49 am
Contact support straight away. You're not likely to get an answer to that here on the forum.
leonardogyn
Mon Jan 24, 2022 2:29 pm
Mikrotik answer on the dissapering config items on reboot couldn't be more frustrating ... boxes were working for years, problems started (as reported) right after upgrading to ROS7. Others are also complaining of similar problems. But more than not acknowledging the problem, Mikrotik just wants me to reinstall the ROS7. As said, I have already downgraded, will wait ROS7 get really mature.
Your described configuration loss and long creation of supout file, may be due to disk errors, Please save your configuration and then perform Netinstall on this device to fix disk errors, after that reconfigure and monitor, if same issue appears again let us know.
Best regards,
pe1chl
Mon Jan 24, 2022 2:32 pm
Mikrotik answer on the dissapering config items couldn't be more frustrating ... boxes were working for years, problems started (as reported) right after upgrading to ROS7. Others are also complaining of similar problems. But more than not acknowledging the problem, Mikrotik just wants me to reinstall the ROS7 ...
I can already assure you that this will not help! If anything, my problem has STARTED after I did that (I reinstalled and cleared the config and imported it from a saved export, from that time I am losing the ipsec identities after every reboot)...
leonardogyn
Mon Jan 24, 2022 2:50 pm
At the end, I just lost my time trying to create supout files to help. Will just stay at ROS6 until Mikrotik dev team solves this SEVERE problems on ROS7.
mafiosa
Mon Jan 24, 2022 8:19 pm
Same issue. WIth PCC 140+105 mbps I am getting 86-90% utilization. v7.2 RC1 doesn't solve the problem.
k0st3k
Tue Jan 25, 2022 12:31 am
dell r420 ros x86 7.1.1. After ac power problems lost some config bridge, vlan, dhcp....
kevinlukas
Tue Jan 25, 2022 7:24 am
I am using router hEX - 750 GR3, when I upgrade RouterOS version v7.1.1 (stable) or RouterOS version v7.2rc1 (testing), error occurs as shown below.
Bandwidth test is not full speed 1 Gbps on total Tx/Rx Current, even when I am using bonding ethers with command "send" or "both" , but before that I use RouterOS version 6.48.6 (long-term) this is not the case.
I have tried to reset configuration (back to default) and reconfigure step by step, but the situation is still not fixed.
Is RouterOS v7 not good support for old model routers, specifically architectures: MMIPS, MIPSBE ?!!
Thanks.
osc86
Tue Jan 25, 2022 10:47 am
I think I just got this "ROUTER HAS NO SOFTWARE KEY" problem on an RB941-2nD. Before the device went offline, it showed 7.1.1 (Level 0) via snmp. I have to check tomorrow.
mafiosa
Tue Jan 25, 2022 1:40 pm
I am really pissed with Mikrotik, opened a ticket on 12th Jan regarding high CPU utilization on RB3011. Sumitted supout.rif and all relevant info asked by them, no reply on the ticket till today.
https://help.mikrotik.com/servicedesk/s ... /SUP-71297
mkx
Tue Jan 25, 2022 1:53 pm
I am really pissed with Mikrotik, ...
If this pisses you off so much, why don't you downgrade your very important router to 6.49 and wait for v7 to stabilise enough to meet your operational demands?
mafiosa
Tue Jan 25, 2022 3:53 pm
Already downgraded but that doesn't justify them not answering the ticket.
sbhokray
Tue Jan 25, 2022 4:27 pm
hi!
after using the CHR for a while on hyper-v, I have upgraded to the all new CHR7.1 stable.
so far so good. the only thing am missing is, I am unable to uninstall functionality's which i do not use.
I tried uninstalling wireless, hotspot IPV6 but there is no option to do this under the packages in system menu.
am I finding them in a wrong menu? or Mikrotik 7.1 is made to stay with all this options.
pe1chl
Tue Jan 25, 2022 4:36 pm
Yes, unfortunately this possibility was removed by putting the entire RouterOS except some really niche functions in one big package.
I agree that was good for some low-level functions like dhcp,ppp,security,ipv6 etc that have lots of inter-dependecies, but frankly I think wireless and hotspot do not belong there.
