mikrotak
How to upgrade from 6.49.2 to 7.1
Wed Dec 29, 2021 2:30 am
I have MikroTik RB4011iGS+RM router.
7.1 does not show when I check for updates in PACKAGE LIST in WinBox.
How do I upgrade from 6.49.2 to 7.1?
DejanAgain
Re: How to upgrade from 6.49.2 to 7.1
Wed Dec 29, 2021 5:10 am
Any update is working when you download package, upload to ruter and restart. I guess 7.1 will do same, but I don't know how license will work, you should specify which hardware and which initial version was for someone who may help then
adcre
Wed Dec 29, 2021 12:02 pm
First I would check if version is ok on system:
] > system/check-installation
  status: installation is ok
and routerboard:
 system/routerboard/print
       routerboard: yes
             model: XXXX
          revision: YYY
     serial-number: BBBBBB
     firmware-type: CCCCCC
  factory-firmware: 6.47.10
  current-firmware: 6.49.2
  upgrade-firmware: 6.49.2
Current firmware and upgrade firmware should be in the same version and also the same version of your routeros
Then you have to say that you want to change from 6 channel to 7:
 > system package update set channel=upgrade
and usuall upgrade:
 >] > system package update check-for-updates
            channel: upgrade
  installed-version: 6.49.2
     latest-version: 7.1.1
             status: New version is available
] > system package update download
] > system reboot
and after reboot check again the installation and upgrade the firmware.
Best Regards,
Diego
kalamaja
Wed Dec 29, 2021 1:02 pm
Choose channel to "upgrade" to switch from 6.xx tree to 7.xx and after that you'll see new long-term, stable, testing trees. Choose stable or long-term and go. Don't forget to create binary backup before any upgrade to be able to fully recover if anything would go wrong.
mikrotak
Thu Dec 30, 2021 5:19 am
Thanks!
That worked!
venhow
Mon Jan 10, 2022 5:30 am
and routerboard:
       routerboard: yes
             model: XXXX
          revision: YYY
and usuall upgrade:
            channel: upgrade
] > system reboot
Best Regards,
Diego
It's must be the version 6.49.2?
adcre
Mon Jan 10, 2022 11:46 am
Starting version was 6.49.2 cause is the OP request.
If you have lower version I would first do upgrades following near releases First long-term channel if needed, then stable and then upgrade from 6 to 7.
In all upgrade steps check upgrade status and firmware upgrade.
Best Regards,
Diego
