blurrybird
7.1.1 - CAKE breaks IPv6
Wed Dec 29, 2021 2:35 pm
Hey all,
Seems that when I have a CAKE queue enabled on my WAN interface, IPv6 traffic stops flowing.
I have an RB5009 arriving soon, and I'd love to be able to run CAKE-based SQM on my network.
Any way to formally raise this as a bug or is that as good as done via this post?
Cheers.
/queue export compact hide-sensitive
# dec/29/2021 23:29:16 by RouterOS 7.1.1
# software id = 40RY-IE0B
# model = RBD52G-5HacD2HnD
# serial number = BEED0B51CF44
/queue type
add cake-diffserv=besteffort cake-nat=yes kind=cake name=cake-default
add cake-ack-filter=filter cake-bandwidth=50.0Mbps cake-diffserv=besteffort cake-nat=yes kind=cake name=cake-up
add cake-bandwidth=1000.0Mbps cake-diffserv=besteffort cake-nat=yes cake-wash=yes kind=cake name=cake-down
/queue simple
add bucket-size=0.001/0.001 name=cake queue=cake-down/cake-up target=ether1 total-queue=cake-default
/ipv6 export compact hide-sensitive
# dec/29/2021 23:33:09 by RouterOS 7.1.1
/ipv6 address
add address=::c6ad:34ff:feb5:8d5e eui-64=yes from-pool=abb interface=ether2
/ipv6 dhcp-client
add add-default-route=yes interface=ether1 pool-name=abb request=address,prefix use-peer-dns=no
/ipv6 firewall address-list
/ipv6 firewall filter
add action=accept chain=input comment="defconf: accept ICMPv6" protocol=icmpv6
add action=accept chain=input comment="defconf: accept UDP traceroute" port=33434-33534 protocol=udp
add action=accept chain=input comment="defconf: accept DHCPv6-Client prefix delegation." dst-port=546 protocol=udp src-address=fe80::/10
add action=accept chain=input comment="defconf: accept IKE" dst-port=500,4500 protocol=udp
add action=accept chain=input comment="defconf: accept ipsec AH" protocol=ipsec-ah
add action=accept chain=input comment="defconf: accept ipsec ESP" protocol=ipsec-esp
add action=accept chain=input comment="defconf: accept all that matches ipsec policy" ipsec-policy=in,ipsec
add action=drop chain=input comment="defconf: drop everything else not coming from LAN" in-interface-list=!LAN
add action=accept chain=forward comment="defconf: accept established,related,untracked" connection-state=established,related,untracked
add action=drop chain=forward comment="defconf: drop packets with bad src ipv6" src-address-list=bad_ipv6
add action=drop chain=forward comment="defconf: drop packets with bad dst ipv6" dst-address-list=bad_ipv6
add action=drop chain=forward comment="defconf: rfc4890 drop hop-limit=1" hop-limit=equal:1 protocol=icmpv6
add action=accept chain=forward comment="defconf: accept ICMPv6" protocol=icmpv6
add action=accept chain=forward comment="defconf: accept IKE" dst-port=500,4500 protocol=udp
add action=accept chain=forward comment="defconf: accept ipsec AH" protocol=ipsec-ah
add action=accept chain=forward comment="defconf: accept ipsec ESP" protocol=ipsec-esp
add action=accept chain=forward comment="defconf: accept all that matches ipsec policy" ipsec-policy=in,ipsec
add action=drop chain=forward comment="defconf: drop everything else not coming from LAN" in-interface-list=!LAN
/ipv6 nd
set [ find default=yes ] advertise-dns=no interface=ether2 ra-interval=5s-10s
blurrybird
Re: 7.1.1 - CAKE breaks IPv6
Wed Dec 29, 2021 3:01 pm
I've worked out how to raise this via help.mikrotik.com and have created SUP-70209.
blurrybird
Thu Dec 30, 2021 5:26 am
Seems to be more than just CAKE. fq-codel also affected.
viewtopic.php?p=883027&hilit=ipv6+cake#p883027 seems to detail the same problem.
mducharme
Trainer
Trainer
Thu Dec 30, 2021 5:37 am
I heard it is with any queue type at all with simple queues. Have you found any queue type that does work?
macgaiver
Thu Dec 30, 2021 7:16 am
You should put cake as interface queue, instead of creating simple queues for it.