Nothing we are going to change about that...
avaz
Tue Jan 25, 2022 5:52 pm
Forgive me for my english
I upgraded my CCR1036 to version 7.1.1 , but I noticed an item in openvpn
In ppp active sessions , I see two sessions in winbox for the same user but I can't see these sessions in the command line
Is this a winbox or os router bug?
sterod
Vonage SIP Problems
Tue Jan 25, 2022 6:16 pm
I am writing to advise of a problem I encountered with a CCR1009-8G-1S-1S+ that was upgraded to v7.1.1. I received a call from the client that their Vonage VOIP service was not working. At first I thought it was a problem with the Vonage VTA adaptor and I proceeded to replace it with a spare. After doing so, the problem remained and the two numbers associated with the Vonage service would not register (could not be provisioned). I tried a variety of things such as disabling the SIP helper, adding NAT rules for TCP/UDP 5060 and nothing worked. I then took the VTA adaptor to a different location on another network and found that it worked immediately. This was very odd. I took the adaptor back to the office and plugged it into the CCR and again, the numbers would not register. After tearing my hair out with a very unhelpful Vonage support person, I proceeded to downgrade the CCR back to 6.49.2 and on the subsequent reboot the Vonage VTA immediately started working. I have no explanation for this, but there must be some issue with 7.1.1 and SIP with the CCR1009.
EDIT: My problem is the same as that of post #281 as I also have a WAN over PPPoE VLAN connection on this CCR.
RohanAJoshi
Tue Jan 25, 2022 6:17 pm
Stabilize ?
Stable version = Stabilized Version, right ?
I am with ccr2004 with random reboot issues from nearly 1.5yrs, no fix till now, there is whole topic going on.
Support asked spout, I gave, nothing in that spout, then support asked spout via serial cable with watchdog disabled, which means router will not reboot, i need manual reboot, router was in remote location, I cant do that., but others did and support find nothing in it. 1.5 yrs, same situation.
They released half baked 7.1.1 as stable 7.1.1, which is not stable at all. its not even alpha capable, forgot beta release.
7.1.1 is rebooting for all ccr1009 users, there are lot of complaints about cpu going nuts.
So, its obvious that users will get pissed.
mkx
Tue Jan 25, 2022 6:28 pm
Stabilize ?
Wrong. If you can't afford downtime or are not willing to chase bugs, then
  1. closely follow discussions on this vivid forum to assess general opinion on stability of a particular version on your particular hardware
  2. create lab setup where you can test and verify both upgrade procedure and fitness for your particular setup and if not satisfied, go back to #1
Nothing that software producer states about some particular release shouldn't make you skip any of steps above, it can only intrigue you into looking at some particular release more closely.
pe1chl
Re: Vonage SIP Problems
Tue Jan 25, 2022 8:16 pm
Why did you upgrade it? The issue you describe is known, and there should be no reason to upgrade a CCR router to 7.1.1 unless maybe you want higher
performance BGP and are working in an experimental setting. Certainly not on a customer site!
sterod
Tue Jan 25, 2022 8:49 pm
I haven't had issues with 7.1.1 on any other my client sites so I decided to give it a try. would you be kind enough to tell me where this problem is known so I can read about it please?
pe1chl
Tue Jan 25, 2022 9:06 pm
E.g. message #281 in this topic, but also other places where issues with SIP are discussed. it is likely related to DSCP. I have issues with DSCP i.c.w. PPPoE as well.
draid
Wed Jan 26, 2022 10:47 am
Hello guys,
Recently I've found that all of the information for the SFP interface is missing on v7.1.1. At the moment there is no information listed at all, something that was present in v6.x.x. Currently using Hex S and S-85DLC05DI module. Anyone having the same problem on v7?
Ullinator
Wed Jan 26, 2022 12:48 pm
Hello guys,
It´s not a general bug in V7.1.1, because in my ARM and MIBSBE devices all SFP+ interfaces reports correctly.
Unfortunatly I have no MMIPS device running with SFP modules to verify.
tigro11
Wed Jan 26, 2022 1:27 pm
Hi Guys, I noticed that the OpenVPN in UDP sessions remain active even if I am disconnected.
