tmichaud
TG-BT5-IN Firmware upgrade
Tue Dec 21, 2021 7:05 pm
I have a TG-BT5-IN and I'm not able to Download and Install new firmware.
Current version
1.6.7
Latest version
2.3.1
When I select "Download and install" on the Android version of Mikrotik Beacon Manager nothing appears to happen.
Also can not locate a downloadable version of 2.3.1 to enable the "Manual upgrade".
Does any have the location of TG-BT5-IN version 2.3.1 firmware?
Thanks,
Tom
davorjs
Re: TG-BT5-IN Firmware upgrade
Fri Jan 07, 2022 1:52 am
Hi Tom,
I had the same question.
I noticed an upgrade to the Mikrotik Beacon Manager app yesterday, and when I upgraded that and went to configure my tag, I was able to upgrade the tag as well.
Cheers, Dave.
amir1
Mon Mar 14, 2022 5:24 pm
any solution? i have the same problem after automatic upgrade from version 1.6.7-orr to 2.3.1-orr the device is broken and no longer recognizable in Beacon manager android or IOS app. it seems being in OTA mode and does show unix time 1970-01-01 01:00:00.
VK7HSE
Wed Jul 20, 2022 3:04 am
You are not alone, I've just received a tb-bt5-in and just saw the firmware upgrade and ran it, and my tag is now in the same mode as mentioned, l don't know what to do with it!
Is there a way to get the firmware and update it manually? That's an option in the app but there's nothing on the mikrotik download server.
This is a new record for me to brick an item within a minute of unpacking it! 😝
*** update ***
https://help.mikrotik.com/docs/display/ ... deFirmware
Has some files, I uploaded but I'm not sure what mode this tag has gone into as placing a magnet doesn't light up the led...
Users browsing this forum: Deantwo, jaclaz, mgual, Shambler, tangent and 107 guests
