tilat
Route all traffic via Wireguard interface
Tue Dec 21, 2021 8:46 pm
Hi all,
I am trying to route all traffic through the wireguard interface.
Device: mikrotik hex s
Configuration:
# dec/21/2021 21:26:00 by RouterOS 7.1
# software id = B44A-P90U
# model = RB760iGS
add name=bridge1
set [ find default-name=ether1 ] l2mtu=2026 mtu=2026
set [ find default-name=ether2 ] l2mtu=2026 mtu=2026
set [ find default-name=ether3 ] l2mtu=2026 mtu=2026
set [ find default-name=ether4 ] l2mtu=2026 mtu=2026
set [ find default-name=ether5 ] l2mtu=2026 mtu=2026
set [ find default-name=sfp1 ] disabled=yes l2mtu=2026 mtu=2026
/interface wireguard
add listen-port=13231 mtu=2026 name=wg0
add name=dhcp_pool0 ranges=192.168.1.2-192.168.1.254
add address-pool=dhcp_pool0 interface=bridge1 lease-time=1d name=dhcp1
/port
set 0 name=serial0
/routing table
add disabled=no fib name=via-wg
/ipv6 settings
/interface wireguard peers
add allowed-address=0.0.0.0/0 endpoint-address=77.zz.xx.yy endpoint-port=\
    63665 interface=wg0 persistent-keepalive=3s public-key=\
    "some_public_key="
add address=192.168.1.1/24 interface=bridge1 network=192.168.1.0
add address=10.0.1.3/24 interface=wg0 network=10.0.1.0
/ip dhcp-client
add default-route-distance=10 interface=ether1
add address=192.168.1.0/24 dns-server=192.168.1.1 gateway=192.168.1.1
set allow-remote-requests=yes
add disabled=no distance=10 dst-address=0.0.0.0/0 gateway=192.168.9.1 \
    pref-src="" routing-table=main scope=30 suppress-hw-offload=no \
    target-scope=10
add disabled=no distance=1 dst-address=0.0.0.0/0 gateway=wg0 pref-src="" \
    routing-table=via-wg scope=30 suppress-hw-offload=no target-scope=10
/system clock
set time-zone-name=Europe
WHERE
10.0.1.3 the ip of my router for wg0 interface;
10.0.1.1 the ip of my remote host for wg0 interface;
192.168.9.1 the ip of default geteway from the ISP.
the wg interface is working as expected ( i can ping the remote host from the router )
Routes:
admin@MikroTik] > /ip route print
Flags: D - DYNAMIC; A - ACTIVE; c, s, y - COPY
Columns: DST-ADDRESS, GATEWAY, DISTANCE
#     DST-ADDRESS     GATEWAY      DISTANCE
0  As 0.0.0.0/0       192.168.9.1        10
  DAc 10.0.1.0/24     wg0                 0
  DAc 192.168.1.0/24  bridge1             0
  DAc 192.168.9.0/24  ether1              0
1  As 0.0.0.0/0       wg0                 1
[code]
Symptoms:
 1. IF I add a route "0.0.0.0/0   wg0" with default table main then i can't ping 8.8.8.8 host
 2. IF I add a route "0.0.0.0/0   wg0" with table "via-wg" then I can't ping 8.8.8.8 host
Question: Could someone explain what should be done in order to route all traffic via wg tunnel?
 NB: I've already read several posts on this forum and it looks like I should use routing table. But I don't have a full understanding how exactly it should be done - not a network engineer.
 Thank for any help in advance.
Sob
Re: Route all traffic via Wireguard interface
Fri Dec 24, 2021 9:55 pm
You can find some inspiration here: viewtopic.php?t=181205 (I recommend mainly my posts :))
anav
Sat Dec 25, 2021 12:32 am
Mind you the diagram from this post is very comprehensive and look ma NO HANDS (well no Ip address for wg interface were used or harmed in that photo) ;-)
viewtopic.php?t=174417#p859788
Cheers
and Merry Xmas Sob
Sob
Sat Dec 25, 2021 1:11 am
What's with address and WG interface?
Merry Xmas to you too, and here, have a lovely picture:
anav
Sun Dec 26, 2021 9:46 pm
Its always good to have options............
Sob
Sun Dec 26, 2021 10:34 pm
I don't think it answers the question.
anav
Tue Dec 28, 2021 3:38 pm
The problem for me is the OP has not fully described the WG setup.
I see ONE device only described and its not clear to me if his hex is a Server Router or a Client Router.
It is not clear what the other device or end of this tunnel consists of.
He does have the listening port configured which tells me the router hex is probably acting as a server.
Then he has wireguard peers setup but with the WRONG setup for allowed addresses (from server perspective..........
Then he has an endpoint setup which makes me think this is a Client Router.
Hence the confusion.
Finally the IP route he has 0.0.0.0/0 wg interface etc........
Tells me that the device is actually a CLIENT ROUTER .
In conclusion things are close, and it may be on the host side where things need to be amended?
The correct config assuming his is a client router and he wants to send all his internet bound traffic through the Remote SERVER connection.......
HEX Router
WIREGUARD INTERFACE
(no listening port required - client)
Private Key (YES but only for internal use)
Public Key (Yes, this is needed at the remote host and should be given to the remote host/service)
PEER INTERFACE
interface: wg0
Public Key: This is the public key given to the OP, FROM the remote Device or Service
Endpoint: 77.xx WANIP or URL of remote device/service
Endpoint Port: 63655
Allowed Address: 0.0.0.0/0
Persistent Keep alive: use something like 30 secs.....
The IP route the OP has is good although, I would do it slightly differently.
If the connection through wireguard goes down, the users will get internet through the main table.
If this is not desired ( and wants if no wg tunnel, then no internet) then the OP should use a Route Rule ......... lookup-only-in-table with source address of the LAN subnet.............
I would delete the WG Ip address, not required. and just gets in the way.
THe key to get this to work is at the remote site setup.........which we seemingly know nothing about.
I will attempt to delineate a Remote Server setup.....
WIREGUARD INTERFACE
listening port: 63655
Public Key (Yes, this is needed at the client site)
PEER INTERFACE
interface: wgRemote
Public Key: This is the public key from the OP given to the Server device/service.
Allowed Address: 192.168.1.0/24
Users browsing this forum: No registered users and 25 guests