Check if possible.
Thank you
Valerio
Ciao Ragazzi, ho notato che la OpenVPN in UDP, le sessioni rimangono attive anche se mi sono scollegato.
Se possibile verificare.
Grazie
Valerio
draid
Wed Jan 26, 2022 6:08 pm
Hello guys,
It seems to be working for you. Interesting enough it was working on v6.x.x without any problems. I've tested it now with another SFP module and it seems to not be from it. With both modules the problems remains. Don't have a SM module to test but I'd say that this is most likely coming from the v7 and as you mentioned it isn't a general thing for all SFP modules and architectures. The connection is working fine but no information. I'm using OM2 cable.
BitHaulers
Wed Jan 26, 2022 6:47 pm
The number of problems I've solved by NetInstalling , or NetInstalling and THEN factory resetting and importing my config is staggering. I don't care if the file system check says the install is good, there's some NVRAM corruption going on that can't be measured/detected, but NetInstall fixes the issue 99% of the time, and factory reset after a NetInstall and upgrading the bootloader solves the rest of the problems. If that SOP (standard operating procedure) doesn't fix it, and a downgrade with NetInstall doesn't fix it, I just replace the whole device. If I can't get a board to NetInstall, but other ones do, I replace the equipment. Something is wrong with the bootloader. It will act up in the future.
Before you deploy any Tik in an operational environment, I think you should NetInstall it, upgrade the bootloader, and factory reset it. Straight out of the box, even. I've gotten "new" things from suppliers that were obvious returns once I logged in.
NetInstall has a history of being flaky, but I think I've found a solution. Use a cheap USB to ethernet adapter with a Realtek chipset. Now, NetInstall works every time. There's some issue with Windows 10+ and integrated Intel NICs. It works until it doesn't, and then it never works again. Plug in the USB adapter, now it works every time. Go figure. Didn't have these problems with Windows 7, but we obviously can't keep that around for NetInstall.
So if I "fix" a problem with NetInstall, and it happens again, and I fix it a second time with NetInstall, I replace the board, because I suspect bad NVRAM. That's cheaper than the labor to chase the bug down. This solves almost all of my problems to date.
I read most of these threads, and I think every one of us should be NetInstalling and importing your existing config afterwards when trying out these new releases, before you post, just to take that variable out of the equation. I'd put money on that being a reason Mikrotik can't reproduce a lot of these problems in the lab. I bet they NetInstall all the time to start with a clean slate, and you guys haven't reformatted that NVRAM...ever, and still expect it to all just "work".
bort900
Wed Jan 26, 2022 9:02 pm
EDIT: Worked fine after a netinstall. I took heed from the post in this thread to do a netinstall. I will be doing netinstall for all 6 to 7 upgrades now.
hEX S on 7.1.1 doesn't seem to use multiple routing tables correctly.
Simple setup with two gateways, using a mangle rule to mark certain traffic and route them out a specific gateway. Works fine in 6.x, but doesn't work on 7.1.1 or 7.2rc1.
In ROS7, I was only able to get route rules to have any effect on traffic. Simply using a mangle rule to mark routing did not work, nor did adding a route rule with that routing mark as well.
After a few minutes of experimenting, i eventually locked the unit up with high CPU usage (from routing and management).
Everything works fine in ROS6. I am aware in ROS 7 now you must add a routing table via the Routes menu and have FIB checked first before you attempt to set the mangle rule and the gateway route.
A confirmation of this bug on this platform would be helpful. I have downgraded to 6 for now, but would really like to use 7 for its wireguard ability, which really works great! just need the routing to work as well!
Thank you MikroTik team!
draid
Wed Jan 26, 2022 9:55 pm
A quick update on the problem with the missing information from the SFP module on my Hex S. I've tried some things in order to resolve the problem but nothing seems to be working, tried even the v7.2 but without any success. Few minutes ago I downgraded back to 6.42.2 and surprise everything on the SFP worked as expected. Now I'm more than convinced that this is a problem with v7 on Hex S or MMIPS in general.