With great knowledge comes great responsibility, because of ability to recognize id... incompetent people much faster.
blurrybird
Thu Dec 30, 2021 12:23 pm
You can only assign a single interface queue. How do you handle asymmetric bandwidth limits?
infabo
Thu Dec 30, 2021 12:59 pm
You cant assign a queue to lte Interface.
curtdept
Fri Dec 31, 2021 7:46 pm
Only true if you triple isolate and don't really want to ack filter, etc. Cake config is really geared toward being different between upstream and downstream.
Tporlapt
Sat Jan 01, 2022 10:45 am
Same with PCQ Simple Queue applied to target = WAN interface. Functionally works as expected for IPv4, breaks IPv6
Working with networked devices since the 1980s. That makes me old, not an expert.
ErnyTech
Sat Jan 29, 2022 12:42 am
This problem continues to be present, it is quite absurd that there is no answer from mikrotik ...
crosswind
Sat Jan 29, 2022 12:03 pm
i'm also having this problem (raised as SUP-72949) with fq_codel as a simple queue - when the queue is enabled, new IPv6 conntrack rules are not added. has anyone found a workaround?
Jotne
Sat Jan 29, 2022 12:16 pm
Have you tested latest beta? If so add these information as well to support@mikrotik.com
Use Splunk> to log/monitor your MikroTik Router(s). See link below. :mrgreen:
MikroTik->Splunk
ivantirado
Sun Jan 30, 2022 2:54 am
I’ve had this problem and reported it to support. It started a few releases back and has stayed constant… in my case, any simple queue causes IPv6 traffic to fail. No matter the queue algorithm. Using interface queues works, as well as using queue tree. It’s a simple queue problem… I was told to try a newer beta release but it didn’t work. Support didn’t see anything wrong with my configs or supout.rif - they see no problems there.
mducharme
Trainer
Trainer
Sun Jan 30, 2022 5:14 am
What you can do is, if your only LAN interface is a single bridge, you can create two queue trees, one on the WAN port for shaping upload and one on the bridge interface for shaping download. They need to fix this, but in the interim, this can work.
ErnyTech
Sun Jan 30, 2022 12:11 pm
It is crazy that they keep saying that everything is fine, when multiple people are reporting the issue.
razondz
Sun Feb 13, 2022 12:11 pm
Still broken in 7.1.2 apparently. I hope it will be fixed soon.
mke
Mon Feb 28, 2022 3:45 am
EDIT I edited this post and removed some code examples as I realised I had completely forgotten how queue tree works.
Its been a while since I've used ROS. In this scenario is there any need to account for the combined bandwidth, similar to how with the setup below the UL and DL are wrapped in the unshaped "total-queue=cake-default"?
/queue type
add kind=cake name=cake-ul cake-bandwidth=15.0Mbps \
	cake-atm=ptm cake-diffserv=besteffort cake-nat=yes cake-overhead=22 cake-overhead-scheme=bridged-ptm,via-ethernet
add kind=cake name=cake-dl cake-bandwidth=45.0Mbps \
add kind=cake name=cake-default \
/queue simple
add bucket-size=0.001/0.001 disabled=yes name=cake queue=cake-dl/cake-ul target=ether1,ether1 total-queue=cake-default
blurrybird
Fri Mar 25, 2022 12:19 am
Everything is working once again in RouterOS 7.2rc5 🎉
asiobob
Fri Mar 25, 2022 2:11 am
Excellent. From the change log
*) queue - fixed queued IPv6 traffic considered as "invalid" by Firewall;
Users browsing this forum: safik and 8 guests
