com2com
ecmp load balancing
Tue Dec 21, 2021 8:42 pm
In ros 6 a have ecmp load balancing. Now in new rb5009 i try configure ecmp.
My config.
add name=bridge1
set [ find default-name=ether2 ] name=MGL
/interface pppoe-client
add disabled=no interface=ether3 name=RST user=fz5
/interface bonding
add mode=802.3ad name=bonding1 slaves=ether4,ether5 transmit-hash-policy=\
    layer-2-and-3
add name=WAN
add name=LAN
add name=dhcp_pool1 ranges=192.168.1.2-192.168.1.254
add address-pool=dhcp_pool1 interface=bridge1 lease-time=1d10m name=dhcp1
/ppp profile
set *0 remote-address=10.253.252.251
/routing table
add disabled=no fib name=to_WAN1
add disabled=no fib name=to_WAN2
add bridge=bridge1 interface=ether1 trusted=yes
add bridge=bridge1 interface=ether6 trusted=yes
add bridge=bridge1 interface=ether7 trusted=yes
add bridge=bridge1 interface=ether8 trusted=yes
add bridge=bridge1 interface=sfp-sfpplus1 trusted=yes
add bridge=bridge1 interface=bonding1 trusted=yes
add interface=MGL list=WAN
add interface=RST list=WAN
add address=192.168.1.1/24 interface=bridge1 network=192.168.1.0
add address=95.174.109.112/20 interface=MGL network=95.174.96.0
add address=192.168.1.0/24 dns-server=192.168.1.1 gateway=192.168.1.1
set allow-remote-requests=yes servers=\
    8.8.8.8,8.8.4.4,95.174.97.43,95.174.96.2
add action=fasttrack-connection chain=forward connection-state=\
    established,related hw-offload=yes protocol=tcp
    established,related hw-offload=yes protocol=udp
add action=accept chain=forward comment="FastTrack Connection" \
    established,related,untracked
    ipsec-policy=in,ipsec
    ipsec-policy=out,ipsec
add action=drop chain=input dst-port=53 in-interface=MGL packet-mark="" \
    protocol=udp
add action=drop chain=input dst-port=53 in-interface=RST protocol=udp
    invalid
    in-interface-list=!LAN
    connection-state=invalid
/ip firewall mangle
add action=mark-connection chain=prerouting connection-mark=no-mark \
    in-interface=MGL new-connection-mark=WAN1_conn passthrough=no
    in-interface=RST new-connection-mark=WAN2_conn passthrough=no
add action=mark-routing chain=prerouting connection-mark=WAN1_conn \
    in-interface=bridge1 new-routing-mark=to_WAN1 passthrough=no
add action=mark-routing chain=prerouting connection-mark=WAN2_conn \
    in-interface=bridge1 new-routing-mark=to_WAN2 passthrough=no
add action=mark-routing chain=output connection-mark=WAN1_conn \
add action=mark-routing chain=output connection-mark=WAN2_conn \
add action=masquerade chain=srcnat out-interface=MGL
add action=masquerade chain=srcnat out-interface=RST
add disabled=no distance=10 dst-address=0.0.0.0/0 gateway=10.253.252.251 \
    pref-src="" routing-table=main scope=30 suppress-hw-offload=no \
    target-scope=10
add disabled=no distance=1 dst-address=0.0.0.0/0 gateway=95.174.97.43 \
    target-scope=10
i try make ecmp route with same distance
    target-scope=10
    target-scope=10
add disabled=no distance=1 dst-address=0.0.0.0/0 gateway=10.253.252.251 \
   target-scope=10
if route in table main ecmp routes connected. if i try use routing mark it not work.
Users browsing this forum: No registered users and 36 guests