Tom5DB
Thu Jan 27, 2022 2:55 pm
update cannot be done on wsap ac, no enough of disk space :-(
Same here, I tried several times but still no good result.
avaz
Fri Jan 28, 2022 12:17 am
Hello everyone
I encountered another strange event after upgrading to router OS to 7.1 ,7.1.1 or 7+.
On site-to-site ipsec tunnels ( with 3des + sha1 ) and CISCO routers I noticed an error in the cisco log "%CRYPTO-4-RECVD_PKT_MAC_ERR:
decrypt:" , from what I found 3DES encryption presents some divergence in version 7.1 for this case, when rolling back to 6.49, everything works again
maxb
Fri Jan 28, 2022 2:45 am
Router hexS, upgrade from 6.49.2 to 7.1.1
Connection WAN PPPoE over VLAN
After the update, SIP connections to external servers are no longer working.
Before mikrotik I had the same problem with same connection but a different gateway, registration of SIP clients was impossible.
After downgrade to version 6.49.2 everything works again.
Stefano
I'm experiencing the same issues
pe1chl
Fri Jan 28, 2022 11:39 am
We are all experiencing the same issues. No need to keep reporting that.
prawira
Trainer
Trainer
Mon Jan 31, 2022 6:44 am
hello all,
i manage to make a small lab for OSPF within ros v7.1.1 while read the documentation on https://help.mikrotik.com/docs/pages/vi ... eId=328218
the above doc said :
Notes
OSPF protocol supports two types of metrics:
type1 - OSPF metric is the sum of the internal OSPF cost and the external route cost
type2 - OSPF metric is equal only to the external route cost.
question: how to set the ospf metric as type1 or type2 for the interface under ros v7.1.1 ?
thank you
hifigraz
Re: v7.1.1 is released! ( RB4011iGS Unusable )
Mon Jan 31, 2022 10:14 am
Before the upgrade, the RB4011iGS's (I've got three of them) were working perfectly stable. Now they are completely rubbish.
RX-Package drops though they are not loaded at all. And render completely broken after a couple of days. Only a reboot helps.
Support is informed, but no answer by now.
Consider not upgrading to ROS 7 if you are using a RB4011iGS ...
pe1chl
Mon Jan 31, 2022 10:53 am
I have been running my RB4011 on 7.1.1 for more than a month without issue. Now I have upgraded to 7.2rc3 (7.2rc1 was rubbish here).
The RX drops appear to be related to reading the device temperature. You may have SNMP monitoring that regularly reads the temperature.
It appears that during each temperature reading there is some chance of RX drops (maybe it disables interrupts for too long).
clambert
Mon Jan 31, 2022 3:25 pm
I have experienced the same behavior on the RB1100AHx4 on RouterOS v6 with temperature readings via SNMP queries.
jbl42
Mon Jan 31, 2022 3:46 pm
It depends.
For serious routing and working IPv6 support, RB4011 better stays on 6.49.2
For more home/small office/lab oriented setups (some VLAN/bridging, some queues for VOIP, some firewalling, outgoing srcNAT, no IPv6) RB4011 works well with ROS 7.1.1 and brings nice features like bridge VLAN filter hw offloading, cake/fq_codel queues and Wireguard
berdux
Wed Feb 02, 2022 4:37 pm
Not sure if its a bug or not but after I upgraded from 7.1 to 7.1.1 some (70%) of my DHCP static lease entries got dropped (RB5009UG+S+)
In my case it has happened twice now, but not right after the upgrade.
Just at two random times in the last month about half of my dhcp leases got lost, different ones each time (hAP ac^2) (model: RBD52G-5HacD2HnD)
Is there anything on this?
fmk
Wed Feb 02, 2022 5:03 pm
I got Kernel panic/reboot on CCR1036-12G-4S after upraded to v7.1.1, so back to v6 where I had over 1 year of uptime..
Too bad because I liked bgp on v7, so I'm waiting for the next Stable.
pe1chl
Wed Feb 02, 2022 5:31 pm
Did you reboot at that time? There is lots of mention about random pieces of configuration going missing at a reboot in 7.1 and 7.1.1
Hopefully it is now fixed in 7.2rc3 but I have not verified it yet.
berdux
Wed Feb 02, 2022 8:46 pm
Hmmm, both times could have been after a reboot. It reboots every morning at 4:30 am..
I will disable that for now
vecernik87
Forum Veteran
Forum Veteran
Thu Feb 03, 2022 8:21 am
Somehow, ARP pings don't seem to work... Tested on 7.1.1, hAP ac2, tested both VLAN as well as normal bridge interface. Another router with v6 (and almost same config) works without issue.
Can anyone confirm? (just to be clear, interface is correct. If the interface was wrong, it would simply timeout but notice the status - "ping failed")
Sob
Thu Feb 03, 2022 8:40 am
Confirmed with CHR 7.1.1, same "ping failed" for ARP pings.
eworm
Forum Veteran
Forum Veteran
Thu Feb 03, 2022 11:07 am
Yes, also confirmed by Mikrotik in SUP-69080 ("ARP ping fails (v7)").
stormeporm
Thu Feb 03, 2022 11:43 am
So ive updated my CCR1009-8G-1S-1S+ it worked until I updated the routerboard firmware.
Now its in a bootloop.
I had v7RC4 running on it as a test and it was working fine.]
A fresh netinstall fixed it. But it does not make me very eager to use this thing in production
harry66
Thu Feb 03, 2022 2:50 pm
Something weird in proxy access rules. Winbox 3.32 and Console config show different.
RB5009/ROS7.1.1 here
Elisium91
Thu Feb 03, 2022 3:45 pm
Same situation. Kernel failure \ reboot. CCR1016-12G ROS v7.1.1\v7.2rc3. Running OSPF\LDP\MPLS (no BGP enable)
Router crashed after 1-2 min when i have enabled any VPLS connection. When i disable VPLS links - router works well =\
kennnnnnnneth
Fri Feb 04, 2022 3:41 am
Broken on my rb4011 test unit. Clean install, extremely basic factory settings, no firewall, no nothing. I never got far enough to load in my full test config. Reset to factory, netinstalled, same issue each time.
Problems I notitced:
High CPU utilization.
High CPU IRQs.
Ping replies, when connected directly to one of the ethernet ports, take 5-15ms. Considering the rb4011 has a 1.4ghz quadcore and a practically empty config, that's like fifty times higher than it should be. I imagine this has something to do with high CPU utilization.
SFP+ port fails. Worked fine in all versions of ros6. Now it only works intermittently with a variety of different SFP modules. When it works, it's stuck at 1G.
Weird thing is, 7.1.1 runs fine on the rb4011 running my homelab (I literally ordered the two rb4011 units together), which has dozens of filters, raws, mangles, some queues, and 14 subnets. It also works fine on the hEX S I have installed at my parents' place, which also has multiple subnets and firewalls.
I'll come back next release and see what weirdness awaits!!
bda
Fri Feb 04, 2022 12:53 pm
ROS7.1.1 causes CCR1009-7G-1C-1S+ to crash with one ovpn session!
Any suggestions?
pe1chl
Fri Feb 04, 2022 1:15 pm
Any suggestions?
1. try 7.2rc3
2. when not fixed, install 6.49.2
Aureliusz
Fri Feb 04, 2022 3:32 pm
I have many Mikrotik devices, but on two I decided to install version 7.1.1 - fast - in case of connecting via www to Mikrotik the routing table is very lazy - the second thing is where the "%" characters next to the gateway names (come from both in WinBox and www )
bda
Fri Feb 04, 2022 10:08 pm
Any suggestions?
1. try 7.2rc3
Hi, thanx but 6.49.2 has no ovpn-udp, like all 6.x
pe1chl
Sat Feb 05, 2022 11:55 am
That is true, but 7.x is not in a state with usable OpenVPN. So for now, the only way to have OpenVPN is to run it on a separate device (server).
dimacbz
Sat Feb 05, 2022 8:35 pm
v7.1.1 RB5009 Link SFP+ <---> any device with SFP (SFP+) packet loss 35-50%, regardless of the load. Tested on two RB5009.
v6.49.2 CRS328 Link SFP+ <---> any device with SFP (SFP+) packet loss 0%, regardless of the load.
prawira
Trainer
Trainer
Sun Feb 06, 2022 10:34 am
hi all,
i did the OSPF lab with 3 hap-mini routers with ros v7.1.1 today.
what i found are :
+ on /ip route table, no more pref-source that ussualy came from the ip addresses added on /ip address. so, what is the pref-source for ?
+ export not working, wait almost forever and the result is nothing
+ Make supout.rif stop at 85%
is it the bug for hap-mini only or for v7.1.1 or hap-mini too small for v7.1.1 ?
EDITED: i try to add the mpls config on it and end-up with error
[admin@MikroTik] > /ip/address/print
Columns: ADDRESS, NETWORK, INTERFACE
# ADDRESS         NETWORK      INTERFACE
0 172.16.1.2/32   172.16.1.2   loopback
1 10.1.1.2/30     10.1.1.0     ether1
2 192.168.2.1/29  192.168.2.0  ether2
3 10.1.2.1/30     10.1.2.0     ether3
[admin@MikroTik] > /mpls/ldp/add lsr-id=172.16.1.2
action timed out - try again, if error continues contact MikroTik support and send a supout file (13)
P
pe1chl
Sun Feb 06, 2022 12:19 pm
pref-source is the source address that the router uses when making outbound connections to an address in that range.
when you have a number of routers that are interconnected using link subnets, it may be a good idea to have "the main router address" (e.g. the router address on the LAN) as the pref-source everywhere.
prawira
Trainer
Trainer
Mon Feb 07, 2022 4:14 am
one of our RB1100AHx2 having boot-loop after upgrade to v7.1.1 with error message kernel failure.
unfortunatelly the ether13 port has been maffunction and no chance to do netinstall.
how to get the working firmware file for RB1100AHx2 ? AFAIK the file with extention .fwf
tia
mkx
Mon Feb 07, 2022 11:12 am
Download NPK file, open it with 7z ... fwf files are in /etc directory. Make sure you select file with name exactly matching firmware-type shown by /systen/routerboard/print.
Copy file to CCR and it should be shown as available for upgrading routerboot.
Edit: just hit me: with device in boot-loop the above procedure will not work. I hope there's option to upgrade routerboot via serial port ...
pe1chl
Mon Feb 07, 2022 12:31 pm
Users should learn to partition their device prior to upgrading, when they have a router like RB1100AHx2 where that is a possibility.
k0st3k
Mon Feb 07, 2022 3:31 pm
vlan inside eoiptunnel inside openvpn. When adding to bridge eoip couses system reboot ;) Works fine in 6.xx........x86
dmq
Mon Feb 07, 2022 10:52 pm
I just ordered a RB4011iGS+5HacQ2HnD-IN. Can someone tell me that it will be ever possible to use the new WifiWave2 without deactivating the 2.4 GHz radio (legacy driver in parallel)? This would be really sad if not possible. Maybe it is on the roadmap? Thanks in advance.
ahmedelbarbary
Tue Feb 08, 2022 10:12 pm
Updated from last v6 release, i can't ping in routing table in Tools ping this option is removed ?
jimmer
Wed Feb 09, 2022 12:52 pm
I am not sure if its a 7.1.0 or a 7.1.1 issue, I remember it showing in 6.49.x but I am not seeing any client/station association, disassociation and signal strength logging at all from either of my CAP's or the CAPsMAN controller, ive checked the logging, I am seeing log entries from all devices, e.g. winbox login, logging changes ete, no station information at all.
I have a PC that is dropping in and out and I cant see what reason it is disassociating for anywhere in the logs.
Anyone else seeing the same problem?
I am logging to a syslog destination, firewall, winbox login messages - everything else is appearing in the logs except for CAPsMAN related (dis)associations
Kind Regards,
Jim.
mducharme
Trainer
Trainer
Thu Feb 10, 2022 3:21 am
This is fixed in 7.2rc2.
Jotne
Thu Feb 10, 2022 8:20 am
Still very long export time on devices with little CPU in 7.2rc2 (compare to 6.x)
viewtopic.php?p=908897#p908897
emils
Thu Feb 10, 2022 10:28 am
New version v7.1.2 has been released:
viewtopic.php?t=183109
Users browsing this forum: Bing [Bot] and 2 guests
